| Author | Subject: Midlife's Rallye |
puglover
Banned!Location: Far out there Registered: 08 Jun 2006 Posts: 6,095 Status: Offline |
Post #251
think my cooler came with an extension bolt |
Post #252
Buy some M20 threaded bar/set screw and drill it out?________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Post #253
I can drill out a set screw or some threaded bar if you need me to Wayne, just let me know what size you want it drilling to and how long you want it and i'll see what i can do ________________________________________ Goldie the track car. |
midlife
Seasoned Pro Location: Colne, Lancashire Registered: 13 Mar 2006 Posts: 7,544 Status: Offline |
Post #254
Thanks for the offer Stephen!I might just take you up on it if the suggestion from Miles doesn't work. miles wrote: This old chesnut, Comes down to people not knowing what they are selling I'm afraid or saying you need another part, Just order 1103.54 (Mamelon or thread in English) from Pug, around a £1.00 I've had quite a nonproductive day at the garage today. I first checked my ptfe gasket against the sc inlet & found that I needed to dress the bores in the gasket a little to get rid of some positive steps into the gas flow. I just used a drum sander in the drill. ![]() I then dummy fitted the sc inlet on the engine with a spare fuel rail to see where I could position the dip stick tube. ![]() I then set about stripping the fuel rail from my old na inlet manifold. I removed the two bolts thinking it would pull off the tops of the injectors easily. After 5 minutes on my hands & knees on the floor with no success I put the manifold onto the bench only to discover that each injector is held in the fuel rail with a little black clip. ![]() Clips off & it came apart fairly easily. I then spent a couple of hours preparing the fuel rail for paint, what a ballache ensuring no crap got inside it!!!! Fuel rail painted. ![]() Also painted the dip stick tube. ![]() Decided to pull up stumps at this point as it was bloody freezing! ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
Post #255
haha loving the leather sofa mate to sit down nd work on |
midlife
Post #256
It's somewhere to rest my old bones![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
midlife
Post #257
This turned up in the post today from Miles, cheers buddyProblem solved! ![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,311 Status: Offline |
Post #258
cute little doggie________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
midlife
Post #259
hovis16 wrote: cute little doggie It's Princess Aura Tilley Pompom ![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
eddy_gti6
Post #260
midlife wrote: Also painted the dip stick tube. ![]() Decided to pull up stumps at this point as it was bloody freezing! ![]() that dip stick looks huge ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
midlife
Post #261
My 1 litre swirl pot & Facet solid state fuel pump arrived today.![]() I'll be using the facet pump to lift the fuel from the tank to the swirl pot then I'm planning on fitting the Walboro high pressure pump somewhere under the bonnet so that the run of pipe under high pressure is as short as possible. I know that most of the SC boys use the STD in the tank pump to send the fuel to the swirl pot but my theory is that the STD pump is designed to run at 3 bar & won't like the fact that it's seeing no pressure. This Facet pump on the other hand is designed to run at 7psi max so should cope nicely. ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
midlife
Post #262
Wow, 10000 views![]() Thanks lads! The motivation this gives is unbelievable ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
Post #263
Oh more shiny bits! |
midlife
Post #264
After seeing a thread from one of our Scottish members showing the end result (crash pics) of using a pattern brake master cylinder on an expensive project car I decided mine was getting a genuine Peugeot master cylinder.I got one from Luke Jenks for £64.48 + vat, very reasonable I think. It arrived today, cheers Luke!!!! ![]() ![]() It's coming together slowly but surely ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
eddy_gti6
Post #265
you covered her tits... NOOOOOOOOOOOO!!!!________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
midlife
Post #266
did you like what I did there keeping it safe for work![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
eddy_gti6
Post #267
not the best fake boobs i have ever seen but atleast you got the white bits right safety first tho________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Post #268
![]() ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
eddy_gti6
Post #269
looking good tho. when you expecting to have it ready for the track ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
midlife
Post #270
If things go smoothly we should be good to go June/July ish next year![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
berger
Seasoned Pro Location: Bathurst Registered: 26 Oct 2008 Posts: 1,068 Status: Offline |
Post #271
When I replaced the m/c in the Xsara earlier this year I bought a pattern one, only to recieve it, decide that the quality looked a little shoddy and go to ECP to order an OE one, which was 10x better!________________________________________ Bang'in 7 gram rocks!I have one gear, GO! |
Post #272
I reckon that picture is Waynes sneaky way to get another 1000 views sharpish....![]() ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
chrisd306
Seasoned Pro Location: Perth Scotland Registered: 26 Nov 2005 Posts: 10,061 Status: Offline |
Post #273
looking forward to seeing pics of your fibre glass bits so that i can deside if im getting some or not!That small helper pump. bet its loud, the 1 in cherrys 106 does your nut in clicking away!! ________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
midlife
Post #274
I'm going to mount it on rubber bobbins so it shouldn't be too bad, let's face it the whole car is going to be bloody noisy so a bit of ticking isn't going to make much difference..I'll post a write up on the fg bits when I get home on Sunday ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
chrisd306
Post #275
Cool as im thinking of buying a bonnet and door cards and bootlid, then some poly carb windows.My mates 106 the noise is mad, but if you watch his videows on youtube you can hear the pump clicking over the exhaust lol an his is mounted straight to the floor tho, he used to where ear defenders on the road it was that bad lol. ________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
