displaying posts 1 to 25 of 388
Pages (16): [1] 2 3 .. last
Author Subject: Midlife's Rallye
midlife
Right then, guess it's about time I started a project thread!
I like my trackdays..
& a bit of drag racing..
I took it as far as I could with the STD engine, fully stripped interior, updated suspension, richw's roller brg wishbone bushes, phillipm's rosejointed droplinks, 330mm discs & brembo's 4 pots & 17" alloys.
The next step was more power......
Normally aspirated looked the way to go, 250bhp was doable, not cheap mind with high compression pistons, wild cams & throttle bodies. Then Ford & Renault started bringing their turbo nutter bas**rds out, suddenly na was not the future! Even with a little nitrous!
Around that time the news broke about Richw's beast. I kept in close contact with Rich & when he announced the first batch of supercharger kits I put my name down straight away. True to form Rich delivered.
I knew I couldn't run 400+bhp with the suspension I had so I sourced some Koni coilovers, 23mm torsion bars, 30mm arb from Ash & a spare beam to get to work on.
Now I knew that I couldn't do this work in the street with all the shady buggers round where I live so I started looking for a garage. I tend not to do anything the cheap way so I found a unit in an old milking shed on a farm out in the country. I bought a ramp, bfo compressor, mig welder & loads of tools that I thought I'd need. This lot put a massive hole in my finances.
I started by rebuilding the spare beam..
CRF450 (Martin) machined my trailing arms to achieve a little bit of negative camber, so I carried on painting..
Special discs from phillipm.
Tb's & arb
I fitted new bearings & seals, assembled it all, wrapped it all in cotton wool & put it on a shelf.
I the removed the old beam & found that the single layer of paint found on Rallye's had done fook all to prevent rust. Now this is where I made my big mistake! Because I'd made a good job of the beam I wanted to make a good job of the rear end, looking back I should of just caked it with loads of underseal but no because I'm a cock I got carried away...
Next thing was to fit the beam with some shiney solid mounts from BBM.
A little negative camber..
And phillipm's discs
Ride height exactly the same as Martin's
Rear end DONE!
Made a start on the front...
Is that rust I see
Several weeks of grinding, grinder mounted wire brushing and we get to....
A couple of mods to the strut tops for the KAD adjustable top mounts
Front end DONE
Next came the interior.
I wanted a cage but I wasn't too happy with the cages on offer from SD & OMP, I came across a for sale thread on this forum for a SD challenge spec bolt in cage, Binka did not need it & for what he was asking for it I couldn't resist!
In she goes
I thought bolt in, it will be a piece of p*ss to fit, how wrong could I have been!
I had to weld 17 yes seventeen plates to the shell so it took me ages, I got arc eye, radiation burns & shitloads of spatter down my neck not to mention I'm getting on a bit now & I'm a fat bas**rd so I'm not built to spend several weekends on my knees bent double welding fecking plates in place.
I then got stuck into cutting as much as I could out of the back of the dash, I've only got this pic when I was half way through it
I fitted a couple of these fan hatred into the top of the dash as I've done away with the heater
Then came last Xmas, the wife bought me an Xbox 360 with Modern Warfare 2 & I have not been to the garage since, until this weekend that is.
I've loosely fitted the front suspension, rolled it out of the garage for a good clean up & started stripping the engine so I can start building it to high boost spec with all the goodies I have laying about.
More updates to follow!!!!!
I did this all on my mobi so please forgive any typos!
Cool
Team 330™Cool
Team "no front end or engine"
Posted 23rd Aug 2010 at 05:31
That's a nice WIP thread. Nice to see once fully done.
Any idea on the weight lost thus far?
Posted 23rd Aug 2010 at 05:47
midlife
It started life at 1140kg, I've weighed quite a lot of the things as I've taken them off & there are fg bonnet & boot, Kevlar wings & plastic windows to come. There may even be fg doors too. I know it will be well under 1000kg but just how much under only time will tell!!
Cool
Team 330™Cool
Posted 23rd Aug 2010 at 05:57
mabgti
NV motors
finaf*ckingly wayne... we desrve a decent read! Big grin
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 23rd Aug 2010 at 05:58
midlife
I'm back on it now so expect weekly updatesThumbs up
Cool
Team 330™Cool
Posted 23rd Aug 2010 at 06:04
jeffers Forum Admin
LOL Its been that long since i seen you buy anything shiny i thought you'd sold the Rallye! Nice read though.....Cool
Team Running Engine again!
Team Negative Camber!
Posted 23rd Aug 2010 at 12:30
ben306
Nice one mate. Be nice to see it back, thats for sure Smile
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 23rd Aug 2010 at 13:08
CUJ
Nice thread, I was wondering recently where you'd been as I thought you had a project on the go (answer on the xbox LOL) Thumbs up
340 horses
Posted 23rd Aug 2010 at 13:42
Cracking project Cool
Looks awesome (bar those f*cking horrible rear lights) LOL
Posted 23rd Aug 2010 at 16:24
midlife
Those rear lights are lighter than the STD onesNinja
Cool
Team 330™Cool
Posted 23rd Aug 2010 at 20:54
Fight, fight!
That's a serious exhaust manifold gasket you've got on the shelf down, bet that took some porting.
Looks like a very interesting thread my friend, I'll be keeping an eye on this one fo' sho'. I thought about getting some of those electric blowers but was assured they're complete crap, have you tried them out yet?
O.
Posted 23rd Aug 2010 at 20:58
simonjames
Cool
some things need to be heavier then LOL
MY EBAY ITEMS
07943066306
Posted 23rd Aug 2010 at 21:01
fletch
Track Head
Laugh my ass off
Good thread Thumbs up
Posted 24th Aug 2010 at 03:31
binkagti
Glad to see cage fitted mate, should never have sold it looking back lol. Never mind, you live and learn.
TEAM Supercharged Rallye
Posted 24th Aug 2010 at 03:57
puglover Banned!
"not been out since the wife bought an Xbox 360 with MW2" Laugh my ass off
Handle?
same here really except i moved out and all that shite Sad
Glad your back on it though wayne, i should make a thread one day too. Smile
Posted 24th Aug 2010 at 21:20
midlife
Xbox name strangely enough is Midlife 306 UK
8th prestige & all fine & dandy killing yanks!!
Cool
Team 330™Cool
Posted 24th Aug 2010 at 22:31
puglover Banned!
8th prestige LOL you have been busy Smoke
Posted 24th Aug 2010 at 22:41
vernam616
owain wrote:
Fight, fight!
Laugh my ass off
Audi S3 Black Edition
Posted 24th Aug 2010 at 23:06
birk
Updates god dammit LOL
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 24th Aug 2010 at 23:13
eddy_gti6
them rear discs look Cool
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 24th Aug 2010 at 23:34
tea boy
what is the story with the crinkle cut discs?
They look wierd.
Make tea, not war.
If it ain't broke......fix it until it is.
Posted 25th Aug 2010 at 23:48
midlife
Light weight & better biteNinja
Cool
Team 330™Cool
Posted 26th Aug 2010 at 00:38
Great in the wet too!
Posted 29th Aug 2010 at 00:15
andy306gti
What makes it better in the wet?
Posted 29th Aug 2010 at 06:25
Clear water from the disc easier and you don't suffer any knockback from the boundary layer of water.
Posted 29th Aug 2010 at 23:26
