displaying posts 151 to 175 of 3423
Pages (137): first .. 6 [7] 8 .. last
Post #151
derp, missed you were going to box it LOL
That's ok Mei ...I'm always glad of your Knowledge & great input m8 ...I've learned the danger First hand of Petrol & having it behind me is a little scary m8 ...
Yes I'm going to make a Alloy box completely over everything ...just incase a hose comes lose or something fails or God forbid upside down / bad accident .
Posted 5th Mar 2016 at 17:21
Post #152
Just some tiding up to do under the bonnet & a couple of Pipes to make ...
The ABS will be coming out next year Thumbs up
Posted 5th Mar 2016 at 20:14
Post #153
I really like not having ABS. Seems to kick in way too early in the xsara in comparison
Posted 5th Mar 2016 at 21:46
Post #154
Not caused a massive problem Adam ...but I feel it's just not needed ?
Posted 5th Mar 2016 at 22:04
demondriverdan
Post #155
I've not had ABS for ages, haven't had any problems. In the wet it locks up, obviously, but you learn to modulate the pedal properly.
Do you not run the heat exchanger? I've got an oil cooler and thought about getting rid of the heat exchanger but figured for 2 pipes and a small about of weight it does no harm.
Rallye Race Car
Posted 5th Mar 2016 at 22:06
Post #156
Havnt had one on mine since I fitted the oil cooler. The heat exchanger was weeping oil anyway was glad to get rid of it lol.
However I tried an Xsi radiator without the take off pipe for it and blanked off the one on the top hose on the 6 and soon as I booted it for any length of time the coolant temp would rise noticeably.... swapped back to a standard nissens rad and looped the 2 pipes together and no problems since? Either it wouldn't Bleed out completely with the top hose takeoff blanked or the rad I used was s**te but it didn't like it with boost.
Posted 5th Mar 2016 at 22:11
Post #157
Doesn't seem to in my phase 2 6 barely cuts in at all with massive brakes etc but many phase 3 cars I've driven seem a lot more intrusive. Maybe because they have the EBD as well?
Posted 5th Mar 2016 at 22:12
Post #158
I didn't have any issues with my abs kicking in too early on my phase 2 when i had it with the standard calipers. It weighed too much though so it went when i upgraded to 4 pots.
Posted 5th Mar 2016 at 22:57
Post #159
I've Never run a stnd Heat exchanger after mine failed & leaked & I just blanked the radiator take off & the Silicon hose take off & never had a water temp issue running TBs
The ABS doesn't seem to work or kick in much with 330s which I'm glad of ...just want to remove it all & clear some pipework & the box out of the engine bay ..
I'm in no rush it will be much easier with the engine out of the way LOL
Posted 5th Mar 2016 at 23:30
Twangy
Post #160
what the f**k is ABS on a track car , comp car , Im not fussed on it on my every day vehicles , ,easy enough to remove with engine in Damien , , car looks like its coming along well m8 Thumbs up
wayne mcardle
Posted 6th Mar 2016 at 08:38
Post #161
I'm wondering if these phase 2 cars have working compensators! LOL
It makes a huge difference (once the rears have a bit of heat) to the amount of braking you can put in.
Posted 6th Mar 2016 at 09:08
Post #162
As we know Wink Laugh
Posted 6th Mar 2016 at 09:16
cully
Post #163
on my Ph 2 i can really stand on the brakes pulls up very long before the ABS kicks in yes the compensator is free and working and the ABS works
my Ph3 daily i hate the ABS on that as all id does is extends the stopping distance by turning the brakes off very scary
Posted 6th Mar 2016 at 09:52
RetroPug
Post #164
http://www.frenchcarshow.co.uk/
Scroll down to "find more information". That's you I think?
Posted 6th Mar 2016 at 10:00
demondriverdan
Post #165
The whole ABS systems weighs about the same as the twin fan unit I think, it's not particularly heavy!
Rallye Race Car
Posted 6th Mar 2016 at 12:15
Post #166
Scroll down to "find more information". That's you I think?[/quote
Yes it is LOL
Posted 6th Mar 2016 at 12:25
Post #167
Small update .....nothing special as loads on here seemed to of done this Mod already Thumbs up
Had JIC6 ends welded on to stnd fuel rail now everything's going to be JIC6 fittings under the bonnet ...
Posted 9th Mar 2016 at 16:53
Chr1sch
Post #168
What is the benefit of that mate? Safety?
Posted 9th Mar 2016 at 17:08
Post #169
It appears it's much safer & after my Fire ....Petrols on my scare the sh-t out of me list LOL
Chris ...It just means for me also ... No push on rubber pipe with fuel hose clamps anymore & I can run my spare 811 PTFE Stainless braided Goodridge hose & JIC6 fittings in the engine bay as well as in the car now Thumbs up
Info here Chris
https://www.merlinmotorsport.co.uk/s/goodridge/goodridge-811-series-fuel-in-car-hose-fittings/811-series-hose
Posted 9th Mar 2016 at 17:46
Post #170
Modifying,it never stops LOL
Posted 9th Mar 2016 at 18:26
RetroPug
Post #171
Well, until you break it for parts LOL
Posted 9th Mar 2016 at 18:31
Post #172
I hope I don't but it would be the only chance of getting any money back at all now Crazy
Posted 9th Mar 2016 at 19:33
Post #173
Because of my fuel line fire my two fuel pipes & breather hose to my Charcoal canister had to be rerouted sadly ...
Now fitted ...Red in the Picture ....Upside down breather vent on alloy p clip from tank now ...up above & inside drivers rear wing & under arch liner
Then vents out ...no pipework inside for this
My 811 PTFE fuel pipes are now running down the passenger inside exhaust tunnel
To the right of the red upside down valve which cuts fuel off if I turn the car over ...is the petrol filler cap cable operner Thumbs up
Posted 13th Mar 2016 at 09:49
Post #174
Bought a couple of these to blank my Brake hoses...
Saving on losing my expensive brake fluid all over my drive ....
I've taken my Brembo V6 4pot Calipers off for (Godspeed) in Bridgend to totally refurb them ...
Less than £1.50 each delivered from fleabay ....not worth making anything
Posted 13th Mar 2016 at 10:36
demondriverdan
Post #175
I took a bit of copper pipe with a union then crushed the end down Big grin Probably should get some proper blanking plugs at some point though
Rallye Race Car
Posted 13th Mar 2016 at 11:58
