displaying posts 126 to 150 of 3423
Pages (137): first .. 5 [6] 7 .. last
Post #126
haha that cant be the same thing you had off me 2 weeks ago Laugh
Posted 26th Feb 2016 at 09:38
Post #127
Yes it is & the Engines with Sandy for 12months time collection going 2.2 Whistle
Posted 26th Feb 2016 at 09:41
Post #128
Cool still got the sump and Xsara jet washers safe here for you bud! Thumbs up
Posted 26th Feb 2016 at 09:51
Post #129
Top man Thumbs up
Posted 26th Feb 2016 at 10:00
Post #130
last time for the (first) time some 130-135 oil temps at Combe were appearing ?
I was Not 100% happy with that on track last time ....seeing as I have a 16 row cooler with good air flow to it with my oil being Millers nano 10w-40w .... my Mocal thermostat sandwich plate ...i think it's not opening enough at 80 degrees ...can't be messing with it I'm just changing it .
Changed it over to a fully open Mocal Sandwhich plate now...I then haven't got to worry about if it's opening 100% or not...
I'll just have to warm the engine up a little more before using it on track .Thumbs up
Posted 26th Feb 2016 at 23:29
jeffers Forum Admin
Post #131
Have you thought of changing to a 10w 50 or 10w 60?
Team Running Engine again!
Team Negative Camber!
Posted 27th Feb 2016 at 00:02
Post #132
Thicker oil will just make it run even hotter.
Posted 27th Feb 2016 at 01:16
jeffers Forum Admin
Post #133
It's not thicker Phil....
Posted 27th Feb 2016 at 01:21
jeffers Forum Admin
Post #134
Sorry il reword that, it's not thicker per se, basically it will break down at a higher temperature. Mine on track runs cooler with a 10w 50 in it.... The 10w 40 was running hotter and the pressure was visably lower after2-3 laps. Plenty of people run a 10w50 or 60 in track cars?
Oh balls, I know what I'm trying to say but not wording it very well, il try again in the morning when I'm not so tired! LOL
Posted 27th Feb 2016 at 01:39
Post #135
The idea is to run a thicker oil to keep you at the same viscosity as the thinner oil at 'normal' temperatures, but a thicker oil in and of itself will increase temperatures, especially in the bearing shells.
Ideally you stick to the thinner oil and control the temperature, if you can't do that, you shift to thicker oil to compensate.
50-60w is definately thicker than the 40w he's running though Wink
And he's running decent oil so high temp breakdown shouldn't be an issue, certainly not with a 40w, perhaps with 5w-20 or similar with low HTHS figures but not that Millers.
Posted 27th Feb 2016 at 01:47
Post #136
Thank you Jeffers & thank you Phillip for your great knowledge ...I'm always wary of changing oils as it seems what you gain one place you seem to lose in another ?
I'm worried the Valve has somehow gone faulty & not opening fully & may be partially stuck or something ?
My reasons which I didn't make clear MY FAULT / SORRY ....I haven't removed & tested it yet but ......
When I came in on 4-5 occasions at Combe after some really heavy 15 or so laps my Oil cooler was only just warm to touch & it used to get very hot ...it was a warm day ...my oil temperature has only ever maxed 120-125 ...
Last time without anything changed inc oil 130-135 & nearly hit close to 140 ...
First of all I thought faulty reading but no I believe it's the Thermostat in the Mocal playing up ...
I'll try this fully open curcuit one & see if it makes a difference ?
I really will only be doing Action days & track days now 90% of the time so warming the oil up shouldn't be a issue ....ill just have to let it tick over on start up a little longer Thumbs up
Posted 27th Feb 2016 at 07:52
aaron6
Post #137
Let us know how much longer it takes to warm up the oil mate. I'm also tempted to remove my mocal thermostatic sandwich plate when my 16 row cooler replaces my 13 row one. But I use my car as the daily so need it most likely.
Posted 27th Feb 2016 at 08:56
Post #138
Was told 10mins & should be 15-20 cooler ...lets hope & I'll update you when I know 110% Arron ..Thumbs up
Posted 27th Feb 2016 at 09:40
cully
Post #139
I had a problem with my mocal plate sticking ive sorted it now by cleaning up the ports and shuttle Wink
oil temps are good now round combe at around 100c as was 130+ before
http://www.306gti6.com/forum/showthread.php?id=164228
Posted 27th Feb 2016 at 09:45
jeffers Forum Admin
Post #140
Thinks by about it, I stripped my thermostatic plate and did the same as Cully and the temperatures dropped last time out... I put it down to it being November and freezing cold but thinking about it now cully's fix has probably sorted the issue....
Posted 27th Feb 2016 at 12:56
Post #141
That's Brilliant Cully Thumbs up
I'm still going to try mine with out & take mine apart Now Thumbs up
Posted 27th Feb 2016 at 18:38
Post #142
Old Bilsteins removed today & Drivers side has been badly damaged by my Fire including my Goodridge brake hose ....going to ring Bilstein Monday & see if they can help ...
Posted 5th Mar 2016 at 16:05
Post #143
Top mounts fitter with Suspension today & they work great / Russian Guys design is Amazing .Thumbs up
Just got to modify my top brace now to fit New mounts
Posted 5th Mar 2016 at 16:24
Post #144
Looking good poppit Thumbs up
Posted 5th Mar 2016 at 16:11
Post #145
Just got to plumb in the swirl / pump / filter all rubber mounted with Goodridge 881 PTFE / Stainless braided hose with JIC6 fittings ...
Both Pipes to fuel rail in the engine bay will go down Passeger side inside car on P clips ...
I'll build a metal box to go over the Swirl etc ...like a fire wall ...Thumbs up
Posted 5th Mar 2016 at 16:17
Post #146
Been busy since 7.00am this morning ...These are Twangy / Wayne's door panels & rear panels he made me I fitted them as well today ..amazing quality & great price ..I did them in Matt finish as it shows less marks & I personally like the look better .
Used Stainless steel Screws to fix them Thumbs up
Posted 5th Mar 2016 at 16:42
Post #147
I'll send you mine if you like Jeffers ?
I won't be using it again .Thumbs up
Just waiting for my fuel tank hose connecting fittings ...big thank you Cully ...I'm pinching your great idea then no chance of petrol fumes then Thumbs up
Posted 5th Mar 2016 at 16:45
Post #148
It's starting to get there Ash Thumbs up
Won't be ready this month though ....
Aprils my dead line m8 hopefully ...
Posted 5th Mar 2016 at 16:47
Post #149
fuel system is not ideal, needs to be boxed or underneath.
Posted 5th Mar 2016 at 16:57
Post #150
derp, missed you were going to box it LOL
Posted 5th Mar 2016 at 17:00
