This rear bumper will be modded as I need the exhaust to come out of the centre
| Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #3401
This rear bumper will be modded as I need the exhaust to come out of the centre |
ben306
Seasoned Pro Location: North West Registered: 17 Jan 2006 Posts: 2,954 Status: Offline |
Post #3402
Its going to look pretty impressive once you've got this done.Is it the hub spacers you'll be going with to get the wider rear end? ________________________________________ My 306 Rallye Project ThreadFew recent Youtube track videos, more on my channel Pair of Rallye's doing a few laps of Anglesey Lap of Anglesey Coastal 3 sisters circuit Few laps at Blyton |
Post #3403
ben306 wrote: Its going to look pretty impressive once you've got this done. Is it the hub spacers you'll be going with to get the wider rear end? thank you Ben ive got a Andy Williams rear beam with Bridgecraft enginnering converted 40mm full hub spacer bolted on behind the bearing on each side at mo but will be having one of the new push / pull Satchell full width rear axles with 1to1 dampers and springs when they are made ...similar to the 106 -205 ones |
Post #3404
well here we go and got everything to bond the rest Composite Wings on now |
Post #3405
Post #3406
got 40 of these also for holding the panels while the Green two pack 3m drys |
ben306
Post #3407
Day666 wrote: got 40 of these also for holding the panels while the Green two pack 3m drys ![]() Ive been thinking something like this may be useful for when I come to replace sections of panels on the campervan to help hold everything in place but then Im not sure it it would end up being more hassle in the long run ________________________________________ My 306 Rallye Project ThreadFew recent Youtube track videos, more on my channel Pair of Rallye's doing a few laps of Anglesey Lap of Anglesey Coastal 3 sisters circuit Few laps at Blyton |
Post #3408
ben306 wrote: Day666 wrote: got 40 of these also for holding the panels while the Green two pack 3m drys ![]() Ive been thinking something like this may be useful for when I come to replace sections of panels on the campervan to help hold everything in place but then Im not sure it it would end up being more hassle in the long run yes I think it would be Ben as you need to drill holes through overlap Composite i'm using but easy when im bonding and filling Composite but Metal wound defo take much longer |
Post #3409
i need to get under my 306 and sort some welding and areas out Thanks to Carl Grimsley i own a Rotisserie for my 306 and with luck after removing the engine it can make cutting and fitting the composite panels easier being higher PS Carls 306 (NOT MINE) |
Post #3410
Hello all it's been a few months since i've posted and have cleared the garage out so i can work around the car easier soon and then get the jig on it and make a start on the underside and cut and bond the rear wings on ...im sure a few of you have been where i am with 2 jobs and limited time ...i need to make time i say but bad weather and any excuse has stopped me Right lets get to the best bit ...those who have read my updates on this Unicorn have seen im going full Maxi width front and back now (with a little twist ) airbox coming through the bonnet for 100% cold air feed & a change from standard maxi - front bumper having a splitter & air duct brake intakes ...it may work or may not ...induction noise maybe too much ??? anyway my update is a big one below is hopefully what i'll be getting in 3-4 months all being well ? it's a exact copy of a Maxi Rear beam but not £20k those of you may say why seeing as i have a Andy Williams top end beam with Bridgecraft 40mm spacers and 30 arb and 24torsion but in my head because i've gone so far now i need it to be as good as i can get it !!!! .... it's got a 289bhp engine and Full sequencial six speed paddle shift gearbox and everything's gone as little weight wise as i can but the only thing it needs in my messed up head is that kit car beam .... fingers crossed it will happen but i'm confident it will ...sort of ...hopefully .... ![]() |
Post #3411
Post #3412
tsd167
Junior User Location: Spalding Registered: 07 Aug 2010 Posts: 73 Status: Offline |
Post #3413
great update on how to build the ultimate such impressive work well done. |
marksorrento205
Seasoned Pro Location: Airborne in the lanes Registered: 26 Aug 2008 Posts: 2,228 Status: Offline |
Post #3414
Holy f**k Batman. Going to be epic this ________________________________________ How to do a clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
ben306
Post #3415
This thig is going to be a beast when (if) it sees the tarmac________________________________________ My 306 Rallye Project ThreadFew recent Youtube track videos, more on my channel Pair of Rallye's doing a few laps of Anglesey Lap of Anglesey Coastal 3 sisters circuit Few laps at Blyton |
Post #3416
tsd167 wrote: great update on how to build the ultimate such impressive work well done. Thank you Tim and i just hope i get to finish it |
Post #3417
marksorrento205 wrote: Holy f**k Batman. Going to be epic this thats what my Bank Balance says Mark |
Post #3418
ben306 wrote: This thig is going to be a beast when (if) it sees the tarmac Thanks Ben & hopefully the Unicorn will one day and with me I hope |
jord294
Post #3419
Day666 wrote: ![]() 👌 ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Post #3420
Hopefully you will all understand !!!!Its with great regret ill be breaking and selling up everything i own GTi6 and Maxi 😢 Due to a serious health scare im not able to finish this car ... anyone interested in anything on my profile pages please contact me 07971704666 PS ill also be selling Mike Blands old Satchel shell i bought off him end of last year .... sometimes you just have to do whats best for your family it was a fantastic journey xxxxxxx |
Joep
Senior User Location: Urmond (The Netherlands) Registered: 19 Sep 2013 Posts: 501 Status: Offline |
Post #3421
Your health and your loved ones health are most important! Can only imagine this must be a very tough decision! Always loved to read all your update and was hoping to see it in real life one day. Thanks for sharing this amazing project with us!Hope you will be still around on this forum and I wish you all the best!Hope your health will be okay! ________________________________________ My car park:'96 Sigma Blue XSi6 '98 Diablo Red GTi6 '99 Onyx Black S16 All RFS powered! Plus various other Peugeots |
jord294
Post #3422
Day666 wrote: Hopefully you will all understand !!!! Its with great regret ill be breaking and selling up everything i own GTi6 and Maxi 😢 Due to a serious health scare im not able to finish this car ... anyone interested in anything on my profile pages please contact me 07971704666 PS ill also be selling Mike Blands old Satchel shell i bought off him end of last year .... sometimes you just have to do whats best for your family it was a fantastic journey xxxxxxx So sorry to hear this. Health and family are what matters ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Post #3423
Big Thank you to everyone who contacted me and bought stuff & sent good luck xive got very little left now from the car and @ the end of the month ill post the few items i still have once i sort everything out totally in the garage as ill be selling non 306 items also Its been a blast for the last 13yrs owning this 306 ....i wouldn't change anything guys . but my health is now top priority regards Damien PS ...its been a tough few months and then two weeks ago i find out my 24yr old son Ben Jefferies based in US has been selected for Team GB Olympic Paris = 400x4 sprint team .... so down & then shock and disbelief all in a few months ....Life Hey !!!!! |
eiei0
Regular Location: Kildare Registered: 08 May 2020 Posts: 193 Status: Offline |
Post #3424
Haven't been here in years seen it mentioned on FB you had sold up, sorry to hear your health is causing you issues, have had to deal with cancer myself over the last 18 months, but hopefully will get the all clear soon, look after yourself you can be proud that you built possibly the wildest 306 these pages ever seen, |
