| Author | Subject: achieving 200 bhp |
markylee
Regular Location: benfleet Registered: 05 Jan 2011 Posts: 393 Status: Offline |
Post #76
blandy wrote: Yeah maybe not less work but in my opinion more straigght forward. Have no idea about ecu, hopefully someone will tell us Cheaper at that cost if doing youself but not less work. Can you map the standard ecu to suit though or would you need standalone ecu |
markylee
Post #77
Also will it be worth doing a rebore and head skimmed |
rallyeash
Post #78
As on my reply before yours yes you can remap your sci, chip wizards do this________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
markylee
Post #79
rallyeash wrote: Cheers mate what do you think about a rebore and head skim As on my reply before yours yes you can remap your sci, chip wizards do this |
rallyeash
Post #80
88mm crank with S16 pistons will give you 50cc more anyway in a completely standard block. I would bother with head work just a set of cams.________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
markylee
Post #81
rallyeash wrote: 88mm crank, is that a completely new crank anwhere can i buy from, and the pistons 88mm crank with S16 pistons will give you 50cc more anyway in a completely standard block. I would bother with head work just a set of cams. |
markylee
Post #82
Ok I'm making a parts list, any help on where I can get the parts please88mm crank s16 pistons cams(what cams and where can I get them) |
rallyeash
Post #83
88mm crank is found in the 1.9td engines. I'm running 109 catcams in my gti6 engine, these are a standard fit for the head ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
markylee
Post #84
rallyeash wrote: Cheers mate, would never had dreamed of getting a crank from a 1.9td 88mm crank is found in the 1.9td engines. I'm running 109 catcams in my gti6 engine, these are a standard fit for the head |
blandy
Post #85
What kind of costs involved in doing a 2.1 engine build with labour etc |
rallyeash
Post #86
Mine... 87mm forge pistons and custome steel rods £1200 88mm crank inc polish £150 Block bored to 87mm £100 Cams £500 Vernier pulleys £200 Jenveys, inlet, trumpets, linkage £1,000 DTA ecu £500 Loom (I had the whole car custom wired from scratch £1,000 Arp bolts, bearings, 16 new valves, springs, head work, everything to build a new engine,assembled etc by Sandy brown. £ Can't remember! That gave me 230hp, 2088cc in a 740kg 205 :-) ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
rallyeash
Post #87
But I recon you could do 88mm crank £100 S16 rods and pistons £50 Bored block £100 Pocket machined pistons £100 Rebuild stuff £200 ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
blandy
Post #88
Thanks gives a kinda rough idea lol already on jenveys so just engine work next |
blandy
Post #89
Out of interest why do people not go the extra to forged pistons whilst its apart or are they just not necessary? |
Post #90
I wouldnt use s16 pistons, very heavy and most will be worn out these days, also attached to short rods.Personally i would get some pistons made to work with bushed gti6 rods, longer rod so less side thrust loads and mean a lighter piston. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Post #91
markylee wrote: jeffers wrote: Have you got a link to your thread, I'd be interested in copying er I mean seeing what you've donestan_306gti6 wrote: You could always go for some bike throttle bodies, 'Peugeot96' on here is doing this at the moment. It will be a lot cheaper than going down the Jenvey route, especially if you fabricate some parts yourself. I'm mid doing this exact thing along with my new engine build.... Which reminds me I must update my project thread...... I'm waiting on some adapter plates being machined up to fit the bodies on so as there's no silicone hoses required. Once I get them back hopefully next week sometime il post some pictures up so u can see how I'm doing it. It's an experiment at the end of the day, the engine is being build regardless of the bodies, if I can make the bodies work il be really happy! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Project D
Newbie Location: Finland, Turku Registered: 16 May 2012 Posts: 21 Status: Offline |
Post #92
Project D wrote: I have spend lot's sleepless nights and reading horror stories about cams and skimmed heads. I ordered Newman PH2 camshaft and i want to know will they fit unskimmed head?? Car is GTi-6. Can somebody answer my question. Pistons are standard and head is unskimmed. |
Post #93
Project D wrote: Project D wrote: I have spend lot's sleepless nights and reading horror stories about cams and skimmed heads. I ordered Newman PH2 camshaft and i want to know will they fit unskimmed head?? Car is GTi-6. Can somebody answer my question. Pistons are standard and head is unskimmed. yes |
beez_neez_gt
Post #94
Start a thread on the subject then.________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Post #95
Have you tried asking Newmans?________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #96
PH2's have half a mil less lift at tdc than pt80/81, so as long as you can guarantee its not been skimmed you'll be ok.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #97
AND only if timed correctly.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #98
yes, of course ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Project D
Post #99
OK... that nice to know. ![]() I have e-mailed to newman, let's see what he respond. |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,311 Status: Offline |
Post #100
welshpug! wrote: yes, of course ![]() Have you had your peter T's from paul yet? I love mine :-) timing them was fun tho ________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
