| Author | Subject: achieving 200 bhp |
markylee
Regular Location: benfleet Registered: 05 Jan 2011 Posts: 393 Status: Offline |
Hi all I'm thinking of increasing my bhp in my gti6, its standard at mo with just a k&n filter and exhaust. Was just after a few peoples opinions on how to reach around 200bhp, I dont want any more than 200, cheers |
Cams, head work + throttle bodies |
blandy
Cams and throttle bodies |
markylee
I was worried you was all gonna say that, tb's = very expensive |
blandy
Any proper power gains on a n/a car will be would need cams as well as the bodies though which is also a hefty chunk extra + new ecu etc so thousands unfortunately |
swiftyboi006
You could try a diy boddie conversion. Talki to yanni on here________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
markylee
Yeah, not sure wether to spend big or rethink on which race car, |
no need for any headwork, and bodies are not expensive, its the labour and consumables which adds up.why only 200? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
blandy
Why the need for 200? It's a odd figure to achieve as with bodies alone your under it but imo once you go into cams may as well look at pistons so would be chasing a bit higher figures. Carl chambers races a pretty much standard powered 306 in the tin tops series and does pretty well from what I've seen |
markylee
I dont want to go up in class, jut need about 190 to be top of my class. What do you think I would gain from just cams |
low to mid 180's, you are very limited due to minimal valve clearance.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
markylee
Have you experienced problems with cams in the past |
blandy
190 is doable with itbs. I was put off going for cams on a standard engine by miles due to the small tolerances etc |
Depends what cams you go for. I recommend catcams 4903110, mainly because i've got a pair i wouldnt mind selling. ![]() You'd need to sort out the pistons though, but they should be good well into the 200's if done correctly. This guy seems to have done ok on what looks like a standard inlet manifold. http://www.youtube.com/watch?v=ssaRxKV6jXk ________________________________________ Goldie the track car. |
markylee
sorry mate what is itbs |
blandy
Throttle bodies sorry |
swiftyboi006
Like blandy says you should message carl chambers to see how he gets on. Hes running a standard engine. ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
markylee
If I can get the car down to a 1000kg I would only need about 180bhp, The car goes really well but because power to weight ratio it sits low down in class. Any offers on gaining 180 |
JWP EFi
i thought a couple of people on here were almost nudging 200 brake with pocketed standard pistons, PT81's and remap. If i dont finish turbo project then this is something i am very keen to try |
blandy
Same as really a lot of people seem to get around 180-185 on a standard engine with jenvey bodies. 1000kg will be difficult as well unless you change panels to fibreglass and change windows etc |
markylee
t99 pug what sort of cost in pocketed pistons |
blandy
Yep but the pocketed pistons is the key but would also be costly unless you strip it yourself etc either way its gonna cost lol |
markylee
Blandy the car weighs 1030 at the mo, so a little more work with the grinder and I should be there, remember its a race car so no niceities comforts left in |
swiftyboi006
Any mild cam and a remap will see 180, its the getting the weight to 1tonne that will be costly ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
blandy
Lol mines just down to 1040 will nothing in it |
