displaying posts 26 to 50 of 156
Pages (7): 1 [2] 3 .. last
Author Subject: achieving 200 bhp
markylee
I could do the work myself, where can I buy these magic pistons
Posted 26th Mar 2013 at 21:46
blandy
You'd have to get the originals pocketed or buy forged items
Out of interest with your weight have you changed the windows and panels yet?
Posted 26th Mar 2013 at 21:47
JWP EFi
Turbo Legend!
i think bridgecraft engineering pocket them for £80-£100, then you may as well fit new rings and a set of shells, so approx £230 plus new head gasket, bolts. cams about £500, remap £400. i reckon (based on what ive read on here) you could be knocking on the door of 200bhp for around £1350, thats assuming you only need 'just' rings and big end shells.
Posted 26th Mar 2013 at 21:48
markylee
Swifty I'm just worried about horror stories with cams
JWP EFi
Turbo Legend!
mod your pistons or replace them, make sure cams are timed correctly and theres little to worry about
Posted 26th Mar 2013 at 21:51
markylee
Yes blandy, perspex windows except windscreen. all doors, boot ld and bonnet have had a row with the grinder, Im sure the purists are gonna hate me
blandy
There were some 2nd hand bodies and ecu for sake recently can't remember how much though
Posted 26th Mar 2013 at 21:52
blandy
Nice I'm yet to look at the windows but think that'll be next
markylee
Do you mean basic cam timing
Posted 26th Mar 2013 at 21:53
JWP EFi
Turbo Legend!
Post #35
marky - you have to time your new cams specifically then after that its basic cam timing when you come to fit / replace timing belt
Posted 26th Mar 2013 at 21:54
markylee
Post #36
Oh I see, a bit too advanced for me then
Posted 26th Mar 2013 at 21:56
JWP EFi
Turbo Legend!
Post #37
welshpug wrote a cracking thread about cams/clearances, search max lift at tdc. well worth a read
JWP EFi
Turbo Legend!
Post #38
its not that hard to do, find exact TDC then time up your cams with a DTI (dial test indicator) gauge
Posted 26th Mar 2013 at 21:58
markylee
Post #39
Do you need special cam pulleys
Posted 26th Mar 2013 at 22:01
JWP EFi
Turbo Legend!
Post #40
no. aftermarket vernier pullies won't work with gti6 ecu/phase sensor. standard pullies are adjustable though, i can't remember how many degrees of 'adjustability' the give but more than enough for PT81's etc
Posted 26th Mar 2013 at 22:05
markylee
Post #41
/www.snappyracers.com/album/2013/160313Snetterton/slides/G27P3102.html Cheers for all your help, heres a link to a pic of the car if anyones interested
Posted 26th Mar 2013 at 22:06
jeffers Forum Admin
Post #42
markylee wrote:
t99 pug what sort of cost in pocketed pistons
Speak to Martin (crf450) on here or Allen Allen his side kick, they can pocket standard pistons they did mine for me. I can't remember how much it cost to be fair (maybe £100 but dint quote me on that) but pocketed standard pistons allow fitment of slightly more aggressive cams ie pt81's but they can be correctly and safely timed up due to the deeper pockets. Hope this helps! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 26th Mar 2013 at 22:14
jamiek_uk2000
Post #43
Has anyone had problems with pistons failing after them having larger pockets machined into the pistons?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 26th Mar 2013 at 22:17
markylee
Post #44
Cheers guys some great advice
JWP EFi
Turbo Legend!
Post #45
how much power/torque did you end up with
Posted 26th Mar 2013 at 22:20
Post #46
no, Martin has checked how much meat there is safe to take out which is 1mm, sop that's how much they take.
Posted 26th Mar 2013 at 22:21
Post #47
You could always go for some bike throttle bodies, 'Peugeot96' on here is doing this at the moment. It will be a lot cheaper than going down the Jenvey route, especially if you fabricate some parts yourself.
Posted 26th Mar 2013 at 22:46
markylee
Post #48
im still gonna need ecu' though
Posted 26th Mar 2013 at 22:52
JWP EFi
Turbo Legend!
Post #49
i wonder how much of the good side of 200bhp you would see with bike bodies alongside pockets and PT81's?
Posted 26th Mar 2013 at 22:53
JWP EFi
Turbo Legend!
Post #50
Ideally yes, but good gains are said to be had with bodies and remapped stock ecu
Posted 26th Mar 2013 at 22:54
