displaying posts 1 to 25 of 156
Pages (7): [1] 2 3 .. last
Author Subject: achieving 200 bhp
markylee
Hi all I'm thinking of increasing my bhp in my gti6, its standard at mo with just a k&n filter and exhaust. Was just after a few peoples opinions on how to reach around 200bhp, I dont want any more than 200, cheers
Posted 26th Mar 2013 at 20:52
Cams, head work + throttle bodies Yes
Posted 26th Mar 2013 at 20:54
blandy
Cams and throttle bodies
Posted 26th Mar 2013 at 20:55
markylee
I was worried you was all gonna say that, tb's = very expensive
Posted 26th Mar 2013 at 20:56
blandy
Any proper power gains on a n/a car will be would need cams as well as the bodies though which is also a hefty chunk extra + new ecu etc so thousands unfortunately
Posted 26th Mar 2013 at 20:59
swiftyboi006
You could try a diy boddie conversion. Talki to yanni on here
Black p3 Love
markylee
Yeah, not sure wether to spend big or rethink on which race car,
Posted 26th Mar 2013 at 21:00
no need for any headwork, and bodies are not expensive, its the labour and consumables which adds up.
why only 200?
Posted 26th Mar 2013 at 21:14
blandy
Why the need for 200? It's a odd figure to achieve as with bodies alone your under it but imo once you go into cams may as well look at pistons so would be chasing a bit higher figures. Carl chambers races a pretty much standard powered 306 in the tin tops series and does pretty well from what I've seen
Posted 26th Mar 2013 at 21:21
markylee
I dont want to go up in class, jut need about 190 to be top of my class. What do you think I would gain from just cams
Posted 26th Mar 2013 at 21:22
low to mid 180's, you are very limited due to minimal valve clearance.
Posted 26th Mar 2013 at 21:24
markylee
Have you experienced problems with cams in the past
Posted 26th Mar 2013 at 21:25
blandy
190 is doable with itbs. I was put off going for cams on a standard engine by miles due to the small tolerances etc
Posted 26th Mar 2013 at 21:29
Depends what cams you go for.
I recommend catcams 4903110, mainly because i've got a pair i wouldnt mind selling. Laugh
You'd need to sort out the pistons though, but they should be good well into the 200's if done correctly.
This guy seems to have done ok on what looks like a standard inlet manifold. http://www.youtube.com/watch?v=ssaRxKV6jXk
markylee
sorry mate what is itbs
Posted 26th Mar 2013 at 21:30
blandy
Throttle bodies sorry
Posted 26th Mar 2013 at 21:31
swiftyboi006
Like blandy says you should message carl chambers to see how he gets on. Hes running a standard engine.
Black p3 Love
Posted 26th Mar 2013 at 21:33
markylee
If I can get the car down to a 1000kg I would only need about 180bhp, The car goes really well but because power to weight ratio it sits low down in class. Any offers on gaining 180
Posted 26th Mar 2013 at 21:37
JWP EFi
Turbo Legend!
i thought a couple of people on here were almost nudging 200 brake with pocketed standard pistons, PT81's and remap. If i dont finish turbo project then this is something i am very keen to try
Posted 26th Mar 2013 at 21:40
blandy
Same as really a lot of people seem to get around 180-185 on a standard engine with jenvey bodies. 1000kg will be difficult as well unless you change panels to fibreglass and change windows etc
Posted 26th Mar 2013 at 21:41
markylee
t99 pug what sort of cost in pocketed pistons
blandy
Yep but the pocketed pistons is the key but would also be costly unless you strip it yourself etc either way its gonna cost lol
Posted 26th Mar 2013 at 21:42
markylee
Blandy the car weighs 1030 at the mo, so a little more work with the grinder and I should be there, remember its a race car so no niceities comforts left in
Posted 26th Mar 2013 at 21:44
swiftyboi006
Any mild cam and a remap will see 180, its the getting the weight to 1tonne that will be costly
Black p3 Love
Posted 26th Mar 2013 at 21:45
blandy
Lol mines just down to 1040 will nothing in it
