displaying posts 201 to 225 of 289
Pages (12): first .. 8 [9] 10 .. last
Author Subject: the ZX 16v thread
Post #201
minor update - MOT ran out end of October so its been off the road whilst I tinker with a few bits, namely welding the exhaust and making pattern part tat actually fit properly, its quite shocking how crap the fit is!
New bushes on the bottom of the rear dampers, lifted the ride height a little on the back, swapped the bottom engine mount for a fairly fresh standard one but filled the voids with PU adhesive.
Annnddd managed to trace down a very reasonably priced genuine bosch fuel pump on teh bay of E all the way from Latvia, the walbro replacement I fitted only lasted 3 months, wasn't amused with that.
MOT booked for later today
Posted 6th Nov 2015 at 10:39
Post #202
one thing I love the SL434's for is that they are proper competition wheels for cars that used the same front end architecture (hub carriers drive flanges etc) , and thus they have quite epic brake caliper clearance radially....
that's a Renaultsport Brembo caliper from the Clio 3/Megane 2 over a 310mm rotor on an alloy bell, with NO spacers Shock granted there's bugger all clearance to the top corners where the nipples are, so I will run a small spacer to add a margin, but I am very pleased with that Big grin
Posted 6th Nov 2015 at 11:53
tvrfan007
Post #203
Like the brakes but not sure on the wheels myself. Great to see the mods coming along. Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 12th Nov 2015 at 21:41
demondriverdan
Post #204
Do you think it's possible to modify the caliper to fit under the wheels without spacers?
Rallye Race Car
Posted 27th Nov 2015 at 15:12
Post #205
yeah, I believe adam has taken a bit off the corners of his, my wheels went on without spacers.
Posted 27th Nov 2015 at 17:29
demondriverdan
Post #206
Problem is, I think they just look a bit crap on a 306! They work well on the ZX though
Rallye Race Car
Posted 27th Nov 2015 at 19:28
Post #207
im sure you'd get a 7" wide compomotive over them, the 6" needs a 10mm spacer
Posted 27th Nov 2015 at 20:24
Post #208
group a 306 used the sl434 btw.
Posted 27th Nov 2015 at 20:25
demondriverdan
Post #209
I'll keep an eye out for a set
Rallye Race Car
Posted 27th Nov 2015 at 22:56
Post #210
Wheres the updates Mei?
Posted 3rd Jan 2016 at 12:16
Post #211
No updates at the moment, its been sat in a yard nearby since I moved house early December, still needs a map.
Posted 3rd Jan 2016 at 18:22
Post #212
I sold the engine to Blandy back in December, as I had happened upon the basis of a full engine build, in the form of a Block and higher compression pistons.
The last few months have been a battle of collecting bits, deciding what direction to take it and budget constraints, and making it work with what I already have to hand!
Currently, I have a big jigsaw puzzle, almost ready to assemble, crank has already been fitted and plasticauged, along with a Conrod and piston in to check deck height and valve clearance.
checking valve clearance -
Decided to paint it a striking colour
Big thanks to Carl Robson and Sandy Brown for helping out with the conrods, also thanks Sandy for the pointers in what to measure.
Also Ed and Steve at Warners for supplying the o.e parts at very good prices.
Posted 6th Apr 2016 at 15:18
silky
Post #213
I have no idea what half that stuff is or what the readings on the gauge mean, however, it looks fantastic. Do love a nice clean painted engine. Good luck with it Mei
Posted 6th Apr 2016 at 15:31
Post #214
the readings were roughly 8mm of total valve to piston clearance!! they are stock aftermarket Omega pistons for a non Peugeot engine that are quite cheap and plentiful.
block has had a 0.1mm deck, piston sides sit about 1mm below deck and the crown comes flush with the mating surface of the head, tapered sides makes that fine however.
Posted 6th Apr 2016 at 15:38
Post #215
Totally understand you don't have the budget of some people Mei .....your updates are always interesting & you seem to get things done WELL on a shoe string....your lucky you can do most of the Engine work yourself....
sourced tells me it's not a 2.0L anymore ...spill the beans LOL
Posted 6th Apr 2016 at 15:50
Post #216
the picture of the crank will tell you its not stock Wink
Final Parts for the bottom end I think, thrust washers, had been on backorder for about 6 weeks.
Made up a bracket to hold the dial gauge (the magnetic stand is Dan's and ion his garage, didn't have it to hand)
pushed the crank, and got my end float figure
0.13 of a mm, ideal, tolerance is 0.07 to 0.32mm.
Further progress is at a halt till I make/earn more money, as the ehad needs checking over and the seats cutting
Posted 12th Apr 2016 at 15:40
Post #217
so, an update!
took the head and valves to South Wales Pistons for them to check the face and guides and cut the seats and valves.
20160515_182416 by WELSHPUG, on Flickr
20160515_182445 by WELSHPUG, on Flickr
Piper double springs
20160515_182431 by WELSHPUG, on Flickr
o.e stem seals, branded SKF.
20160518_185150 by WELSHPUG, on Flickr
pushed into place with a socket and a dab of oil.
20160518_185217 by WELSHPUG, on Flickr
fitting the springs and collets, what a faff! dab of grease helps, also not having the cam ladders gives and extra inch or so of clearance, I wrapped the head of the spring compressor in tape so the lifter bores weren't damaged.
20160518_194119 by WELSHPUG, on Flickr
Cleaned and refaced the tappets.
20160531_204018 by WELSHPUG, on Flickr
20160531_212248 by WELSHPUG, on Flickr
checked the clearance to the freshly re-fitted oil spray bars, looooads, could sling a 96mm crank in there easily.
20160522_132157 by WELSHPUG, on Flickr
fitted and torqued up the crank, fitted the windage tray oil pump and the dipstick guide.
20160526_194635 by WELSHPUG, on Flickr
new hockey stick seals for number one mains cap
20160526_093542 by WELSHPUG, on Flickr
Turned back over.
20160522_162433 by WELSHPUG, on Flickr
o.e steel gasket.
Payen Head bolts
20160522_163108 by WELSHPUG, on Flickr
then cams in and ladders sealed with wellseal, water pump and timing belt kit on.
20160604_231216 by WELSHPUG, on Flickr
doing the cam timing.
20160618_222112 by WELSHPUG, on Flickr
20160618_220408 by WELSHPUG, on Flickr
then off the stand and fit a Steel lightweight flywheel with new bolts and a new dowel.
20160530_192525 by WELSHPUG, on Flickr
Standard clutch fitted, will see how it copes with XXX amount of torque, I don't tend to abuse my cars so probably just fine! starting to look much more like an assembly, less spare bits kicking about
20160623_231258 by WELSHPUG, on Flickr
Dragged the ZX around the units and washed it off, stuck it on the lift.
20160625_172931 by WELSHPUG, on Flickr
Forkinghell this might actually happen!
20160626_004848 by WELSHPUG, on Flickr
BOOSH.
20160626_005920 by WELSHPUG, on Flickr
TRUMPETS
20160626_013230 by WELSHPUG, on Flickr
a very rare Milltek exhaust was sourced, tailpipe is rather large but thankfully only externally.
20160626_133647 by WELSHPUG, on Flickr
however the peugeot sport Group N Decat twin tube downpipe had a sleeve fit end for a magnex catback, also pretty small here at 2".
20160629_210434 by WELSHPUG, on Flickr
so I bought this
20160629_110454 by WELSHPUG, on Flickr
20160629_210447 by WELSHPUG, on Flickr
measure mark chop grind weld.
20160629_213817 by WELSHPUG, on Flickr
20160629_215406 by WELSHPUG, on Flickr
fitted with o.e single piece clamps.
20160629_220817 by WELSHPUG, on Flickr
Filled up with fluids.
fired up and running the cams in.
20160628_232045 by WELSHPUG, on Flickr
Posted 30th Jun 2016 at 16:53
blandy
Post #218
When we swapping engines lol
Posted 30th Jun 2016 at 17:09
Post #219
So as I said in months ago post ....spill the Beans Mei tell us all what you've gone & done Whistle
Posted 30th Jun 2016 at 18:32
Post #220
2187cc and newman ph4 cams Big grin
Posted 30th Jun 2016 at 18:47
Post #221
Amazing ...any head work ?....Hydralic lifters ?Crazy Thumbs up Thumbs up Thumbs up Thumbs up
Posted 30th Jun 2016 at 20:42
RetroPug
Post #222
Nice one. Smile
Posted 30th Jun 2016 at 20:47
Post #223
3 angle valve seats and valves cut to suit, wildest hydraulic profile i could find Big grin
Posted 30th Jun 2016 at 22:48
superchargedblack1997gti6
Post #224
What sort of bhp do you think Mei? Great work by the way
Posted 30th Jun 2016 at 22:53
Post #225
not sure, mid 200's maybe.
Posted 30th Jun 2016 at 23:21
