| Author | Subject: the ZX 16v thread |
Post #177
Fuel pump arrived, fitted, test driven.ERMAGHERD. B A R K ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #179
I need some mounts for my GoPro or a willing assistant ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #180
Done nothing to this since mapping but drive it and put fuel in, after replacing that fuel pump.![]() ![]() This clips into a small anti-surge cradle affair in the bottom of the tank, works very well, as long as you remember which way round it goes and to fit the pickup pipe/gauze filter! The Walbro replacement units are a lot smaller than the Bosch original unit, so had to pack out the plastic/rubber bits a bit. ![]() The supplied pickup filter wasn't any use as it was for an upright application, but the inlet is smaller than the Bosch pump so the original pickup tube didn't fit, luckily the handy bits of packaging they come with did the trick... ![]() ![]() ![]() ![]() It has been a little reluctant to start first turn but fires fine after a bit of pedal prodding and cranking, once running its no problem, I'd also noticed that part throttle cruise, i.e 5th at 70 was sometimes not as smooth as it could be, a glance at the lambda and you could see it was trying to correct it quite a bit, I recalled Sandy was not a fan of the PTFE gaskets, though I had never had any issues on the standard inlet, I did have a pair of Elring gaskets so decided to try them ![]() That's after a little clean up, I couldn't remember leaving it particularly grubby but it was, so might have been part of it maybe? Also swapped the starter motor at DCC's suggestion, not sure the starter made much difference, as I still had to prod the throttle pedal a little to get it to catch, no popping this time though, but once it did it settled to a rather low idle. ![]() and the warm idle was quite steady too. ![]() Still seems a little rich to me on part throttle, can only think it would be due to the new fuel pump though at no point during mapping was the old one struggling to keep up with demand, I think I will get a spare set of injectors serviced, another set of picos for the front set and go and see Sandy again. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
Post #181
When i had the 6 mapped, that was on standard fuel pump which it turns out was failing and could not deliver enough fuel at times. Replaced it with a Walbro 255 and took it back for mapping and the whole lot had to be done again unfortunately. |
demondriverdan
Post #182
Sounds awesome! I'm hopefully going to be getting bodies fitted in the next few weeks along with an Omex 600. Looking on the web, I'm not sure if the 600 supports plugging a wideband straight in but if not I can work around it.How does the backplate help? ________________________________________ Rallye Race Car |
Post #183
you mean the filter backplate? its something for the filter to clip to ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Post #184
You fitted your satchshift yet??? |
Post #185
nope, been too busy and I have nowhere to work on it, or a drill small enough to get anywhere near the bulkhead.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #186
a brief update, not yet got the Satchshift fitted, I haven't got any drills small enough to get anywhere near the bulkhead to make the hole, also not having access to anywhere flat or a ramp makes things very difficult.Got hold of some 205 Tarmac rear dampers, so much more chunky than the konis and the balance front to rear from a brief test drive is much improved. ![]() As the ZX seems to sit quite low and these dampers simply will not compress by hand or lever, I had to get creative in their fitting! ![]() I had also been experiencing some light vibration from the nearside rear brake under heavier braking, the discs had got particularly rusty when parked up last and seem to have glazed over and picked up some pad material in spots possibly, so Ebay to the rescue with some genuine rear discs, made sure the flanges were spotless before fitting of course. ![]() ![]() ![]() ![]() 20150523_173527 by WELSHPUG, on Flickr and lastly something to have a fiddle with tomorrow possibly, a cobbled together used bits, thermostatic takeoff, pipes and an oil cooler, pipes should hopefully be long enough this time, the old Swaged set I still have weren't quite and these are a good few inches longer. ![]() 20150524_203740_LLS by WELSHPUG, on Flickr ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Rallyewoo2
Newbie Location: Portsmouth Registered: 21 Jun 2015 Posts: 28 Status: Offline |
Post #187
welshpug! wrote: any vids of this bark mate!!!?it has a bark, a hell of a bark for a standard engine with bodies and mild cams!!! ________________________________________ Kev |
walker_texasranger
Seasoned Pro Location: Sunny Retford Registered: 26 Jan 2008 Posts: 2,502 Status: Offline |
Post #188
That vid of it on the rollers is the tits... I want one!! Though not in a Citroen ![]() ________________________________________ Almost standard 1999 Bianca RallyeHilux InvincibleX daily 306 No.13 ![]() Carp and specialist Anglers Click here |
Post #189
Amazing rear shocks !!!!Transformed mine don't know which of the two on Kam website you got both Tarmac ones group n & other A one being twice the price both have black boots Looking good Mei I take it your going to Pugfest ? |
Post #190
No I'll be in Belgium that weekend.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #191
![]() Speedline sl434 by WELSHPUG, on Flickr fancied a change of wheels.. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,597 Status: Offline |
Post #192
Had a set of those on a 205 years ago. Nice wheels. I think they suit the zx ;-) ________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
99rallye
Regular Location: Hitchin Registered: 26 Aug 2009 Posts: 348 Status: Offline |
Post #193
I don't normally like ZX but that looks the nuts |
Post #194
oh yeah, forgot to update, that Walbro unit failed too, which was a bit s**t, send it back but not heard anything, they say they've never had any fail yet, this just stopped randomly, in 3/4 of a tank of fuel.nabbed a VDO unit from a phase2 xsara and bodged it in there, did the trick, not running lean anywhere though struggles to pick up fuel when its parked on the slope behind the house. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RetroPug
Post #195
Is the plan for this to get painted eventually or is that not really a priority?________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Post #196
eventually yeah, or wrapped.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RetroPug
Post #197
I see.Really like the 3dr ZX. Haven't seen one for ages now, last ZX I saw was a ratty old diesel estate. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Post #198
welshpug! wrote: oh yeah, forgot to update, that Walbro unit failed too, which was a bit s**t, send it back but not heard anything, they say they've never had any fail yet, this just stopped randomly, in 3/4 of a tank of fuel. nabbed a VDO unit from a phase2 xsara and bodged it in there, did the trick, not running lean anywhere though struggles to pick up fuel when its parked on the slope behind the house. You better get it sorted if you plan on going to Pugfest / Precott next year ....lots of hills Nice to have something a little diff from the norm |
Post #199
its fine going that way, its sideways it doesn't like ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #200
welshpug! wrote: its fine going that way, its sideways it doesn't like ![]() Drifting's out of the question then |
