displaying posts 51 to 75 of 516
Pages (21): first .. 2 [3] 4 .. last
Author Subject: DemonDriverDan's Race Rallye Project
Post #51
sod spending £150 on brake lines inside, £10 of copper line ftw.
also sod the iridiums, standard ngh's ftw,
£50 to cut some plastic sheet to fit the doors? lol
Dont need a K&N there's £50 saved, dont need £45 oil, £25 will more than suffice.
there you go, saved you a load Big grin
leave the roller bearing bushes, get the later o.e ones, fill the voids with PU, dont need adjustable droplinks, spend the cash saved on the beam, you will need to spend more than £50 on it if its never been apart.
Posted 2nd Jun 2013 at 23:49
Post #52
More tips from the money saving expert next week folks!
Posted 2nd Jun 2013 at 23:55
demondriverdan
Post #53
Need to get a tool to bend the copper pipe but that shouldn't be too bad. Won't be happening until I get the 310mm kit anyway and that probably won't be for a while either.
Iridiums / non-Iridiums, about a £2 difference per plug :p
Was an overestimation, I agree. Piece of flocked perspex will probably end up being much cheaper.
Roller bearing bushes are part of a long term plan really. What do you mean by PU?
Beam's currently apart at home. Needs new brake lines but other than that the shafts are in good condition so waiting to get rebuilt on the car. Might need to purchase some new springs for the coilovers as I'm not sure how low the current ones will be when they're on the car.
Rallye Race Car
Posted 2nd Jun 2013 at 23:56
Post #54
demondriverdan wrote:
phillipm wrote:
Swap the rear Greenstuff for Mintex 1144's from RallyDesign.
Done, cheers Smile
Did you get my PM about the cage?
Yeah, just got back from hols, I'll PM you later.
Post #55
No
Just use the later bushes as they are.
Without serious prep the PU won't have a strong enough bond to the rubber anyway, and those voids are there to reduce the strain on the bond from the rubber>steel insert, so you might find they seperate around there too.
Posted 2nd Jun 2013 at 23:58
Post #56
Fair enough, guess it works better on the lower engine mount as it doesnt twist.
Posted 3rd Jun 2013 at 00:17
Post #57
Yeah, would be fine on engine mounts. You can do it with the wishbones, but you need 2 part poly and a primer and then have to dick about soaking them in acetone and baking in the oven. Waaaay too much work LOL:
Posted 3rd Jun 2013 at 00:33
Post #58
Agreed you need copper for inside the car, the bending tool is about £7 off eBay. Also, don't bother with RC6 pads for the front, they'll absolutely destroy your paintwork on your wheels and sides of the car.
I have Bluestuffs on mine, they're awesome pads and don't leave red-hot brake dust over everything they go near.
Posted 3rd Jun 2013 at 08:26
demondriverdan
Post #59
Put the Gaz Golds on yesterday. Was just me doing it and had to keep putting things inside while it rained randomly throughout the day! Generally went really well. Need to get some new droplinks as the old ones were shagged so still got that to do but apart from that all good. Anyway, some photos of the day:
Jacked up and ready to go
Something's missing here...
There it is! :p
Left hand side before
During
After
Wheel back on
And done. Not settled yet so still a bit high Smile
Brembos are quite close to the Dotz alloys!
Rallye Race Car
Posted 5th Nov 2017 at 18:43
Jake
Post #60
Looks awesome! Good spec too.
What series are you planning on racing in?
The 205
205 GTI6 For Sale
Off Racing!
Posted 16th Jun 2013 at 19:58
demondriverdan
Post #61
When it's done it'll be pretty good, got a fair bit to go yet. Planning an August trackday at the moment so that's my next deadline.
Planning on starting racing in Trackday Trophy then see where we go from there.
Rallye Race Car
Posted 16th Jun 2013 at 22:18
7057sam
Post #62
I remember this rallye when ian had it.nice to see it in the forum Smile
Ahhh i really need to get some g88 disk
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 16th Jun 2013 at 23:19
daver6
Post #63
Just a quick one about strut removal, I tried to swap mine over the other day but couldn't drop the hub and wishbone enough, as if I'd have to remove the arm to get enough clearance.
Any tips?
Wishbone Polybushes available
Posted 17th Jun 2013 at 08:56
Post #64
Tried a bar between the arm and subframe to lever it down?
  • Posted 17th Jun 2013 at 09:36
    demondriverdan
    Post #65
    Yea, me too. The current ones are slightly warped as I got pretty severe wheel wobble when I took it out last year. Going to leave them on for now and pick up some new ones then swap on the trackday if they're still bad.
    Any tips?
    The way I did it was to put a small jack under the balljoint to support the weight then smash the hub down with a club hammer and punch. When it go to nearly low enough I undid the top bolts and tilted / wiggled the strut out. I'm not really sure exactly what I did to get them free, lots of tilting and turning of the strut. You should be able to get the top of the strut out and push it further in to the wheel arch to get the bottom out of the hub.
    Luckily the Gazs are shorter so much easier to get back in!
    Rallye Race Car
    Posted 17th Jun 2013 at 09:37
    daver6
    Post #66
    I stopped when it looked like I wouldn't have enough room to wiggle it out.
    I tried the balljoint smashing method too, but juat couldn't seem to get the hub and bone low enough to actually get the strut out. I'll have anothrt look when I'm not so pressed for time Smile
    Posted 17th Jun 2013 at 10:09
    demondriverdan
    Post #67
    It was definitely a lot of wiggling and swearing! Although my car was 40mm lower to start with so that might have made it easier to get the strut out.
    Rallye Race Car
    Posted 17th Jun 2013 at 13:23
    Post #68
    I do the hammering process to get mine off too, std ride height. Usually try and pry the hub apart slightly round the back where the bolt nips it up before hammering as it makes life slightly easier.
    Posted 17th Jun 2013 at 18:02
    Post #69
    Small spring compressors help on std struts, means you don't have to push the hub down so far and less chance of popping a drive-shaft out clobbering things and heaving it all around.
    Posted 17th Jun 2013 at 18:10
    Post #70
    I never bother trying to remove the damper from the hub on the car, just crack off the hub nut and pull the balljoint out, far easier and quicker, less risk of damaging stuff and leakage of fluids.
    Posted 17th Jun 2013 at 18:17
    demondriverdan
    Post #71
    I had a small leak of gearbox fluid when I did the drivers side but barely anything. Topping it up a little bit before we go back out again.
    Currently thinking about droplinks. Can get a set from ECP for £40 (Lemforders) but hoping I can pick up some second hand adjustables for around the same money.
    Rallye Race Car
    Posted 17th Jun 2013 at 19:05
    daver6
    Post #72
    I'm about to buy a pair today, for a lot less than £40 though Smile
    Then I'm making some adjustable
    Posted 18th Jun 2013 at 07:56
    demondriverdan
    Post #73
    Where are you getting them from? Interested in making me a set of adjustables? LOL
    Rallye Race Car
    Posted 18th Jun 2013 at 08:08
    demondriverdan
    Post #74
    Update from the last couple of weeks. Adjustable droplinks went on the car. Quite easy to fit in the end, much nicer than the standard ones anyway! Big grin
    Lowered the front a bit while I was there:
    I also picked up a 310mm brake kit and 16" Pro Race 1.2s that are now fitted. Impressed with the performance of the 310s even without temp in them. Can't wait to get out on track again to see how they really are.
    On Sunday I took off the rear beam in to rebuild it. I had originally intended to use a spare beam I have but I had forgotten that it was a non-ABS beam so turned out to be easier to put the new TBs and ARB in the beam already on the car anyway. Didn't get that done on Sunday so hoping to have it sorted during the week. 23.5mm TBs, hybrid ARB, solid mounts, new discs, pads and braided lines all to go.
    Also finally diagnosed the issue with the fuel gauge to be the dial cluster itself so getting a replacement soon Smile
    Rallye Race Car
    Posted 23rd Jul 2013 at 12:57
    Post #75
    Can you post up a pic of the solid mounts please?
    Posted 23rd Jul 2013 at 21:42
