displaying posts 1 to 25 of 45
Author Subject: bloody speedo playing up!
my speedo is starting to play up againDry recently changed my vss sensor (was second hand) and it was all good until the shit weather came backSad im thinking my problems could be down to not having good earthing points? i seen somewhere that the main one is in the engibe bay somewhere.any ideas before i just go buy a new vss sensor or beat the car upWhistle
Posted 15th Dec 2009 at 03:20
cwspellowe
Buy a satnav Wink
You don't need a working speedo for the MOT anyway LOL
Bye bye Sundance Kid Sad
Posted 15th Dec 2009 at 15:48
chrisd306
Stick on an extra earth on the gear box to chassis as i had this problem, and since doing that its been fine, does your speedeo and rev counter just drop off then comes back?
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 15th Dec 2009 at 18:15
ant_kernow
mine does what you discribed....
team umpalumpa.
Posted 15th Dec 2009 at 21:18
chrisd306
asll i done was remove the bit where it screws/plugs in and then it didnt do it as much, then i stuck another earth on from the front of the gearbox to the slam panel, and has been fine since, i used a earth cable from a amp wiring kit, all been good since
& Audi Q5 S Line
Posted 15th Dec 2009 at 21:36
Im goin to have to try this then gettin fed up of it dying and jerking like a wild buck
Posted 16th Dec 2009 at 01:15
maz-306-xs
mine does it too only on a few select roads though. quite funny i think
banned for drifting. back in the s**tbox scene.
Posted 16th Dec 2009 at 01:22
ice-306
having the same drama will try the above
ice
Posted 16th Dec 2009 at 02:55
pete_rallye
The speedo on the dash is wired directly to the vss. There is only 3 wires, a 12v live, an earth and a 'switch' live which is the wire that goes to the dash. It does also split and go to the ecu but don't worry about that, doesn't affect the dash.
Get a multimeter and test you have a good 12v supply, then test the earth. If they are ok its likely to be the vss, the wire to the dash or the dash itself. To test the vss you really need an oscilloscope. The wire goes into the blue plug I think on the back of the dash so you can test continuity of the wire there. Dunno how you'd test the dash though.
Lap of the 'ring
Posted 16th Dec 2009 at 03:09
jammamayhew Banned!
seems quite common and mine does this. Sometimes its fine. Sometimes i start her up and it constantly reads 0mph. Then after a while it Will kick in.
JAMMA "M44YHW" MAYHEW
LOSE WEIGHT NOW - ASK ME HOW -
NUTRI-FIX
GTi6 LPG, The best of both worlds!
2006: 1997 R reg 306 1.4 Miami - Diablo Red - DEAD
2007: 1999 V reg 306 1.4 Meridian - Diablo Red - SOLD
2007-09: 1998 S reg 306 GTi6 - Diablo Red - DEAD
2009-10: 1998 R reg Corsa 1.2 - Blue - SOLD
2010-13: 2001 Y reg 306 GTi6 LPG - Diablo Red - DEAD
2013 - 2013: 2000 X reg GTi6 LPG - Moonstone Blue - DEAD
2013 - current: 2001 X reg GTi6 LPG - Diablo Red
]FOR SALE[/b]
"I LIVE FOR THE 306"
Posted 24th Mar 2013 at 08:02
Laugh my ass off . 4 year bump, have you had a bump to the head jamma?!
Posted 24th Mar 2013 at 08:18
jammamayhew Banned!
just useful info bump
NUTRI-FIX
]FOR SALE[/b]
Posted 24th Mar 2013 at 08:49
So your car is a neglected s**tter too then? LOL All you need is a new vss
Posted 24th Mar 2013 at 08:51
jammamayhew Banned!
it was fine until the dash was changed to my led metal monkey one. So thinking it could be something to do with dash or earth?
NUTRI-FIX
]FOR SALE[/b]
Posted 24th Mar 2013 at 08:58
Hope it works when you take it for an MoT
  • Posted 24th Mar 2013 at 09:01
    jammamayhew Banned!
    over 10 months till Mot is due. How much is a VSS out of interest?
    NUTRI-FIX
    ]FOR SALE[/b]
    Posted 24th Mar 2013 at 09:07
    Niall
    about £45
    Posted 24th Mar 2013 at 09:26
    Yep, as said it's likely to either be the VSS itself or the lack of an Earth connection. Yes
    You shouldn't need to add extra Earth cables really, just ensure the current ones are present and the connection points are clean and tight. Yes
    Posted 24th Mar 2013 at 09:49
    6waysforward
    My speedo randomly drops off for a min or so then comes back. I have a new vss sitting here but its to dam cold out to fit it LOL
    Posted 24th Mar 2013 at 21:47
    beez_neez_gt
    Would the VSS be the cause for my speedo to zip straight to almost max speed just after start up, it goes back down after a mo ?
    Pug fee`ver,
    Pick a Bogey, buy a Pug.
    Posted 25th Mar 2013 at 13:30
    why would VSS matter for mot? LOL
    and you can get them for about £10 from a motor factors
    rikky wrote:
    I have another here actually as I never fitted mine to the HDI. it's a MEYLE one and their part no is 40-148990000 and is for oem part no 616070
    from another thread
    Posted 25th Mar 2013 at 13:35
    Speedo. They check it's operational as part of the test now don't they?
  • Posted 25th Mar 2013 at 13:39
    I'm not sure, do they? How? I suppose the only way would be to run the vehicle in the brake rollers and ensure that the speed starts to raise.
    Posted 25th Mar 2013 at 13:43
    wasn't aware of that as it'd involve mot testers driving the car..
    we only run cars stationary for emissions / testing exhaust and brake testing but that's it
    Posted 25th Mar 2013 at 13:44
    Perhaps when they jack the car up on the subframe to give things a shake and a wiggle they will run the car in the air to see if it moves?
    Or look down at the dash when they drive the car on to the ramp.
  • Posted 25th Mar 2013 at 13:47
