displaying posts 1 to 25 of 81
Pages (4): [1] 2 3 .. last
Author Subject: 406 Brembos and Xantia Disc help
ashlez
Where is everyone getting their Xantia V6 discs from for the 406 V6 brembo conversion and what size?
I bought a set of Xantia V6 disks from buypartsby.co.uk - they are 283MM. Unfortunately they dont fit properly and are heavily offset to the right hand side of the caliper (see pic)
Any help greatly appreciated.
Thanks
ashlez has attached the following image:
Posted 15th Oct 2009 at 01:38
ian7675
Techno Viking
Have you tried the search button? Loads and loads of info on this subject!
Welcome by the way. How about an intro about yourself and your car in the General section. Always appreciated by everyone. Whistle
Less than 24 hours to go!
Posted 15th Oct 2009 at 01:43
You want the 288mm Xantia V6 discs, I made the same cockup when ordering Daveyboy's discs
I've got a spare pair of high-quality ductile iron ones though, 'cause I ordered a couple spare, they're blanks but only need the surface grinding parallel to finish them - I can have that done if you want 'em.
Posted 15th Oct 2009 at 01:42
ashlez
Well i didnt think it would be wise to introduce my car as its a saxo VTS Sad
Posted 15th Oct 2009 at 02:04
ashlez
Is this different for the Saxo VTS or the same? Im trying to get discs that fit and dont squeal.
Take a quick read of this thread.
http://www.saxperience.com/forum/showthread.php?t=97318
I ordered the ones from the first post in that thread but they are not right. The ones suggested in the first post of that thread are apparantly what was suggested for use on here and they were 283MM.
Thanks again for any help. I know this is a 306 forum but i imagine they are similar and lots of people may have had experience with this over here.
Posted 15th Oct 2009 at 02:07
pugheaven
they still squeal with the 288 discs.
Posted 15th Oct 2009 at 02:15
steve_l_gti6
yeh tell me about it, its driving me nuts. How do you get rid of it?
Posted 15th Oct 2009 at 03:21
Backing shims on the pads, lightly grooved/2 piece/wavy discs, chamfer pads, damped sliders...
Posted 15th Oct 2009 at 03:25
pugheaven
or buy the renault brembos with ashs 310 kit thats what i did, couldnt stand the noise Big grin
Posted 15th Oct 2009 at 03:42
ashlez
Backing shims as in the anti-squeal shims you can buy?
damped sliders? What exactly do you mean by this?
Thanks
Yes, anti-squeal shims, damping the sliders involves coating the sliding areas the pads run on with a special compound, probably a bit beyond most people tbh LOL
Posted 15th Oct 2009 at 03:57
lukejenks101
I got some kent pad silencer, it worked on mine for about an hour, but it worked on cosmic spanners for a long time, f*ck knows what im doing wrong Laugh
PS3 I.D - jenkers101
Live i.d - Lukejenks1201
Posted 15th Oct 2009 at 04:02
Everything! Razz
Posted 15th Oct 2009 at 04:04
lukejenks101
I put it on, heat it up as it says on the tin, leave it to cool, put them back in then it all comes off on my discs Laugh my ass off
Posted 15th Oct 2009 at 04:06
Laugh my ass off
/hugs his completely silent wavy discs, even with 1144's, LOL
Posted 15th Oct 2009 at 04:08
lukejenks101
phillipm wrote:
Laugh my ass off
I might just put it on then leave the pads in the oven for a few hours, then it will definately be heated enough Big grin LOL
Posted 15th Oct 2009 at 04:10
Might work actually, give the stuff more time to diffuse into the pads.
Posted 15th Oct 2009 at 04:11
lukejenks101
I was using a blow torch on the back of the pad to heat it, then let it cool overnight ffs LOL
Im probably just putting it on a bit too thick
Posted 15th Oct 2009 at 04:13
rallyestyle
My AP's squeal when running normally, they stop squealing when braking hard though, annoying as braking hard would result in the passenger banging their head and the car being shunted up the rear Doh
Just Drive It
Posted 15th Oct 2009 at 14:43
bellcp306td
I have the 406 Brembos on my 306, I have done all things under the sun to stop them making noise. Just get Renault Brembos with ashs 310 kit. For the xantia discs you need to get some metal skimed from the lugs on the calipers to make it sit centrel but they still squeel!!!! and your left with some calipers that are not any use to anyone.
Where did the road go!
Posted 15th Oct 2009 at 15:22
can always shim them back up or take some material off the inside of the brake bell.
Posted 15th Oct 2009 at 15:34
bellcp306td
I was more thinking of selling them to a 406 owner but yes to the disk bells, one down point to the bell idea your playing with the offset and the disc might not have that much metal, you might make the bells to thin.
Posted 15th Oct 2009 at 15:46
nope, there's enough metal there to take what you need off, its what Hilgie the Dutchman did for his 205 V6, the 205 hubs are the same offset as a 306 Wink
Posted 15th Oct 2009 at 16:13
bellcp306td
Cool, I've never done it just gave up. Going for clio 192 Brembos. If that fails I will just put the '6' ones back on. Sad
Posted 15th Oct 2009 at 16:35
lotek
Ditch the f*ckers there soo much hastle its not f*cking worth it , just get some decent pads on standard brakes, ive just about had enough of the f*ckers and i havent even got mine on yet....
can get wheels or the bloody 100mm pipes its driving me MAD!!!! ...... Rant over .. apologies
Posted 15th Oct 2009 at 17:05
