Whats going on with the pipes?
Where did the road go!Chris
| Author | Subject: 406 Brembos and Xantia Disc help |
bellcp306td
Regular Location: Bedlington Registered: 10 Aug 2009 Posts: 166 Status: Offline |
lotekWhats going on with the pipes? ________________________________________ Where did the road go!Chris |
lotek
Seasoned Pro Location: Berkshire Registered: 04 Dec 2007 Posts: 6,107 Status: Offline |
i need those 100mm l bend pipes so i can use my existing braided brake hoses. |
bellcp306td
ok sorry can't help, I just got new Braded lines made.________________________________________ Where did the road go!Chris |
[l\'e$kro]
Newbie Location: cork City Registered: 16 Feb 2009 Posts: 40 Status: Offline |
I suggest you use a set of 283x26 discs from a gti-6 or a 307 Hdi, they are centered with the calipers and won't squeal as much as the Xantia 288x28 ones which have the wrong ofsetNicolas ________________________________________ 205 gti xu10j4rsms2 extra sequential |
rallyestyle
Seasoned Pro Location: London Registered: 23 Jul 2003 Posts: 14,991 Status: Offline |
lotek wrote: i need those 100mm l bend pipes so i can use my existing braided brake hoses. I have some mate ![]() They are used but you can have them PM me if you want me to get them over to you ![]() ________________________________________ Just Drive It |
lotek
[l\'e$kro] wrote: I suggest you use a set of 283x26 discs from a gti-6 or a 307 Hdi, they are centered with the calipers and won't squeal as much as the Xantia 288x28 ones which have the wrong ofset Nicolas so i can just use my existing discs?? wont they be too small for the pad?? |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Not sure but iirc if using standard discs the pistons can reach maximum travel and maybe pop out if your pads are low. Think the 406 brembos require 28mm width discs as min. Not 100% sure |
lotek
ok xantia ones it is then cheers. will get some cheap jobbies and spend some more on pads.cheers |
pugheaven
you will never get rid of the noise unless you go to 330mm bell and rotors!I couldnt stand the noise so i sold my set and got ash's 310mm kit with 225 brembos. no noise and much better calipers. |
Post #35
don't have to have 330mm, could go for a stock diameter 305mm belled disc and rotor.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugheaven
Post #36
^True. I only said 330 as thats what ash's kits used. |
bellcp306td
Post #37
There is no noise free solution that i know of. i used to run them with a 307 110 Hdi disk. They are better then the 6 brakes but not much better. ________________________________________ Where did the road go!Chris |
anderoo
Seasoned Pro Location: Castle Cary Registered: 05 Oct 2004 Posts: 9,222 Status: Offline |
Post #38
lotek wrote: i need those 100mm l bend pipes so i can use my existing braided brake hoses. Carl (mech_repairs) can make these up for you. ![]() ________________________________________ Pics of my 6My 6 on Google Video thanks to coxy306Xsi |
Post #39
phillipm wrote: Backing shims on the pads, lightly grooved/2 piece/wavy discs, chamfer pads, damped sliders... Stop teasing me you bas**rd, I want them now! ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #40
![]() So do I! I'm getting bored with no milling machine to play with ![]() ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Post #41
Can't you make them with a file and a drill? Like a propper engineer could ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #42
tyerz
Regular Location: newark Registered: 23 Dec 2008 Posts: 342 Status: Offline |
Post #43
jus a thought on this one cuz im planning on fitting brembos but now not so sure but would a 406 V6 coupe hub conversion not be an do-able and sort the problem out?? |
anderoo
Post #44
If it is I'm not sure it'd sort it out anyway, They still squeal on the 406's and the Fiat Coupe's they were fitted to as standard.________________________________________ Pics of my 6My 6 on Google Video thanks to coxy306Xsi |
tyerz
Post #45
ahh right, hmmmmm not sure if to put em on or not now |
vts_gav
Regular Location: Redcar Registered: 12 Jun 2009 Posts: 367 Status: Offline |
Post #46
latter xsara vts's use the 26nn thick discs ideal for brembo calipers |
lotek
Post #47
im still trying to figure out what discs we can use for the brembos other than the xantia onesgti6 discs sit offset, gti 180 discs fit ok? 406 coupe discs wrong offset? xsara hdi estate 2001 , Seem ideal? 283x26 307 lx 283x23 usable? what other cars discs are an option? the xantias are OVERLY heavy. why cant the 406 coupe discs be used? |
Post #48
The late Xsara disc could be a good option. Someone else has mentioned them on here before and yes the Xantia ones do seem pretty heavy, however not a million miles off the normal GTi6 discs.Was going to weigh everything when I changed over. ________________________________________ Nothing to see here |
Post #49
following this with a little interest, I'm still on 266x20.5mm ![]() my discs apparently weigh 4.7 kg, the gti6 283 x 22mm disc is 5.95kg, the C5 discs commonly used is the same as the Late Xsara discs, 6.74kg. 283 x 26, 34mm height. one thing I can't remember about the 405/6 hub is whether the radius of the lugs are the same as the other cars (106/205/206/309/306/307) what I do know is that the offset to the hub is a lot lower hence why its not possible to use the discs on a 306 (and why BBS made the special Coupe wheels) a 406 V6 disc is; 305 x 28mm, 28mm height, 7.9 KG ![]() if the caliper sits at the same radius, a 307 2.0 HDI 135 disc looks to be exactly the right spec to fit; 302 x 26 - 34.1mm height (same height as the C5 discs, but a lot larger diameter, this may help against squeal.) they weigh 8.42 kg though ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #50
How much do the Xantia ones weigh?And what height/size etc are they? ________________________________________ Nothing to see here |
