displaying posts 51 to 75 of 81
Pages (4): first .. 2 [3] 4
Author Subject: 406 Brembos and Xantia Disc help
Post #51
correction, I think most people use a 288mm C5 disc, that is 28mm thick and 34.2mm height.
that's the same as a Xantia 110 HDI estate, 7.98 kilos.
they seem ideal bar being 7mm smaller diameter, so 3.5mm less for the pads to grab onto.
Posted 12th Dec 2009 at 23:47
Post #52
Same disc as the V6 Xantia?
Post #53
yup Thumbs up
Xantia V6 uses a normal Bosch caliper like the 110 hdi.
not from memory, or servicebox LOL I found the Textar online catalogue, same catalogue as Mintex Ferodo and Bosch amongst a few by the looks of it
Posted 12th Dec 2009 at 23:54
Post #54
I'm going to weigh everything before I swap them anyway. Need to get new hoses, fluid, some spacers and the new seal before I fit them. Probably going to paint them as well as they look a bit used.
Posted 12th Dec 2009 at 23:58
Post #55
cool, I'd like to know how much the caliper itself weighs Smile
Posted 13th Dec 2009 at 00:00
Post #56
Not much for the size of it! Will do - with or without pads?
Posted 13th Dec 2009 at 00:05
Post #57
just the weight of the pads would do, found the weight of the caliper on the 205 forum as there's a topic documenting weights of various bits Smile
quote:
406 Coupe V6 Brembo 4-pot calipers:
3750 grams per caliper
Posted 13th Dec 2009 at 00:16
lotek
Post #58
the caliper weighs sod all Yes especially in comparason to the sandard item.
also i found something very interesting.
i looked at some discs from a 307 lx and from memory they were 283?x 23.. BUT.......
they had those coin shape cut outs that phillipm was mentioning about to reduce/shift harmonic waves...... I.E stop squeeling.......
Posted 13th Dec 2009 at 00:20
Post #59
23mm isn't wide enough though is it? What make?
Posted 13th Dec 2009 at 00:24
Post #60
Welly's willwood caliper setup Complete with pads and bracket, 2.5 Kilos.
Posted 13th Dec 2009 at 00:37
lotek
Post #61
im not sure what make they are adam, i presume standard pug fitment, but its the first time ive seen those slots on discs.
23mm maybie a bit small, im not sure who would know for cetain either..
Posted 13th Dec 2009 at 00:43
Post #62
most likely a 22mm disc, or an extremely worn 26mm one.
sounds like an ATE Powerdisc.
Posted 13th Dec 2009 at 00:58
lotek
Post #63
it would be interesting to see if any other pug discs have those cutouts ,
im certain, there is a combination to be had that doesent squeel other than bells and rotors. Yes
Posted 13th Dec 2009 at 00:56
lotek
Post #64
ford discs?
Post #65
they squeeel often enough on a 406 with 406 discs....
Posted 13th Dec 2009 at 00:59
Post #66
Not, not like that Mei - a half circular cutout in the vents and halfway into the disc faces either side, helps shift the harmonic frequency.
Imagine a keyseat cutter pushed sideways into the vents of the disc.
Posted 13th Dec 2009 at 01:27
Post #67
ahh right, hmmmm.
Posted 13th Dec 2009 at 01:34
Post #68
That's it, upset him LOL
Posted 13th Dec 2009 at 01:40
Post #69
The forum will be broken until christmas now Doh
I would have gone for the Willwoods, but they're too much dough. I know what you mean Phil on the cutouts multiple crescent shaped. Come standard on a few cars, but none I can remember right now!
Lotek - they don't squeal at all on Dan_s16s car with DS2500s and Tarox G88 discs. I'm not actually that fussed about squeal, until the summer when the windows have to be open.
Posted 13th Dec 2009 at 02:44
Post #70
Unsure
Posted 13th Dec 2009 at 02:55
Post #71
LOL
I meant Adam...they're lighter than his Razz
Posted 13th Dec 2009 at 05:10
lotek
Post #72
i want to find a cure as il be going back to brembos onc my beam ect is sorted. Thumbs up
Posted 13th Dec 2009 at 08:48
Post #73
I just weighed a gti6 caliper and yoke minus pads on my highly accurate Ikea bathroom scales and got 6 kilos.
so 2.25 kilos less on the caliper, but 2kg's heavier on the disc Doh
Posted 13th Dec 2009 at 17:29
Post #74
Seriously?! Fook me they are heavy!!
Posted 13th Dec 2009 at 21:28
rallyestyle
Post #75
But far better braking Unsure
Just Drive It
Posted 14th Dec 2009 at 21:07
