displaying posts 76 to 81 of 81
Pages (4): first .. 2 3 [4]
Author Subject: 406 Brembos and Xantia Disc help
Post #76
these fit behind the Speedline BTCC 15x7 wheel (1508 IIRC) WITHOUT a spacer, though due to the minimal clearance I'd run a 3mm or so spacer LOL
I'm not certain that the outright braking performance will be any more as the actual piston surface area and pad surface area is pretty close between them, however they should deal with heat a lot better so will give more consistent braking.
Posted 15th Dec 2009 at 04:30
Post #77
It's the much lower caliper + pad flex that gives you the better brakes.
Posted 15th Dec 2009 at 04:32
Post #78
ahhhhh Thumbs up
Posted 15th Dec 2009 at 04:36
Post #79
Keeps the clamping force squarer to the disc, and the heat level more consistant across the pad
Posted 15th Dec 2009 at 04:44
Post #80
Lucky you...
Posted 15th Dec 2009 at 04:55
Post #81
They didn't fit over Dan's so it was the disc that made the difference. Piece of paper close though - I couldn't repaint them thats for sure.
Posted 15th Dec 2009 at 12:52
