displaying posts 401 to 425 of 563
Pages (23): first .. 16 [17] 18 .. last
Author Subject: Wilwood brakes
SteviePut
Post #401
smegal wrote:
By spigot do you mean on the locating but on the spacer?
Yes
Posted 19th Jan 2009 at 03:18
j205
Post #402
I've managed to get my calipers ordered today after a bit of a mess around with rally design. The only problem now is that they haven't got the calipers in stock and are waiting for a shipment to come in so i now have to wait for about 4 weeks Dry . I will get these brakes fitted at some point!
Posted 19th Jan 2009 at 17:24
SteviePut
Post #403
Well it turns out that the spigot rings internal diameter was too small and was fowling on the hub nuts "R" clip. Which meant the spacer wasn't seating straight.
I've had the ring turned out a little so it fits properly. But they are still brokenSad It makes putting the wheel on a pain in the arse!!
Also, one of the wheels is bent! It's had a bit of a knock on the inside edge. I'm going to attempt to give it a bash with a nylon mallet sometime this week then get the wheels balanced.
I bled the brakes again this afternoon and they're getting there. Still not quite 100% but almostSmile It's so easy to get the ABS kicking in now.
And finally, off topic, my car has decided that it wants to run at 90ish degrees instead of its normal 80ish (10 degrees higher). There's no pressure in rad and plenty of water in it. I'm thinking either the gauge is fubared or the sender is, as the fans (which work of a different sensor) kick in 10degrees higher (by gauge) than before also. I'll find out in a bit as I'm off to Pug or GSF for a new senderSmile
Posted 19th Jan 2009 at 21:24
matsoki
Post #404
Which colour sender are you after?
Built on 25th November 1998... That was a Wednesday..... Thank God it wasn't a Friday!
RIP - Pete Sims
Posted 19th Jan 2009 at 23:39
SteviePut
Post #405
Blue one is the gauge mate. Thanks for the offer mate (I'm guessing hereLOL) but I've ordered one from Pug for the sum of
Posted 20th Jan 2009 at 00:28
SteviePut
Post #406
Got those pictures for you Paul. They fitted perfectly and do not protrude from the arches. Obviously they stick out a little further than normal (10mm to be precise) but I'm not complaining.
Only problems were brake hoses. Passengers side had been butchered by some one before so my brake spanner was just rounding it off even further. Nothing a pair of mole grips didn't sort. Can't really blame you for that thoLaugh my ass off
Oh and I've finally got all the air out of them. They're pretty god dam good, but they do squeal when they're hot.
Posted 22nd Jan 2009 at 00:08
Welly Forum Admin
Post #407
Cool, they looks spot on. Doesn't even look like they have spacers tbh.
What friction you running?
Vrs power!!
Posted 22nd Jan 2009 at 04:08
SteviePut
Post #408
The smart pad. They seem pretty good so far. There's a definite step up in friction once they're warm. I've not got them to fade yet so all is good LOL Trouble is in this weather it's difficult to really push them hard. I've got a run over to Weston this weekend so I'm sure there'll be an opportunity somewhereSmile
Posted 22nd Jan 2009 at 15:31
russbez
Post #409
does indeed look rather smart on standard wheels Yes
fitting new pads to my brembos, some squeeking fun to be had no doubt
My Rallye project thread
Posted 22nd Jan 2009 at 18:11
Welly Forum Admin
Post #410
Can't fault it.
I'm really plead all the hard work has paid off. Wonder if that squeek will pass? Mine never made a sound.
Vrs power!!
Posted 23rd Jan 2009 at 01:50
psjunkie
Post #411
mine have been squeeling dont seem to be giving up either, maybe try some different pads or just put up with it
1997 P1 Gti 6 Charged
Posted 23rd Jan 2009 at 03:06
SteviePut
Post #412
Have you put copper grease or the rear of the pads? I haven't. Mabe that's the answer??Dunno
Mine only squeal when you brake lightly when they're hot so I can live with it. Brass brakes are the way forward!!Laugh my ass off
Posted 23rd Jan 2009 at 13:41
psjunkie
Post #413
no didnt put copper grease behind the pads, im going to try that though, mine only do it when hot and braking lightly too,
Posted 24th Jan 2009 at 03:54
SteviePut
Post #414
Same hereSmile Think I can live with it TBH
Posted 27th Jan 2009 at 04:02
psjunkie
Post #415
yeah i think its funny driving our lass mad though
Posted 28th Jan 2009 at 00:04
teggs
Post #416
i'm really tempted to go with this.
are people enjoying there new wilwood set up?
Team 307 HDi!!
Posted 29th Jan 2009 at 03:01
psjunkie
Post #417
they are awsome upto the std setup, braking power seems so progressive and controllable, a* from me dooooooeeeeetttt
Posted 29th Jan 2009 at 03:34
teggs
Post #418
Any tips on convincing the wife?! lol
Team 307 HDi!!
Posted 29th Jan 2009 at 17:38
Post #419
The brake calipers have failed, I'm going to crash unless I get some new ones, sorry luv....
Posted 29th Jan 2009 at 19:15
sacko_gti6
Post #420
Tell her to get to get on her bike. A man needs a set of these in his life?
Build Date - 30 September 1997 - Tuesday's car..is full of pace? Wink
Posted 29th Jan 2009 at 19:17
russbez
Post #421
+1
LOL
Posted 29th Jan 2009 at 19:31
SteviePut
Post #422
I've come from standard callipers and standard pads and they seem quite a big step up in braking power. If you read back through the thread there's 20 odd per cent more pressure available on the pads. It certainly feels soSmile
Once Fletch has his car up and running properly we're going to have a comparison between his standard callipers/DS2500's and mine. Best Mine are better!! Laugh my ass off
Posted 30th Jan 2009 at 01:13
Welly Forum Admin
Post #423
Ditto on the progressive part.
I only did a few high speed HARD brake tests on mine, but i kid you not it was like throwing an anchor out the boot and the front just nose dived and shrugged the speed off in no time at all. Just need a G suit LOL
Seriously, I'm gunna let the other guys do the talking as they are the ones that have them and use them Thumbs up
Vrs power!!
Posted 30th Jan 2009 at 04:55
bininoz
Post #424
i was using tarox g88 discs on the front and standard rear discs with ferodo ds2500 all round and have to say the braking was alot better than standard.
When i get back on the road will be phillipm's wavy discs on the back with ferodo ds2500's and th wilwoods on the front with the smart pads. Will be interesting to see the difference.
Have a braking distance from 70mph marked out on a road near me for reference.
Team High Boost Supercharged Gti-6™
Posted 30th Jan 2009 at 07:25
Welly Forum Admin
Post #425
I had one of them, except mine was 100Shock Whistle
Unerving as it was closly followed by a easy left LOL (pace notes ahoy)
Vrs power!!
Posted 31st Jan 2009 at 07:01
