BLACK RALLYE - phoenixWHITE RALLYE - valliant
| Author | Subject: Clutch fork bushes |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Hi gents one for in the trade guys how much are clutch fork bushes usually pug ones and aftermarket and is there much difference in quality cheers ![]() ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
never bought aby aftermarket, only o.e.m and got a bag of them.never seen a reliable well priced aftermarket source ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mocinim
How much is a bag ???________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
depends how much of a discount your parts man gives you ![]() they come in 5s from the warehouse iirc, but thei will split the pack usually. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
silky
Seasoned Pro Location: Chelmsford, Essex Registered: 29 Dec 2002 Posts: 3,471 Status: Offline |
mocinim
Will check the part number and get back to you cheers bud EDIT : WRONG PART NUMBER BUD TOP IS 2175 21 BOTTOM IS 2175 20 BUT THANKS ANYWAY BUD ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
We have a transmission section for transmission related quiries |
GTi6-PJL
Regular Location: South Essex Registered: 30 Sep 2013 Posts: 144 Status: Offline |
mocinim - I'll have a look through my receipts tonight as I had to buy some new ones last year ![]() ________________________________________ 2000 W Phase 3 Moonstone. |
mocinim
roland rat wrote: We have a transmission section for transmission related quiries ![]() Agreed good sir was originally just after a general price detail Perhaps you could enquire as to weather your good frinds in the admin department could arrange a location alteration due to the unexpected longevity of this now growing thread ?thanks muchley ? ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
GTi6-PJL
Right, just had a look at my invoice from last year and found the following:2175 54 - Fork Bearing £2.11 2175 55 - Fork Bearing £1.73 2175 56 - Protector £1.23 I've just confirmed these part numbers on ServiceBox too. Hope this helps! ________________________________________ 2000 W Phase 3 Moonstone. |
mocinim
GTi6-PJL wrote: Right, just had a look at my invoice from last year and found the following: 2175 54 - Fork Bearing £2.11 2175 55 - Fork Bearing £1.73 2175 56 - Protector £1.23 I've just confirmed these part numbers on ServiceBox too. Hope this helps! Cheers bud thats quite interesting is yours ph3 not that it should matter and did they fit well The numbers i put in above where supplied by my local peugeot garage and are referenced from my number plate going to have to investigate further cheers chap ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
GTi6-PJL
I didn't fit the clutch myself but I didn't have any complaints about that (they did complain about my Miles gear linkages not fitting so they had to order some OE ones in, but that's a different story!) The part numbers you posted appear to be correct too, as they're listed for "until RPO 08484", which being a phase 2 would probably be right - mine is a phase 3. There's no other part number for the fork lever itself, so I can't imagine there would be any issues however YMMV. ________________________________________ 2000 W Phase 3 Moonstone. |
those yellow bushes are only for J stamped push clutch forks pre april 1993, the length of the fork fingers is different and the bushes are offset to account for it.the later bushes are white, the late phase 3 type retrofit to the earlier white bush shafts fine, they have an extended collar for the rubber seal. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
mocinim wrote: roland rat wrote: We have a transmission section for transmission related quiries ![]() Agreed good sir was originally just after a general price detail Perhaps you could enquire as to weather your good frinds in the admin department could arrange a location alteration due to the unexpected longevity of this now growing thread ?thanks muchley ? You only need to ask, or to be fair start the thread in the right place in the first place! Anyway, moved! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
mocinim
jeffers wrote: mocinim wrote: roland rat wrote: We have a transmission section for transmission related quiries ![]() Agreed good sir was originally just after a general price detail Perhaps you could enquire as to weather your good frinds in the admin department could arrange a location alteration due to the unexpected longevity of this now growing thread ?thanks muchley ? You only need to ask, or to be fair start the thread in the right place in the first place! Anyway, moved! Cheers captain ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
Any one know the part number for the clutch fork kit or just the clutch fork cheers ![]() ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
2115 25 ??????________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
check the link in your own signature ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mocinim
welshpug! wrote: check the link in your own signature ![]() Was going to but i keep getting locked out and have to make a new account Its a pain in the arse Plus i like to attempt to keep this forum busy Most required detail can be found on here but if we all just came to read there would be very little chitty chat But cheers anyway got this part number from one of your old posts cheers WP ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
you dont want 2115 25, that's a push clutch fork, you need 2115 27.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mocinim
Cheers bud ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
