Interested in peoples perspectives on my dilemma....
To re-shell or fix it?
Quite simply my car looks great from the outside (well good enough for a track car) however at 162k the bottom end is getting quite noisy, clutch and cambelt need doing too....on top of this, sadly mine is pretty rusty (front edges of the chassis rails, small hole in the one rail running across the back of the front arch and both front jacking points flattened...)
Oh and to top it all off, when i had the AD08's fitted the tyre bloke took my advice to avoid the jacking point.....and used the f'ing floor pan and split it from the bulk head under the accelerator pedal
Now its got loads of nice bits on it - all brand new.....B8's, Satchshift, RichW Wishbones, BakerBM Mounts, Oil cooler, Hi-Spec Billet 400's etc etc
I'm massively attached to it.....so what would you do?
1) Strip it, source a better standard Rallye and fit all the bits again
2) Try and just buy a shell and re-shell it
3) Sell it as a project and start again?
(Options 1 & 2 are a right pain as i have 2 kids, no time, and cant spend thousands getting holes cut etc etc for the Satchshift etc)
Appreciate your thoughts
Chr1sch
Liquid Yellow paint and the Recaros I'd be considering in selling it!
