displaying posts 26 to 50 of 56
Pages (3): 1 [2] 3
Author Subject: Help !
quite unlikely the welding caused anything
Well just spoke to Alex at DTA & he said DTA will be fine Mei ...
Something blew a 5amp fuse & has lost my Mileage & Rev counter Mei ...
I'd love to think coincidence....& I'd be happy ....
It's my fault for on/off battery isolation Whistle
You live & learn more by your costly mistakes you never forget ...life lessons ...hope the new clocks sort it Wink
Posted 19th Feb 2016 at 11:02
cully
you have lost mileage
i suspect the clocks are bust
my reasoning in this is the mileage is set in a chip and is rewritten electrically, i suspect the clocks have been fried with a welding voltage surge
Posted 19th Feb 2016 at 11:19
Paul your 100% correct m8 ...Thumbs up
Picked up 2nd hand phase 3 clocks for my phase 2.5 tonight & also tried them all on another car before I fitted then to mine to make sure that they all worked before I put them on mine, everything is working on mine now apart from rev counter and still can't check speedo until tomorrow.
But since yesterday and today I'm getting extra stuff working each time but tonight's episode of changing the clocks for second hand phase 3s is the best result so far.
Thanks for everybody's help, this is why I love this forum so much!
P.S. Any chance of a wiring diagram for drivers side and passenger side door looms please?
I'm trying to take out most of the wires I don't need apart from electric Windows
Posted 19th Feb 2016 at 16:59
cully
Posted 19th Feb 2016 at 17:47
cully
those drawings are for a ph3 doors
there is also the engine loom layout
Posted 19th Feb 2016 at 17:50
Fantastic Thumbs up
Posted 19th Feb 2016 at 18:12
OMFG !!!!!!
Guess what my Mechanic friend / Martin just discovered Crazy
Looks normal ????
Posted 20th Feb 2016 at 15:54
Not when he opened it up !!!!
The only reason He found it was he was getting 2.9volts where 12v should be & hey bloody presto Shock
Posted 20th Feb 2016 at 15:56
Post #35
Need a new'un?
  • Posted 20th Feb 2016 at 16:00
    Post #36
    Need a new'un? Got some here
    Post #37
    Wizard Magic Martin to the rescue!
    Posted 20th Feb 2016 at 16:09
    Post #38
    dangti6 wrote:
    Need a new'un?
    Thank you Dan Thumbs up
    My Machanic m8 has a few ....we are just driving to his now to open a few up & check them first & back to mine ...
    Posted 20th Feb 2016 at 16:18
    Post #39
    Ash .....this nearly beat even Martin !!!!
    He's never seen one go like that .
    He a clever bugger & wouldn't give in .
    You've met him so I'm sure you could see he's a switched on bloke with Peougets & has been in the game nearly 30yrs Crazy
    This may help others with similar problems?
    Haven't seen anything on here about Fuse box corrosion Razz
    Can I just say a big thank you to those of you that had many suggestions Thumbs up
    We did try them all & more 5-6 times over LOL
    Posted 20th Feb 2016 at 16:25
    Post #40
    so nowt to do with the welding, just a bit of corrosion caused by damp!
    main reason I was particularly sceptical about damage caused to circuits when welding is that theres not much at all live wgen the ignition is off, which is a physical switch, as well as the fuses and relays.
    Posted 20th Feb 2016 at 16:54
    Cjwatson27
    Post #41
    What about tracking back up the ground (earth) take it the ignition doesn't switch the earth ?
    Posted 20th Feb 2016 at 16:59
    Post #42
    Yeah Martin seems to know his shizz!
    Maybe worth fitting a heater if the fuse box is damp?
    Posted 20th Feb 2016 at 18:24
    Post #43
    , you need a complete curcuit for any current to flow....
    Posted 20th Feb 2016 at 18:45
    Post #44
    on the topic of mileage, can the chip be bodged or anything done to up the mileage? i want my new clocks upping by about 10k. i was tempted to try sending power to each of the various speedo plug wires and see what happens, but i suspect that would take a long time
    Posted 20th Feb 2016 at 19:16
    Post #45
    Nope nothing Mei ....what's the chances of that happening at the same time ?...unbelievable m8 Shock
    Only the power to the Rev counter dash clock was caused by the Fuse board Mei
    All my other dash clocks were fried somehow though ...maybe the welding ....I still think that's my fault for not having a battery isolator that turned off & went faulty and my battery was on & connected when welding ...even though ignition would of been off .....who knows 120% knows Mei LOL
    All I care about is its sorted 100% ....would never of looked inside the fuse box ...never ....ever Mei ...Thumbs up
    Posted 20th Feb 2016 at 19:47
    Post #46
    That amount of damage Ash looks like it been there for a while m8 ...I've only had my heater out for a while Thumbs up
    I went to Maplins on the way back from Mechanic / Martins depot ...I bought PCB waterproofer & anti damp spray ...The new fuse board we fitted tonight could go under water now LOL ...
    This ones out of a 40,000 car ...looks new inside & out Thumbs up
    Posted 20th Feb 2016 at 19:42
    Post #47
    Can you not ajust the Mileage via Peouget Planet ?
    Posted 20th Feb 2016 at 19:48
    cully
    Post #48
    there would be a circuit if the fuseboad was tracking due to a short Wink
    Posted 20th Feb 2016 at 19:59
    Post #49
    Yes that makes total sense Thumbs up
    What a bloody pain it was ...had everyone stumped this one LOL
    Thank God it's now Sorted & I really hope this tread may help other ...if anyone else is having problems they can't solve with FAQ
    I thought I was ok with electrics until this LOL
    Posted 20th Feb 2016 at 20:22
    Post #50
    And if you're using HF start on a TIG to weld plates in, that can give more than enough voltage to track across circuits on a PCB.
    However, there would have to be current flow from elsewhere at the same time to damage anything, as the TIG HF is only milliamps.
    May just be one of those things.
    Posted 20th Feb 2016 at 22:00
    Pages (3): 1 [2] 3
