displaying posts 651 to 675 of 3423
Pages (137): first .. 26 [27] 28 .. last
Post #651
AEM wideband?
save sandy some work next time its mapped Wink
This is the one Sandy recommended Just before you two posted ...Thumbs up
Apart from mapping Mei wouldn't this AEM gauge drive you nuts looking at it on the dash with all the LEDs etc or Not ...is really all its use is for mapping ?
You couldn't or shouldn't ajust anything even if it gave a mental reading on track days ?
Posted 9th May 2016 at 15:09
Post #652
doesn't drive me nuts , I don't sit there looking at it really but its a decent quick indication if there's something wildly wrong, not 100%, but I think its brightness varies with the ambient lighting so its not that bad.
As I still had a cat fitted on my ZX Sandy set my ecu to do some self correcting too.
Posted 9th May 2016 at 15:18
Post #653
Ok thank you Brilliant Mei ....seem to be a X series ?....which col black would do the job ?....can fit a lamba back into my decat down-pipe Thumbs up
Sandy just texted & said its a handy thing & saves him plugging his WB lamba in for mapping but that's the big really biggest help he says ....
Posted 9th May 2016 at 15:29
RetroPug
Post #654
52mm analogue clock Smile
Posted 9th May 2016 at 20:12
Post #655
Luke that's a great idea until I have the money to buy a AEMThumbs up
Posted 9th May 2016 at 21:15
Post #656
Yes Mei it does have a sensor on the front and dims slightly but not a lot.
Wondering if mine works properly or not though while we're on the subject of AEM wide band... seems to work OK when driving indicates lean as f**k to nothing on over run etc but when it's turned on without the engine running it shows a constant figure of fairly well what the last thing it read was.... goes up or down a bit but stays around 12-14.... with the engine off it will be 0 fuel and 20% oxygen so it should be reading the same way when on over run I would think and just have 2 lines?
Digging my 6 out the garage this week somewhen so I'll refresh my memory on what it actually does.
I wanted mine in case something goes wrong fuel wise and I start running lean as f**k. Anything involving boost and it's easy to melt things lol.
Posted 9th May 2016 at 22:18
Post #657
The guy who did my mapping said my AEM wideband was bang on what his lambda sensor was reading which he put in the end of the exhaust. I assumed the AEM would be somewhere close to what's going on in there, but the fact he said it was bang on at all extremes made me think its actually not a bad bit of kit.
Handy to see whats going on and to check things arent going to start trying to melt themselves at a glance too, i'm impressed with mine.
It was also fairly useful when i had a base map as i used it to get the engine running a little sweeter which enabled me to then drive the car to the mapping session.
Posted 9th May 2016 at 22:37
Post #658
I think the Stack one can be set with alarm thresholds for fault warning. That might save a blowup if it caught an injector running lean but apart from that it serves no real purpose other than mapping and keeping an eye on an otherwise healthy engine.
Posted 10th May 2016 at 09:47
Post #659
Thanks Jim Thumbs up ....I save my money for the mo then LOL
Posted 10th May 2016 at 13:10
Post #660
Tonight ...Found a small-oil leak & power steering leak tonight and sourced the causes.....
1. Oil leak is from old oil pressure sensor plug NOT Used any longer ....(which on the far right in the picture below says M16 blank )....so I'm going to remove the unused sensor & fit a blank ...ANYONE know if it's M16 fine or common course metric .... I think it should be ....?
2. Power steering sensor plug weeping not from base from where the edges are pressed & crimped around the sensor ...I've removed this already & will fit a blank with a copper washer Thumbs up
PS this is not my engine it's a picture stolen off here Big grin LOL
Posted 11th May 2016 at 08:24
Post #661
I think the blank is m16x1.5 from memory. Hopefully someone will be able to confirm that soon.
Posted 10th May 2016 at 22:05
Post #662
Yes your spot on Steve Thumbs up
Will get a blank for it today as not using it ......
That's weeping around the top edges also Thumbs down
The power steering sensors had a knock at sometime (pic below)...that's weeping badly when I turn the steering Thumbs down
Posted 11th May 2016 at 08:29
demondriverdan
Post #663
What thread are the photos of your gearbox oil breather in? I thought they were in here but went back a long way and couldn't find them
Rallye Race Car
Posted 11th May 2016 at 09:20
Post #664
I think the thread on the PAS pressure switch is 14x1.25, if a sump plug fits then it is Smile
Posted 11th May 2016 at 10:37
Post #665
Sadly Dan I can't remember ?....sorry just took my plastic gearbox filling cover breather plug into Merlin Motor sport & they gave me it Whistle ....
Don't keep receipts sadly Thumbs down
Posted 11th May 2016 at 10:49
Post #666
You are SO so close Mel it's M12 X 1.25 m8 Thumbs up
I thought it was M14 myself until they fitted a nut on it & said M12 m8
Posted 11th May 2016 at 10:51
Post #667
sneaky bas**rds LOL
Posted 11th May 2016 at 10:56
Post #668
Just rang Frank from Advanti Motorsport. Who's checking size for me now Dan ....give him 30mins m8 Thumbs up
Also it extra 3/4 of A litre of oil he said ....
That's what I fitted Thumbs up
Posted 11th May 2016 at 10:59
Post #669
sneaky bas**rds LOL
Exactly Mei LOL
I'm just fitting a bolt & cooper washer Mei Thumbs up
Posted 11th May 2016 at 11:00
Post #670
Got it in the End Dan = M20x1.5 Thumbs up
Don't forget 3/4 of a litre more no less no more Thumbs up
Posted 11th May 2016 at 14:11
Post #671
Small update ...
A few of us on here run TRS Carbon roof vents ....I asked Twangy / Wayne about them being noisy & the water coming in far to much when raining & he came up with a amazing suggestion .....
But a decent cheap Air filter & fit that ontop of the mess fitted inside the lid ...it keeps it from wind noise & dust also limits the rain a little ...even though mine vents into a cycle bottle temp LOL
So thanks to Twangy here's my take on it ...
ITG JCS-12 with three filtration layers & round end cut off & flatted out with finer foam on the inside ..job done ....your a star Wayne
Posted 11th May 2016 at 14:44
Post #672
Now cut & flattened out before fitting Thumbs up
Two layer filter that can be cleaned & does not restrict airflow much ....
Normal cheap open cell foam didn't work Thumbs down
Posted 11th May 2016 at 14:26
Post #673
Got my M16x1.5 bolt that needs shortening & Copper washer fitting ...
Got my M12 X 1.25 bolt for blanking power steering sensor thread that also needs shortening & Copper washer fitting ...
Sorted now ...fitting tonight Thumbs up
Posted 11th May 2016 at 14:43
demondriverdan
Post #674
I should have blanked off the sensors on my engine. Still got things like oil level, and the spare oil pressure one that I don't use!
Rallye Race Car
Posted 11th May 2016 at 15:03
Post #675
Yes take those your not using out ...two of mine have leaked ...only noticed it by chance Whistle
£1.93 for two odd bolts 8.8 quality & two copper compression washers Thumbs up
Posted 11th May 2016 at 16:48
