displaying posts 676 to 700 of 3423
Pages (137): first .. 27 [28] 29 .. last
Post #676
Foam fitted amazing into the Carbon TRS roof vent ...you don't need it to the back as it seals 1/2 way down because it drops down at the back
Posted 11th May 2016 at 20:51
Post #677
M16x1.5 old oil sensor taken out where blank is below on the picture
It was leaking below white plastic pressed edges
Posted 11th May 2016 at 20:56
Post #678
New M16x1.5 bolt blank & compression copper washer used ..
Posted 11th May 2016 at 20:57
Post #679
M12x1.25 bolt blank fitted to Power steering old sensor place ...used compression copper washer that sits ontop of built in ORing ...
Bolt on right hand side ...you can see top only
Posted 11th May 2016 at 21:02
Post #680
These clamp around my Rollcage behind my dash & the alloy plate in picture below bolt onto it Thumbs up
Posted 11th May 2016 at 21:04
Post #681
Alloy angled brackets bonded onto the underside of the fibreglass dash with new Polymor adhesive that's anti vibration & is a little flexible also it's waterproof ...looks great stuff but takes 24hrs to cure sadly ....
Going to put 3 alloy brackets on in total ...one each end & one in the middle as in the picture ....
If you look closely you can see two holes drilled into each alloy plate for exhaust clamps the bolt through Thumbs up
Posted 12th May 2016 at 06:40
Post #682
Got a nice surprise from Jenvey today Whistle
I love freebies LOL
Posted 11th May 2016 at 21:11
blandy
Post #683
Oooh what's in the box
I thought I got on quick with a project but nothing like this lol
Posted 11th May 2016 at 21:21
RetroPug
Post #684
You can't post that box without showing us the contents!
Posted 11th May 2016 at 21:37
Post #685
Lots of stickers / catalogues & some Pipercross airfilter cleaner & re-oiler Thumbs up
All for our FCS stand Whistle
Posted 11th May 2016 at 22:55
jeffers Forum Admin
Post #686
Ok I'm gonna bite... Whose FCS stand?
Team Running Engine again!
Team Negative Camber!
Posted 12th May 2016 at 00:09
Post #687
Sorry Lee I should of said m8 wasn't teasing ...Will DeClaudio knows Mark Dow very we'll who runs FCS & because he will have his new white 106 ready for the first display at FCS he has been given at a great price..... A stand area in the trade area to display for 3 cars ...and he's taking two cars himself ...because Sandy / Jenvey / DTA / Colin Sachell / Mike Edwards have all worked or helped out on my car & they help Will ...he asked if I'd like to put my old girl on there & Sandy Browns hopefully trying to make it ...plus Jenveys sales manager Nigel is going to try & make it but only comes off of hols the day before so he has sent some stickers & brochures down to give away ...in case he doesn't make it Whistle
Wills hopefully taking his new car on track also ...
Look my cars no show car ....but I'm sure not going to turn down a free day Razz
Posted 12th May 2016 at 06:26
Post #688
I was trying my hardest to get the car ready for Jap fest this weekend it's the new Castle Combe one Thumbs up
I'm not going to have it ready Now though sadly & got told today that only Jap cars will be allowed on track ??????.....
if that's true I hope FCS do the same as at least a dozen Jap cars always turn up to FCS track sessions Thumbs down
Posted 12th May 2016 at 06:35
RetroPug
Post #689
Lassa tyres did a japanese drift show thing at FCS last year as well.
I wonder if there will be any discounts on Jenvey setups on the day haha.
Posted 12th May 2016 at 18:05
Post #690
Fitted fibreglass dash tonight & well happy ...so fitted two Stack pro gauges X1 Volts ....x1 Oil pressure
Drilled a three for when I get a Widedand gauge later on...
I'm going to have it Flocked so everything needs to be ready before its flocked ...
Posted 13th May 2016 at 20:47
Post #691
Stop ends
Post #692
Blank on bottom will be used
Posted 13th May 2016 at 20:48
Post #693
Other stop ends
Also I'll be fitting Hazard switch at very bottom below gauges ....
The original fuse box will go in a modified cradle cut down on the bottom R/H corner ...sort of wear it is normally ...
Posted 14th May 2016 at 04:42
Post #694
I spoke to Castle Combe guy who's running it ....he said he's not banning other makes EG French ....but because it's there first show from splitting with the Jap Silverston lot ....he's trying to keep it as Jap as possible ...I can understand that Thumbs up
So if my car was ready I could of gone Thumbs up
3gan on here Lee who does my flocking is going & taking his Evo (Tommy Mak ) red car that's been on the front cover & inside main pages last month of Banzi Mag Thumbs up
PS ...give me a shout on Jenvey as I'll always put you in touch with the best price person Whistle
Posted 14th May 2016 at 04:51
Post #695
Well just dash to finish flocking & fitting then Dash wiring needs wrapping & taping up ....
Just went out in the old girl & helix paddle Clutch / pressure plate feels great not snappy one bit ....
3j plate diff when driving slowly is now clunky & bloody noisy as I'm not using any Redline bed in additive ....it will work much better now on track ...
The drives seat is really low now so with a helmet on I'll have loads of room ...
Just fitted my new Odessey Race lightweight battery & upside down secure bracket with lorry rubber inner tube around the box ....just in case a terminal comes loose ...
No leaks of any kind now thank god Thumbs up
Posted 15th May 2016 at 13:05
Post #696
Fits amazing & half the weight
And yes I have a full cover for it
Posted 15th May 2016 at 13:06
Post #697
Cut & fitted my standard fuse box holder to my Fibreglass dash
Posted 15th May 2016 at 13:07
Post #698
Better picture
aaron6
Post #699
You've gone proper mad with this now ain't ya. LOL
Looks cracking though. I still ain't passenger ridden in it yet...
Posted 15th May 2016 at 15:09
aaron6
Post #700
You gonna make my wife squeal again? If so, take my gopro...
Posted 15th May 2016 at 15:10
