need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets.
Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,825 Status: Offline |
Post #476
i remember getting those rads from gsf for £40!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 25th Apr 2016 at 13:45
gnrlee
Forum Admin Location: Leeds Registered: 20 Aug 2005 Posts: 8,880 Status: Offline |
Post #477
looking good mate! ________________________________________ Proud Member of the ASTOR Owners Club |
Posted 25th Apr 2016 at 14:38
Post #478
welshpug! wrote: you could use a 205 tank, quite easy to plumb it into a 306. dont cut into the top hose, ill get you a diagram later, standard 406 top hose. Brilliant Mei ...I've got a 205 expansion tank but it's old & doesn't look great PIC BELOW How the hell am I going to fill the radiator & bleed it also ?.....I'm all ears Day666 has attached the following image: |
Posted 25th Apr 2016 at 20:11
Post #479
Got some bits I was going to use or take back ?Day666 has attached the following image: |
Posted 25th Apr 2016 at 20:47
Post #480
Got this expansion tank & it has everything I need & it fits perfect as in picture ...plus it's well above the hose / radiator level Day666 has attached the following image: |
Posted 25th Apr 2016 at 20:48
Post #481
Used some alloy 6mm plate & drilled & fitted the rubber bungs in the right position for the 205 radiator .....Used the Aircon rubbers as they are smaller & same internal size .... Day666 has attached the following image: |
Posted 26th Apr 2016 at 15:16
Post #482
Going to fix alloy plates to cross member ...the reason I used 6mm is it lifts the rubbers enough to miss the oil cooler brackets Day666 has attached the following image: |
Posted 25th Apr 2016 at 20:53
Post #483
Fits a treat Day666 has attached the following image: |
Post #484
Plenty of space Day666 has attached the following image: |
Posted 25th Apr 2016 at 20:54
Post #485
Getting some alloy angle welded onto the top of the radiator each side & then these two rubber Robbins will bolt through the slam panel ...hopefully nice & simple fitment Day666 has attached the following image: |
Posted 25th Apr 2016 at 21:01
Seasoned Pro Location: DoncastAAAAARGH Registered: 13 Jan 2008 Posts: 4,640 Status: Offline |
Post #486
Nice update. Definitely consider making a shroud for the radiator, it's made the world of difference to mine! ________________________________________ Goldie the track car. |
Post #487
Nice & softish rubber bobbins Day666 has attached the following image: |
Posted 25th Apr 2016 at 21:02
Post #488
prism7guy wrote: Nice update. Definitely consider making a shroud for the radiator, it's made the world of difference to mine! Don't forget Steve I've got no intercooler or pipework infront of my radiator m8 ... Defo do it if I get any issues ...ill see how the temps are first My 10inch single fan is a Tripac USA made one so say good quality but not SPAL prices ...one fan kept it cool before & it's easy to add another if needed |
Posted 25th Apr 2016 at 21:20
demondriverdan
Post #489
Will the expansion tank have any issues with heat from the exhaust?________________________________________ Rallye Race Car |
Posted 25th Apr 2016 at 22:42
Post #490
demondriverdan wrote: Will the expansion tank have any issues with heat from the exhaust? I'm hoping not Dan ?.....many cars have ran them there m8 ....I can Put some Zirotec underneath if it becomes a issue m8 |
Posted 26th Apr 2016 at 01:17
Post #491
you need an xu/xud tank not a tu one.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 26th Apr 2016 at 07:30
Post #492
welshpug! wrote: you need an xu/xud tank not a tu one. What's the difference Mei ? Would the one I bought in the picture be no good ? Where's the best place to connect the header tank bottom hose ? I can fit it with the piece in the bottom hose or top hose ?....I didn't think the top hose would work because the thermostat may be closed ?....or am I wrong ?....fitting the large bottom tank filler Hose into the top hose would make things so easier I can see the small top expansion radiator tube goes to the top of my expansion alloy tank ... |
Posted 26th Apr 2016 at 08:35
Post #493
Trying to find one of these off 205 GTI 1.6/1.9 to fit my Baker BM thermostat adaptor .....get rid of that Bacolight 306 thing & wont need a reducer to 205 rad then ?Anyone have a spare to sell ? Day666 has attached the following image: |
Posted 26th Apr 2016 at 08:27
Post #494
Got one good condition £15 delivered .....from address below only deals with 205s good bloke has 32 cars instock |
Posted 26th Apr 2016 at 13:10
demondriverdan
Post #495
Day666 wrote: I'm hoping not Dan ?.....many cars have ran them there m8 ....I can Put some Zirotec underneath if it becomes a issue m8 I doubt it'll be a problem, just wasn't sure! ________________________________________ Rallye Race Car |
Posted 26th Apr 2016 at 11:27
Post #496
Got one from 205gti spares £15 delivered ....Also I'm connecting into my rear lower Old not used heater matrix pipe & blanking top |
Post #497
Made some T pieces up out of alloy angle & seam welded them & then tigged them onto the top of the Radiator ....Will drill x2 holes in each later for rubber bobbins to fix too ... Day666 has attached the following image: |
Posted 26th Apr 2016 at 13:17
Post #498
Had to go dam careful & not let it get too hot Day666 has attached the following image: |
Posted 26th Apr 2016 at 13:18
Post #499
Got my clips for the 205 new hoses .....so far so good And got some thin 1.5mm alloy sheet bent to make radiator Cold Air director like Prismguy/ Stephens done Day666 has attached the following image: |
Posted 26th Apr 2016 at 14:14
Post #500
yeah with the square 205 tank tee off the upper heater hose to the bottom of the tank, fitting it to the top hose wont fill up properly.the small takeoff goes to the rad and with a 6 engine blank the larger top takeoff with a factory bung, from a 405 airbox iirc, or an XUD rear water takeoff. drill two 3mm holes in the thermostat either side, to allow any air to bleed out, its a peugeot/citroen sport mod that Ive done to all cars I've worked on. go easy with those mikalor type clamps, too easy to over tighten those. I might have a spare alloy takeoff, much prefer the standard plastic takeoff though, so much easier to fit, use a 406 top hose MIles has said. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 26th Apr 2016 at 15:19
