displaying posts 326 to 350 of 3423
Pages (137): first .. 13 [14] 15 .. last
Post #326
you still have the spring thing?
Yes Mei ..I have a non Spring Tensioner that I was given & I could fit but bearings are clicky ....
I'm looking at doing away with the whole tensioner or fixed extra roller totally long term ....get a much shorter belt & then this Rose jointed ajuster will come into its own for putting tension on the belt Thumbs up
Posted 7th Apr 2016 at 08:25
demondriverdan
Post #327
I didn't bother with an adjustable bar and just used a stretchy belt straight from the crank pulley on to the alternator. Using a smaller / lighter alternator is interesting though, might have to look in to that, assuming it fits the original mounting points.
Rallye Race Car
Posted 7th Apr 2016 at 08:56
Post #328
Never tried the smaller alternator on the standard Cast iron mount ?....can't see why not .....I've saved with cast alloy mount & smaller alternator 14kgs Crazy
Posted 7th Apr 2016 at 12:45
Post #329
Made these myself ....
Trying to strengthen my top mounts & also fix my Brace I'm modifying to fit at the same time 5mm plate should do the trick when it's welded on .....
Only tacked it together at mo Whistle
Got to ajust shape a little Thumbs up
Posted 7th Apr 2016 at 12:52
demondriverdan
Post #330
Interestingly I was looking back, your gearbox only gives you 128mph in 6th? That's not a lot, I hit about 130 ish at Rockingham?
Rallye Race Car
Posted 7th Apr 2016 at 13:46
Post #331
rockingham has far longer straights than Combe, though Combe is still a very high average speed, especially for FWD chassis.
Posted 7th Apr 2016 at 13:54
demondriverdan
Post #332
That's fine if you only want to do Combe but that must be so boring? I find Brands Indy really dull as I've done so many trackdays there!
Rallye Race Car
Posted 7th Apr 2016 at 14:22
Post #333
Dan that's at 7500rpm on a standard engine !
My new Engine will go a lot higher m8 ...I'm trying to think ahead so I only buy once m8 ..Thumbs up
Also it's geared better for Prescott Whistle
Posted 7th Apr 2016 at 15:05
Post #334
Dan have you ever been to Combe ?...YOU would love it m8
It's 6miles from my front door
It's the most dangerous track in the UK m8 & responsible for 70% of the crashes LOL
You can't get bored of that danger m8 ...
But I'm planning on doing lots more tracks also ...sadly I've no trailer yet & I have to drive my car to the venue which isn't ideal ...
Would love a old Beaver tail midi van ....Thumbs up
Posted 7th Apr 2016 at 15:44
demondriverdan
Post #335
I'm not saying Combe is boring, it's a good circuit, but there are so many others out there! It's fast but I'd say it's still safer than Cadwell if you're going flat out.
You're missing out on Craner Curves at Donnington, Paddock Hill at Brands, Turn 1 and Goose Neck at Cadwell, Turn 1 at Rockingham, Druids at Oulton, etc. So many good circuits that doing one over and over again is just a little tedious? Once you've figured out the lines and are comfortable in the car then the danger goes away and you're just lapping for the sake of it, which is a bit pointless to me. I've come in during a Brands trackday because I was genuinely bored in the car!
Rallye Race Car
Posted 7th Apr 2016 at 15:46
blandy
Post #336
how do you get on at combe with noise?
Posted 7th Apr 2016 at 16:06
Post #337
My Cars 90dbs with front & back box 2.5 Magnex Thumbs up
Posted 7th Apr 2016 at 16:09
blandy
Post #338
bodies dont cause a issue on drive-by then?
Posted 7th Apr 2016 at 16:28
Post #339
No ....not one bit ...
My car only has standard engine at mo don't forget LOL
Posted 8th Apr 2016 at 07:32
Post #340
This ones for Welshpug Thumbs up
Wonder what I'm upto later 890 belt instead of 1130 LOL
Posted 8th Apr 2016 at 14:35
Post #341
I've used a 610 belt on one before, but that was non pas as well, with a custom made really cheap bracket Big grin
Posted 8th Apr 2016 at 16:29
Post #342
Your a legend Mei Thumbs up
Posted 8th Apr 2016 at 20:08
Post #343
Right I've been speaking to Frank from Advanti Motorsport in Street / Somerset ...
He's a gearbox Guru & used to design & assemble 5 speed & 6speed boxes for Peougeot Rallye team in Coventry in the day ..
Anyway he did some designs & R&D for Bacci in Italy & knows Plate Diffs & Sequential gearboxes inside out ..also made a plate diff without planet gears because that was a big week spot so say ...
I asked him about gearboxes for Super big power cars like Ollies & Ross sadly he said anything over 350 they were always having failures on LSDs & Gearsets ..one of the reasons he gave was lack of oil & said even without the syncros & bearings the torque killed them also ...
Frank said they tried every trick in the book & one they helped massively was to vent the box as I've just done in the picture below his idea not mine & put an extra 500ml in the box ....2.5 litres he said of high quality gearbox oil ..
He said the boxes were transformed with the high power cars ...he used to go to Coventry twice a week back in the day ...
Anyway I thought I've got a expensive Syncro box with Bacci crownwheel & pinion so why not give it a try seeing as my box does get hammered ...
What have I got to lose ?.....he said it must be vented like this don't use the standard vent Thumbs up
Posted 8th Apr 2016 at 20:26
Post #344
Super big hole
Posted 8th Apr 2016 at 20:27
Post #345
ITG filter or K&N recommended
Posted 8th Apr 2016 at 20:28
Post #346
Took seconds to fit but don't forget to use Doughty washer ....
I hope you super high boost Boys try this ?????
Franks no at Advanti is
01458 446517 amazing bloke that just knows boxes ...especially Lancia / fiat / Peougot boxes from 40yrs to today ...
Got all the bits from Merlin Motorsport visited the shop so sadly can't remember part nos but I'll get them ...
Cost £34 all in which considering its brass etc plus ITG not too bad ....Thumbs up
Posted 8th Apr 2016 at 21:26
eddy_gti6
Post #347
You need to come do croft, flat out through the Jim Clark esses into barceoft and knockhill is a great track for our cars too, but you's probably will never make it this far up living so far away
Posted 8th Apr 2016 at 21:48
Post #348
Anglesey 2nd May Big grin
Posted 9th Apr 2016 at 00:02
Post #349
Would love to do both Guys ....I've modified the car to use .....but in looking at 2-3 weeks more before its 100% finished & then it needs a bloody good couple of local Combe shake downs Whistle
I've not got a trailer & would have to drive in this car & drive back ?
Posted 9th Apr 2016 at 08:32
demondriverdan
Post #350
Invest in a trailer! No point having a well specced car that you can't push hard as you're worried you'll end up in the wall with no way of getting home. At our last race someone had a crash and it turned out they had driven the car there, such a silly idea.
Rallye Race Car
Posted 9th Apr 2016 at 11:50
