Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
blandy
Post #3101
Fantastic as always đź‘Ť |
Posted 18th Apr 2021 at 11:56
Post #3102
Small update from today Nothing exciting The composite bumper needed a little tiding up and some support areas worked on so they look similar to others as well at the same time of strengthening them The pic below is the middle support bar what I need to replicate to the ones either side |
Posted 18th Apr 2021 at 20:01
Post #3103
These are the results of copying the ones in the middle in the pic above post Was dam fiddly So I cut some Carbon Prepreg tube in half ...then went about shaping it to fit the figure S shape which does not show in the pics and then finally I bonded them on with VM100 structural bond ... This will now get semi seam sealed and primed over after keying up the Carbon a little with some wet and dry paper |
Posted 18th Apr 2021 at 20:03
Post #3104
Final results before semi seam sealing I believe it’s the little things that add up to big things ... This has massively strengthened the front support bars and stopped any flex ....hopefully won’t need any metal support bars now and two max if needed ? |
Posted 18th Apr 2021 at 19:57
Post #3105
blandy wrote: Fantastic as always đź‘Ť Thank you Mike Cant wait to see yours Friday at Combe |
Posted 18th Apr 2021 at 19:59
blandy
Post #3106
Just need to get it ready 🤦‍♂️ Going to be a couple of late evenings I reckon having to work this weekend hasn’t helped lol |
Posted 18th Apr 2021 at 20:50
Post #3107
Small update on the Grill surround and another (Updated bonnet) that I’ve changed yet again I’m really happy now and I’ll be taking it to get mould made end of next week Hopefully Air take is in place finally now |
Posted 24th Apr 2021 at 15:34
Post #3108
Posted 24th Apr 2021 at 15:35
Post #3109
Posted 24th Apr 2021 at 15:36
marksorrento205
Seasoned Pro Location: Airborne in the lanes Registered: 26 Aug 2008 Posts: 2,223 Status: Offline |
Post #3110
That is just front end porn ________________________________________ How to do a clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Posted 24th Apr 2021 at 19:50
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,306 Status: Offline |
Post #3111
Osh.________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
Posted 25th Apr 2021 at 07:30
matty_rallye
Senior User Location: Devizes Registered: 28 Oct 2005 Posts: 966 Status: Offline |
Post #3112
Blimey, nice work. ________________________________________ 2.1 16v 306 Rallye. |
Posted 26th Apr 2021 at 21:52
Post #3113
marksorrento205 wrote: That is just front end porn Thank you guys .... Mark Marcellus Matthew |
Posted 27th Apr 2021 at 20:44
Post #3114
Forget to mention made the (yellow X) section up with P40 fibreglass in three layers then Easy1 Upol body filler |
Posted 27th Apr 2021 at 21:02
Post #3115
So basically it looks like the (Red X) area now |
Posted 27th Apr 2021 at 21:14
Post #3116
From the pic I’m sure you can see a lot of messing about on the underside |
Posted 27th Apr 2021 at 21:06
Post #3117
Plus even more messing about on the top ...but hopefully it’s the little details that count and make all the difference?The reasoning as well as filling the gap to reduce wind underneath was to (strengthen) that area up to try and eliminate some of the bonnet flex at high speed over 120mph when this bonnet which is Fibreglass at present would bulge ...hopefully the mould from this bonnet made in Carbon Prepreg won’t do that now with these teeth like areas it will help ...it’s made a massive difference to this Fibreglass one |
Post #3118
Nothing exciting just finished off smoothing the modified bonnet Sending it next week to get a mould made and then have a (twin skinned) = prepeg Carbon bonnet that will be sprayed the same col of the car on the outside .... I’m going to call this bonnet the MANTA model thanks to Joep |
Posted 30th Apr 2021 at 20:36
Joep
Regular Location: Urmond (The Netherlands) Registered: 19 Sep 2013 Posts: 478 Status: Offline |
Post #3119
Nice progress! This car is going to be so unique in every aspect, it is awesome!Bonnet looks more like a manta to me, but stingray sounds way cooler and so does more justice to the car! 8) ________________________________________ My car park:'96 Sigma Blue XSi6 '98 Diablo Red GTi6 '99 Onyx Black S16 All RFS powered! Plus various other Peugeots |
Posted 30th Apr 2021 at 13:32
Post #3120
Joep wrote: Nice progress! This car is going to be so unique in every aspect, it is awesome! Bonnet looks more like a manta to me, but stingray sounds way cooler and so does more justice to the car! 8) Thank you Joep Your 100% correct Manta now X |
Posted 30th Apr 2021 at 20:35
Post #3121
Nothing exciting but took me ages to get to this stage The Joep /Manta bonnet |
Posted 1st May 2021 at 09:23
Post #3122
Fitted Genuine Aero catch’s to the top and bottom now instead of Extra large Pitking push button ones that I personally didn’t trust The visual and safety I feel they give far outweighed what they looked like At high speed they are going to take a fair bit of pressure with the double different size top and bottom splitter .... |
Posted 1st May 2021 at 12:53
Post #3123
Small update ...mocked up =mk2 new dash and [Carbon Cartek] centre control panel fitted with Sequencial gear-lever and DTA Digital Dash and electric power steering and steering support frame ....getting there |
Posted 9th May 2021 at 14:18
eiei0
Regular Location: Kildare Registered: 08 May 2020 Posts: 192 Status: Offline |
Post #3124
Do you think it will see a track this year Damien ?? |
Posted 11th May 2021 at 08:06
Post #3125
eiei0 wrote: Do you think it will see a track this year Damien ?? Sadly no Trevor The engine has to go to the engine builder Sandy Brown for oil pump to be removed because I’ve gone dry sump and some upgrades plus it needs a refresh etc ... He’s fully booked for the next 12months Plus I’m only spending money that I have and earn etc .....so I recon 14-16 months |
Posted 13th May 2021 at 16:03
