displaying posts 2801 to 2825 of 3423
Pages (137): first .. 112 [113] 114 .. last
Post #2801
Posted 30th Aug 2020 at 17:40
Post #2802
Posted 30th Aug 2020 at 17:41
Post #2803
Inside the Cartek
Posted 30th Aug 2020 at 17:43
Post #2804
Some may not but I prefer the black and white with round button also has black stickers rather than coloured red/ blue / yellow
Posted 30th Aug 2020 at 17:48
Post #2805
As you can see from this view the dash now curves into the driver by 90mm
Posted 30th Aug 2020 at 17:50
Post #2806
Very nice
Posted 30th Aug 2020 at 19:40
blandy
Post #2807
Do love that dash, kinda wish I’d of kept a 306 dash in mine seeing that
Posted 30th Aug 2020 at 20:24
Post #2808
hovis16 wrote:
Very nice
Thank you
I see yours is coming along fantastic too Thumbs up
Posted 30th Aug 2020 at 21:30
Post #2809
Thank you
I never really had a choice Mike after I spent silly money getting the original mould made that I sold to Ryan ...even lost £100s on that ...
I sort of had to keep it out of it costing me so bloody much Crazy
But getting the extension from David Warren I’m glad I did now .:.only thing is I’ve got nothing to put in or on it Thumbs down
Posted 30th Aug 2020 at 21:35
Post #2810
Had a idea ....I knew it wasent going to be cheap or a quick job .....I made all my engine mounts myself to drop and angle my engine so Sandy designed inlet that was made by Satchell would be the correct or close angle to fit the inlet below with some modification...hopefully not to much ...hope I got my measurements right
This has just arrived at Maxi Motorsport/ Tony Palfrey’s place
For those not sure what it is ....It’s Carbon /Kevlar air intake box off a Mk3 Maxi design ...need a flat green cotton air filter installed at the end and it fits over the radiator
Posted 3rd Sep 2020 at 16:53
Post #2811
Posted 3rd Sep 2020 at 14:35
blandy
Post #2812
Looks great
Posted 3rd Sep 2020 at 15:10
Post #2813
blandy wrote:
Looks great
Thanks Mike
Hopefully I can make it fit now Whistle
Posted 4th Sep 2020 at 08:12
demondriverdan
Post #2814
Damo, does it fit over the standard rad? I'd like to get an air box on mine but think I'll need to go to a 205 rad as my inlet points too far downward
Rallye Race Car
Posted 4th Sep 2020 at 08:30
Post #2815
Mine we’re pointing upwards Dan as my inlet is quite straight
So I made all my own engine mounts and angled the whole engine to hopefully fit this airbox Thumbs up
Not sure until tomorrow Morning when I get a chance to try it Dan ...I recon NOT mucker as it would have to stick through the bonnet at the top with a standard rad ... I guess ?
I’ve got two ways I’m thinking of fitting it at mo and both involve a bespoke rad sadly Whistle
The 205 rad for my idea and how my non standard engine mounts angle and lower my engine mean it would be slightly to low I think ?
Posted 4th Sep 2020 at 18:10
Post #2816
Had a good look at it in my van tonight as I’ve not got a chance to try it until tomorrow am
Can’t knock the quality of the product
Posted 4th Sep 2020 at 18:12
Post #2817
Really pleased how the air-box is going to fit...
The problem has always been how straight my Sandy designed / Satchell inlet has been ...it’s always had my ITG pushing hard onto the inside top of my bonnet pointing up and the idea of that was airflow / less bend etc
I dropped the engine and angled the engine with bespoke engine mounts I made to make it all fit as best as possible ....so the air-box and the sequential box would work better and get the weight lower too
I may? need to get a 3D printed first to try and then a billet machined alloy spacer with threads in to take up the angle to have the airbox straight where I want it...
In the pic below the back of the airbox is parallel and 100% upright and you can see the Jenveys are still angled ...but now the engine is lower and angled more forward I can play around with angled spacers more without the top of the air-box hitting the underside of the bonnet or it not closing by 40mm ...had it would of before
Posted 5th Sep 2020 at 11:42
Post #2818
The air-box is straight and parallel in the pic but you can see how the Jenveys still point upwards but half as much as the used to because of the nearly straight inlet
Posted 5th Sep 2020 at 11:46
Post #2819
The Rad I have now and is in the picture is 370mm high I need it 75/80mm shorter but with a expansion tank possibly....we will see ...so 300mm tall really .
I may
have to get a bespoke Rad made with a expansion tank as I’m limited to room with the dry sump tank going in ...as Tony Palfrey said try and get a 205 Diesal Rad in but sadly it needs a expansion tank ...I may have room somewhere up in the corner of the wing but that may need making ?
Just messing around thinking at mo ...it always changes on the way....
In the picture below the air-box is still 30mm to high and will
Drop when I remove this rad to try
Posted 5th Sep 2020 at 11:50
Post #2820
Hopefully look similar but I can see already its going to have to be cut and go up more into the bonnet front ...Have to wait and see Whistle
Posted 6th Sep 2020 at 10:26
Post #2821
will a gti6 rad but just a shorter core do the trick? if so speak to Ross as he's got some ideas/contact
Posted 6th Sep 2020 at 11:43
Post #2822
Yes ....apart from the built in expansion tank would have to be smaller also Mei Thumbs up
If I can I want that catch tank built in ....
Do you mean Ross / supercharger ?
Also
Problem with a 205 rad I’ve looked at is the top outlet is at a awkward angle and no built in expansion tank
Big thank you Mei
Posted 6th Sep 2020 at 12:38
Post #2823
yeah exactly that, my thoughts would be to have the tank full height still if there is room, otherwise you will have issues filing the system up that would negate having a built in tank.
Posted 6th Sep 2020 at 12:47
Post #2824
Yes I’ve got the room Thumbs up
Did you mean Ross / supercharger?
Posted 6th Sep 2020 at 12:55
Post #2825
yeah chapman
Posted 6th Sep 2020 at 14:21
