| Author | Subject: i broke it. |
RetroPug
Post #101
I quite like copper slip for protecting and lubricating threads. Most products will need reapplication if protecting exposed ones like that, but I find copper slip seems to last fairly well.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Post #102
Agreed i use copper slip or grease for most or gray antilock grease for heavy applications ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
shabusta
Regular Location: Australia Registered: 10 Sep 2015 Posts: 244 Status: Offline |
Post #103
One i came across is wd40 silacone spray its meant to be the same in cleaning and lubrication but wont attract dirt and dust after use.I have to send the strut back to spax for further inspection :'( this will more than likerly take weeks, and using an old strut with the spax one would be sheer stupidity (?) |
mocinim
Post #104
Not wise but if you drive real careful to move it should be ok ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
shabusta
Post #105
I think i'll just suck it up and put the original struts back one until something can be sorted out.see how i go tomorrow and if i can be bothered. |
mocinim
Post #106
Good plan________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
Post #107
you can see what angle the droplink tab should sit at if you fit the standard ones ![]() regarding the threads, anything waterproof will do, when you need to move the spring pans thoroughly degrease and clean any crap off them, apply some oil and should move nicely (as long as not cheap and rusty, gaz probably the worst ive ever seen for rust!) raceland are usually fooked and I the bin before they get chance to rust. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
shabusta
Post #108
Yea the main problem i found with the spaz rsx is the front end gets very very bouncy with the stock and old rear shocks, this is fully wound and not setup properly and as seen eailyer probably broken. |
mocinim
Post #110
Buy new bearing the one in my pic above was new from febi and is fairly cheap £14 iirc________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Post #111
GSF do a pair of SKF bearings for a shade over £20 delivered within the UK, when they have their weekend sales. I'm unsure if they would post out to you though. I'm sure a company popular over there will supply a decent brand for not a lot of money. The top mount platform itself appears to look OK, but have a look at it closely. ________________________________________ ![]() |
shabusta
Post #112
The top mount its self is brand new it has probably done 15kms. yea we get Meyle parts from an importer in Melbourne generally takes a few days to get almost any part in. |
Post #113
bearing looks fine, do you have the spring pan to match the small diameter spring?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
shabusta
Post #114
Yes i have all of the plastic spacers for the springs and the alloy connector for the springs to go onto the top mount. |
shabusta
Post #115
Only problem from my point of view is dirt and whatever else that got onto it and the grease, and the main part the plastic clip that holds it together broke, but it all fits / sits the way it should. |
Post #116
once assembled it stays together with spring tension so the clip doesn't actually do much.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Cherry Buell
Newbie Location: Cork Registered: 06 Mar 2015 Posts: 33 Status: Offline |
Post #117
Have a few low mileage febi ones lying around here will post to you if you stuck,message me address |
russbez
Post #118
dam you and those clean hubs etcbarely a sniff of rust anywhere ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
shabusta
Post #119
Hahaha i did just rebuild the front end, but yes the only real rust i have found was tbe bottom corner of each of the rear guards, brake guards? The metal disc thing. |
mocinim
Post #120
russbez wrote: dam you and those clean hubs etc barely a sniff of rust anywhere Awsome a !!! im thinking of importing a 306 from oz just for the shell ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
shabusta
Post #121
They are cheap here, i got mine for $5000 Aud, roof racks inclided and only 86k kms.Especially with how good the GBP is compared to AUD. |
mocinim
Post #122
Whats the exchange rate average is it around half that would still make it around 2500k GBP got mine for 1400k GBP with free rot !now selling by the bag bargin at 7.38 per kg LOL________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
shabusta
Post #124
Loads @ £500 over here ![]() ________________________________________ ![]() |
