displaying posts 76 to 100 of 124
Pages (5): first .. 3 [4] 5
Author Subject: i broke it.
shabusta
Post #76
I took it is the fin on the right should point to the left (rear)
The left fin should point to the right (rear)
Posted 28th Oct 2015 at 22:01
mocinim
Post #77
Got me thinking as mine point forward on my oe struts just slightly not sure if the coilovers should be different or mine are correct but thats how they came off and my old ones look original least the springs do really crusty rotten
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 28th Oct 2015 at 22:25
shabusta
Post #78
Yea my OE ones point directly to the body of the car. While the coilys have a fair angle to the.
Posted 28th Oct 2015 at 22:34
mocinim
Post #79
I suppose if they work without contact on full turn then there correct apart from that and all mentioned i reacon your good to go try your full lock both sides have a good look and off you go let us know how you get on mate
Posted 28th Oct 2015 at 23:04
shabusta
Post #80
Just dropped the car off camber is way out and so is the alignment....
Might be the time to get some new tires...
left marks along the road for a good few KMs
Posted 29th Oct 2015 at 03:06
shabusta
Post #81
Results:
$500 AUD, for wheel alignment, wind up the coil overs, driver and passenger boots.
solution, move car from their workshop to street, wind up coil overs, anyone got tips on how to get these just right or a nice height to have (30-75mm)? install both boots, drive back into workshop and get wheel alignment, $100.
i'm thinking to just fully wind them to the top to keep things simple, but i dont like how the top spring almost fully compresses.
Posted 29th Oct 2015 at 06:02
shabusta
Post #82
My new best friend for boots Smile
Posted 29th Oct 2015 at 08:48
mocinim
Post #83
What do you mean by boots cv or ? And why mate
Posted 29th Oct 2015 at 08:45
shabusta
Post #84
the steering rack boots, i'm using these as the clips.
mocinim
Post #85
They will do i reacon i just managed to source oe peugeot ones there just wire with twist ends of
Posted 29th Oct 2015 at 09:06
mocinim
Post #86
mocinim has attached the following image:
shabusta
Post #87
Yea from what i've looked up cable ties are the usual go to fix, and even come with some boot kits, but wear out, so why not just get stainless steel cable ties.
Very nice, they look nothing like what i took off.
Posted 29th Oct 2015 at 09:08
shabusta
Post #88
I stand corrected the passenger side boot has those clips on it, which is actually in near perfect condition for 15 years!!! ( i will do this when i start on the rear end and get some new tires / rims)
I put a new drivers side boot on, easiest job i have ever done!!! bit of grease and it slipped straight on.
my metal cable ties were only good for the larger diameter of the steering rack, it did work around the inner tie rod but not as well as i would have liked.
Currently in for a wheel alignment and a double check of the coil overs height!!!!! i should be clear to go for a cruise all week end, and to take it for a lap around Mount Panorama!!!
Posted 30th Oct 2015 at 02:25
mocinim
Post #89
Awsome glad shes sorted and ready worth the hard work best find a non mountain to practice hard conering to begin a fella LOL
Posted 30th Oct 2015 at 08:09
shabusta
Post #90
Back to the drawing board and as the heading of this thread states, wheel alignment is amazing now, and the local boys even did it for free......
purely because the coil overs "dropped a thread" the guys did what they could for me, for free i might add.
but the end advice is don't drive it until the thread can be fixed or contact the distributor.
this is more than likely my own fault for winding them up too far.
Posted 30th Oct 2015 at 08:49
mocinim
Post #91
Holy horse crap bat cheese not sure it should be doing that can you get it back on the thread youll need to compress that coil doesnt look impossible to fix did you scar the thread or is it simply the tention nut has give up if the shocks ok then its not massively drastic
Posted 30th Oct 2015 at 09:01
mocinim
Post #92
And yes looks simply like you wound it off the top may just wind back on if you can release the tension and realign it
!thought! If you wind up the lock nut can you push it back up or is there to much force
Posted 30th Oct 2015 at 09:07
shabusta
Post #93
hmmmmm thats some good thinking, could i damage it more by doing this, some steel / alloy thread was poking up before it was aligned, so i think it might actually be de threaded.
Posted 30th Oct 2015 at 09:23
mocinim
Post #94
Yep think you may have lost the thread on the load ring you will only damage it more if you wind the lock nut up to far or if the thread is already damaged
Have you got a large washer you can use to space the gap between rings to avoid winding the load ring off the top
Cut washer in half greese in insert in the space then wind up etc
Posted 30th Oct 2015 at 09:35
mocinim
Post #95
Best practice to oil these 3in 1 or something keep the crap out grit will damage threads when adjusting always
then clean down after with some wd40 oil dispersing greese nothing harsh
Wd40 cleans lubricated for a short while then its low viscosity wont allow for high build up crap to remain leaving areas grease free depending on how much used best to wipe down with a paper towell to remove additional residue Smile
In my experience wd40 used in garages has a thicker viscule content due to not having to be mixed with volatile hydrocarbons for areasol function may need two paper towels Smile
Essentially better than leaving lubricating oils of a thicker nature on
Edited to please Smile all fluid based materials evaporate in time some quicker than others usually depending on viscosity
TIP!!
Posted 30th Oct 2015 at 16:28
shabusta
Post #96
^ now that is some good advice, i am just leaving the car parked until i get a reply from SPAX the person i bought it off or i get onto a local suspension specialist.
Posted 30th Oct 2015 at 09:45
mocinim
Post #97
Fair play sir good luck
Posted 30th Oct 2015 at 10:30
shabusta
Post #98
got an email back from supplier "hello, we have forwarded your email to SPax technical to see what can be done"
Posted 30th Oct 2015 at 10:44
jeffers Forum Admin
Post #99
then clean down after with some wd40 oil dispersant nothing harsh
Wd40 cleans lubricated for a short while then evaporates leaving areas grease free
TIP!!
WD40 attracts dirt if left on and you will end up with more crap in the threads than you started with, and it certainly doesn't evaporate.
Team Running Engine again!
Team Negative Camber!
Posted 30th Oct 2015 at 14:57
mocinim
Post #100
TIP!!
Quite correct but not more than you would collect anyway and certainly less than leaving thicker oil on most oil will dilute and disperse greese
Posted 30th Oct 2015 at 16:02
