http://www.306gti6.com/forum/attachments/2240232_dsc_0007_(400x600).jpg
| Author | Subject: i broke it. |
shabusta
Regular Location: Australia Registered: 10 Sep 2015 Posts: 244 Status: Offline |
see If you can sus anything out of that photo?http://www.306gti6.com/forum/attachments/2240232_dsc_0007_(400x600).jpg |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
The wires are wear sensor wires if they dont plug in anywhere cut them off nice and short mine are the same cut off that is!________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
Oe top mounts with coilovers not sure thats correct what does the manufacturer suggest for top mountsbearings do look upside down from what i can see flange lip should point down in a normal cup fit flat of bearing to the top ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
Oe one shows the bearing flange coming through the top spring cup black ring in the middle not sure how they will fit you coilovers ot sure they should ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
shabusta
I've been thinking about it all day,I had a funny feeling about the drop links the whole time and that the struts drop link hole was in the wrong location, that it should be parallel with the body not off set by say 45 degrees. then it just clicked.... i think i put the drop links on back to front...... and to bring back an old joke, yes they are also upside down :/ |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
bearing is upside down.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mocinim
welshpug! wrote: bearing is upside down.[/quote As per the previous bearing is definately upside down the strut wont seat properly once fitted correctly it will give more thread at the top of the mount to tighten the bolt down dont drive this fella ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
shabusta
Post #35
To confirm if i flip the bearing will the springs sit in a U shaped grove to also fix that issue?And should i get the fittings off the old struts so the bolt holds down on the rubber on top? Drop links right or wrong way around? |
mocinim
Post #36
Drop links look ok mine are pug ones and are equal size both ends not sure on rotation from the pic link strut connection fin should face the car as the hub sits stright e.g with no turn does your coilover have a locating notch on it this should locate your strut correctly on the hub should slot in the gap where the bolt clamps the hub ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
Post #37
mocinim wrote: Drop links look ok mine are pug ones and are equal size both ends not sure on rotation from the pic link strut connection fin should face the car as the hub sits stright e.g with no turn does your coilover have a locating notch on it this should locate your strut correctly on the hub should slot in the gap where the bolt clamps the hub Fresh bearing !! The flange should face down you need this to slot into the top of your strut the weight must push on the curved section ! Outer flange ! mocinim has attached the following image: ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
Post #38
mocinim wrote: mocinim wrote: Drop links look ok mine are pug ones and are equal size both ends not sure on rotation from the pic link strut connection fin should face the car as the hub sits stright e.g with no turn does your coilover have a locating notch on it this should locate your strut correctly on the hub should slot in the gap where the bolt clamps the hub Fresh bearing !! The flange should face down you need this to slot into the top of your strut the weight must push on the curved section ! Outer flange ! Do you have a pic of the top of the coilover is there a grove where this will fit mocinim has attached the following image: ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
shabusta
Post #39
If i am understanding correctly and it will fit exactly how you are holding it there is a bracket that the lip that points down will fit into if not that would be a perfect fit for the spring to simply fit around.I never understood the term flange can you explain how you understand it? And again should i get the metal top for the bolt to press down onto? |
mocinim
Post #40
On you original set up the flange (bit on the bearing that points down )goes into the top of the spring cup bit of metal or disc that the top of your spring pushes on Im guessing that on the top of the coilover there is a groove the flange/down pointing bit will slot into if not you will require a different topmount type or adaptor SORRY SHOULD OF READ ABOVE ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
Post #41
Flange: An external or internal rib or rim, used either to add strength or to hold something in placeflange. [flanj] /flændʒ/ a projecting rim, collar, or ring on a shaft, pipe, machine housing, etc., cast or formed to give additional strength, stiffness, or supporting area, or to provide a place for the attachment of other objects. 2. ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
shabusta
Post #42
Yes there is an adapter that should fit perfectly (Hopefully....) i'll try and work out a method to do it without removing the top mount or the strut from the hud / body.current plan is to raise the body of the car, support the wishbone undo the bolt flip the bearing, align lower and do up bolt. thanks for that the closest i have come to a definition was that it was basically the same as a gasket. |
mocinim
Post #43
Spoke to demon tweeks guy said should fit as sold to you e.g should go stright onto oe mount Flange :its a great word !!! ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
RetroPug
Post #44
shabusta wrote: Same as i took it off ish, 19 turns either side. It won't solve your knocking, and the bearing issue certainly needs fixing, setting the toe to roughly the same number of turns will get it good enough to go and get it done properly, but with all the changes etc. and the imprecision in doing the same approximate number of turns will mean it is still a fair bit out. I hope once you sort the top mount bearing issue out your troubles will be over. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
shabusta
Post #45
i think the knocking was the adapter moving on the rubber of the flange, everything else seems fine.and yes once i get on the road i need a wheel alignment ASAP. |
mocinim
Post #46
Hi retro will it being out of alignment cause clicking or knocking in the tierod ends________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
RetroPug
Post #47
mocinim wrote: Hi retro will it being out of alignment cause clicking or knocking in the tierod ends It shouldn't do, but it being out of alignment is definitely bad and the car will have all sorts of funny road-holding behaviour, so if you suspect it is out get it realigned. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
mocinim
Post #48
I know mine is out waiting on drive shafts before i get it done have a clicking on mine when moving away and slowing as the torque comes in n drops off cant define where it is coming from had new bearings well and everything really about to replace inner tie rods will replace outer to keep as a set fingers crossed any thoughts ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Post #50
struts are either 205 ones or they're on the wrong sides.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
