Author Subject: cat convertor best to buy
mocinim
Hi gents whats peoples opinions on the best non original cat to buy peugeot want 6 to 7 hundred for a new one do any others perform as well original system only
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 6th Aug 2015 at 17:02
RetroPug
Probably best off spending 70-80 odd quid on a good, 2nd hand genuine one.
Has it failed emissions or has the outlet pipe cracked and fallen to bits? If the 2nd one get it repaired at an exhaust place.
Posted 6th Aug 2015 at 18:03
sbolly
http://www.autobits.co.uk/store/view_product.php?product=6946
Bought this for mine, will be fitting it tomorrow will try and let you know details on fit and quality etc. Went for the steel monolith option, ramps the price up a bit but worth paying for as it'll last forever.
'97 Platinum Silver GTI 6
Posted 6th Aug 2015 at 18:21
mocinim
None of the above its actually fine at the moment bit smelly not sure it will pass mot in jan just preempting the enevitable but dont want to spend out till required will start work on the bottom of the car soon will all be oe in the end
Just thought there maybe an alternative out there any idea who manufactures the peugeot one
Posted 6th Aug 2015 at 18:25
chiefton
if you cab get a gen pug one the difference is night and day to a nasty pattern one
cherry rallye daily (the money pit)
Posted 7th Aug 2015 at 02:38
ash
Six Addict
I've got a genuine cat you can have for £100
Posted 7th Aug 2015 at 07:41
mocinim
What age you got on that cat ash
Posted 7th Aug 2015 at 12:26
mocinim
Cheers bolly keep us posted seems super cheap think ill wait a month and get a new pug one it is a full to standard rebuild pricy but will never need another
Posted 7th Aug 2015 at 12:30
£600 odd for a genuine one IIRC
  • Posted 7th Aug 2015 at 13:23
    mocinim
    Cheers dan tis 681 plus surcharge unless you give them your old cat on the spot wallet raping ball bags
    Posted 7th Aug 2015 at 15:16
    RetroPug
    The genuine cats give the best performance, and also last quite well. In fact their ability to pass emissions often seems to outlast their ability to stay in one piece. The outlet pipe is the main weak point.
    Your issue could possibly be a sensor?
    Posted 7th Aug 2015 at 15:26
    mocinim
    Hi retro what sensor would you suggest has brand new lambda (bosch) and brand new ICV (marelli) have considered the map sensor advice is welcome
    Posted 8th Aug 2015 at 11:58
    RetroPug
    Maybe CTS but it could well the cat causing it to fail.
    Posted 11th Aug 2015 at 21:03
    sbolly
    Thumbs up Went in a treat, fits to my Jetex system very nicely Smile
    Posted 11th Aug 2015 at 21:30
    mocinim
    Cheers bolly did it make a difference to you power output
    Posted 11th Aug 2015 at 22:14
    RetroPug
    It almost definitely will. It doesn't mention if it is a 100 cell, 200 cell etc. Also it is definitely a physically smaller casing than the std. cats which are quite large in order to offer less flow restriction.
    Posted 12th Aug 2015 at 19:25
    mocinim
    Hi ,retro what other symptoms do you get with a dickky CTS
    Posted 12th Aug 2015 at 20:32
    sbolly
    Yeah you bet, coupled with the Jetex system I've noticed a great improvement in the drive, mostly acceleration. It's much sharper in lower gears and pulls really well through the higher ones. If you do go for that option i posted in the beginning, go with the steel monolith as technically you shouldn't need to ever replace it. And comes with two year warrantySmile
    Posted 12th Aug 2015 at 20:35
