Author Subject: replacing the cat...
barrym
The cat part of my exhaust has failed big time, practically hanging off.
The cat is the original but was only refitted 5 months ago to replace a decat. Not by me obviously as I wouldn't be asking !
Got a new one ordered, no problems there. My question is are there any un-obvious pitfalls when removing/refitting one? ie. what sealant to use, gaskets etc? The fitting kit on servicebox looks quite complex too, also any special-ish tools needed to release the manifold end of the pipe?
Got one day off work to do this so need to be prepared for anything
Help me please guysBig grin
Black Rallye occassional toy
Posted 17th Nov 2014 at 17:14
Have you bought a pattern part?
They don't last apparently.
10mm ring spanner for the top of the fitting bolt, deep 10mm socket on the bottom. I do it all from underneath with arms around the subframe.
My advice would be to wear goggles. You may find you knock the protective bag on he steering rack ram (if it's there!) and get a face full of old water mixed with PAS fluid and a decades worth of grit and grime in your face.
It's not a tricky job tbh.
  • Posted 17th Nov 2014 at 17:30
    barrym
    Thanks Dan.
    Yes I bought a pattern part. Hmm not good they don't last but coming up to Christmas needs must and all that. It was only £63 quid anyway.
    From experience when fitting a replacement HP steering pipe I know for sure the protective bag is gone.
    I have all the tools you mention so hopefully it will go well and I can spend the rest of the day fitting my BBM engine mountsThumbs up
    Posted 17th Nov 2014 at 17:42
    demondriverdan
    It's not particularly tricky but a fiddly job, mainly undoing the manifold to cat bolts. I think the fitting kit comes with several different length springs in which case you need the longest one.
    Rallye Race Car
    Posted 17th Nov 2014 at 18:14
    barrym
    TBH I wasn't planning on getting the fitting kit. Do I really need to?
    Posted 17th Nov 2014 at 18:18
    Whilst you are there you may as well IMO, or at least replace the firing ring as you don't really want to have to take it all apart again if it blows at the joint.
    My preference is to lay with my legs sticking out the front - but please do use axle stands, wheels underneath, have supervision if poss etc etc. I know someone who died from having a car fall on him, and when you are wiggling things around you don't want to risk it toppling on top of you.
  • Posted 17th Nov 2014 at 18:20
    barrym
    yeah I have all the kit, will have the car on axle stands under the front subframe and another set under the sills, chocks behind the rear wheels etc.
    I would like to go with a fitting kit, and will pop into my Pug dealer tomorrow to check availability. If I can get one I will use it but I HAVE to fit this Wednesday. Even if just as a temporary measure till i get the time to do a 100% proper job.
    Posted 17th Nov 2014 at 18:31
    You can buy the firing ring singly from a motor factors/eBay even.
  • Posted 17th Nov 2014 at 18:33
    barrym
    Cheers, I will check local availability.
    Posted 17th Nov 2014 at 18:37
    demondriverdan
    It's worth getting a fitting kit while you're there really. It's about £20 but makes life easier if you have to change the cat again as you know the kit will be new.
    Rallye Race Car
    Posted 17th Nov 2014 at 18:52
    ian7675
    Techno Viking
    I would advise getting the full kit, if you take the original bolts/springs off and lose one then you're stuffed. It's a simple job but as already said its fiddly. And definitely use goggles as Dan said. The kit comes with different sized bolts so it's just a case of matching the right ones to the originals.
    Less than 24 hours to go!
    Posted 17th Nov 2014 at 18:55
    barrym
    New cat is now in place and car is fine again!
    As stated it is a fiddly job but not complicated. Thanks for the help guys Thumbs up
    Posted 20th Nov 2014 at 15:47
