It looks impossible but I've welded in the cage so I also can't remove it
205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread
Looking for:
VTS P1 Rack
PR1.2 16"
| Author | Subject: Removing dash with cage installed |
jamiek_uk2000
Is this possible? I've fitted my cage which dogleg in front of the dash. It looks impossible but I've welded in the cage so I also can't remove it ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Hmmm you could have a problem there..... The dash needs to come straight forward iirc....________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Do you want to remove it to save weight? If so - perhaps cut it out. ________________________________________ ![]() |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
opps im guessing heater matrix job |
Rich E
I suspect your only option will be to cut the dash to allow it to pass the cage.________________________________________ Rich |
devere
Senior User Location: Saxtead Registered: 16 Dec 2008 Posts: 810 Status: Offline |
When I did this, I cut the end off the dash, to then e ale to pull that end clear of the cage, and then wiggle the other end out.Although having said that, I may have cut the other end also... hmmm. Either way, I did what I needed to do, and stuck the end back on afterwards. |
didnt think there were any dash dodger weld in cages?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jamiek_uk2000
It's a bolt in, but I've welded the feet as whoever I bought it off had welded it and some extra bars. ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
jamiek_uk2000
When I say I. I told someone with skills to do it ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
rikky
![]() ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
demondriverdan
I managed to get the dash out of the spare car without cutting it but it was a serious squeeze. Undo as much stuff as you can, heater matrix pipes etc. Then it was a case of moving each side to check it was loose and starting to pull it out. Essentially I had to pull one side as far as it would go (I think the passenger's side) then levering the driver's side out.It didn't quite come out intact as one of the mounting points snapped out but it did come out in the end. Took me 2 months of irregular trying to get it done though! ________________________________________ Rallye Race Car |
jamiek_uk2000
I think I'm going to chop it. I was hoping to put the fuses and stuff where the airbag is on the passenger side but I think that idea is out the window. Is it worth removing the heating matrix and fans? How much does that save? ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
rikky
saves a bit but you need a heater for the window, it's a nightmare otherwise________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
jamiek_uk2000
I'm not the most patient of person so I reckon it wouldn't go back in till about 2016 after I lose patience with it. I think its staying in to be honest. ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
demondriverdan
Unless you have to, I'd recommend leaving it in. It was a crap job and I'm not looking forward to putting it all back in!________________________________________ Rallye Race Car |
