displaying posts 1 to 25 of 35
Author Subject: Harness bolt point
jamiek_uk2000
Where do people bolt the handbrake side of the harnesses to? Everywhere else is easy but can't suss out this little issue.
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 4th Aug 2014 at 16:41
Drill a hole behind the handbrake cables
Posted 4th Aug 2014 at 17:28
jamiek_uk2000
Ah right, what you use then? A bolt and flat plate underneath?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 4th Aug 2014 at 18:03
a harness captive nut plate.
Posted 4th Aug 2014 at 18:05
jamiek_uk2000
I see. Two ordered from the bay
Better than the M10 Nut and square plate washer I was going to rob from work...
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 4th Aug 2014 at 18:10
jamiek_uk2000
Since I'm here, I've gone to fit the harness over the roll cage bar but both ends of the harness are sewn into a loop so I cannot undo it to lap it over the harness bar.
If I undo the stitching and then get the end sewn over so it's like a normal harness is this acceptable? MOT wise and track day wise?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 4th Aug 2014 at 18:16
Is there no harness buckles ?
Posted 4th Aug 2014 at 18:42
jamiek_uk2000
There are the standard bolt to the floor type buckles on there but I would rather lap it over the harness bar. Otherwise I'll have to go for the clip on bolt type thingamybob. That's the technical term for them anyway
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 4th Aug 2014 at 18:47
Get a buckle to thread it through. Sewing it up wont suffice at however many tons of force you'll create on it
Posted 4th Aug 2014 at 19:47
jamiek_uk2000
Yeah thats what I mean, the rear part of the harness is a loop so I can't undo it like you would a normal harness. Am I ok to just cut the existing stitching so I can run it through a buckle like a normal harness would. I was going to stitch the end so it doesn't look a mess
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 4th Aug 2014 at 19:50
um, what? pitchers!
Posted 4th Aug 2014 at 20:17
jamiek_uk2000
I want to do as shown on here http://www.securon.co.uk/fitting/extras/fiaharnessfitting.htm (can't remember how to do a clicky any more)
But the rear strap cannot be undone as it is stitched back onto itself after the bracket, so can I cut the stitching?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 4th Aug 2014 at 20:24
If you buy cheap eyelet harnesses you can't convert them to roll cage loop ones as far as I know.
It's the ones that you buy as cage loops that you can thread through a buckle.
  • Posted 4th Aug 2014 at 20:40
    jamiek_uk2000
    I see. What are my options then. Can I bolt the harness to where the original back seat belts were?
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 4th Aug 2014 at 20:44
    I'd be inclined to buy new harnesses and sell the ones you have.
  • Posted 4th Aug 2014 at 20:56
    jamiek_uk2000
    That may work out. Anyone want some Sabelt three point harnesses......
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 4th Aug 2014 at 21:07
    No I value my crown jewels
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 5th Aug 2014 at 00:30
    Fail.
    Left - right - rear from a V
  • Posted 5th Aug 2014 at 07:57
    jamiek_uk2000
    Fail.
    I was wondering what he was on about. They are the same to sit in as 4 point, the two chest straps join behind the seat so only one bolt point
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 5th Aug 2014 at 08:19
    Ignore Buzz Wink
    You'll not hear from him again until he asks you in 3 years how you got on LOL
  • Posted 5th Aug 2014 at 08:26
    dangti6 wrote:
    Ignore Buzz Wink
    LOL
    Posted 5th Aug 2014 at 10:20
    jamiek_uk2000
    Another question, do I have to weld the captive nut on the underside of the car?
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 6th Aug 2014 at 19:54
    nope Smile
    does make fitting the bolts easier if you tack it though.
    Posted 6th Aug 2014 at 20:02
    demondriverdan
    On the race car we drilled a hole behind the handbrake cables then put in welded a plate in.
    In this photo, near the top left, you can see a circular indentation in the metal work. We drilled a hole there:
    Then got a plate like this: http://www.carbuildersolutions.com/uk/heavy-duty-harness-fixing-plate-3mm and weld it in with the nut inside the hole
    Rallye Race Car
    Posted 6th Aug 2014 at 20:03
    jamiek_uk2000
    Yeah I was thinking that, but I haven't got a welding set. Gripfill to the rescue! Superman
    Looking for:
    VTS P1 Rack
    PR1.2 16"
