eek!!
youre meant to put them on the other way, theyre not meant to eork that way round!
need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets.
displaying posts 26 to 35 of 35
Pages (2): 1 [2]
| Author | Subject: Harness bolt point |
demondriverdan wrote: ] and weld it in with the nut inside the hole eek!! youre meant to put them on the other way, theyre not meant to eork that way round! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
What I did - which I assumed was correct:Drilled a hole big enough for the eye bolt to go through and put the square plate underneath the floor with the nut facing down to the ground. The eye/head of the bolt effectively uses the floorpan as a washer. ________________________________________ ![]() |
jamiek_uk2000
Yeah that's the plan. Just using gripfil to hold it to the car until I can get back onto and put the bolt it. That either means I have no friends or I am preparing incase I have to remove the harness a few times________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
demondriverdan
I need to check what I've done but I'm fairly certain I described it right. When we drilled a hole through there was another layer underneath so I'm not sure how you welded the plate in from underneath?________________________________________ Rallye Race Car |
Chr1sch
Seasoned Pro Location: Worcester Registered: 02 Aug 2014 Posts: 1,025 Status: Offline |
Daft question (possibly) can you run harnesses if the buckets are on sliders?! |
yep, its not ideal, you'll just hsve to adjust them every time you move the seat________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Chr1sch
Thought as much, but useful to know. So is the overall conclusion that these lugs need to be welded into the rear floor to mount harnesses? Seems logical but one heck of a faff, i recently removed my rear seats and there are 2 very large what appear to be brass (over an inch tall) big lugs coming through the floor - any idea what the heck they are?! |
lugs for the seat base, yellow zinc plated steel________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Chr1sch
Post #35
balls, not harness mounts then lol |
Pages (2): 1 [2]
