displaying posts 126 to 150 of 184
Pages (8): first .. 5 [6] 7 .. last
Author Subject: Breaking 306 & 206 Race Cars
eddy_gti6
Post #126
Any pics of that bonnet?
Posted 18th Mar 2015 at 20:14
ash
Six Addict
Post #127
The sold one?! I mean sorry it's sold.
Posted 18th Mar 2015 at 22:37
eddy_gti6
Post #128
Ah must have missed that... sorry LOL
Posted 19th Mar 2015 at 00:06
Hawkesfire
Post #129
Ash is the engine still lurking around as if the price has dropped a little i might buy as a spare???
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 19th Mar 2015 at 12:59
ash
Six Addict
Post #130
Yes the engine is still here, I'd consider offers over £1000 bare if collected during March or be happy to include other bits at a very reasonable price.
Posted 19th Mar 2015 at 18:31
ash
Six Addict
Post #131
I still have loads of bits including the engine...
Posted 2nd Jul 2015 at 17:27
eddy_gti6
Post #132
Got an up to date list?
Posted 2nd Jul 2015 at 18:49
Nick.gti6
Post #133
Hi ash can you update to see what you got left
Posted 10th Jul 2015 at 08:43
ash
Six Addict
Post #134
Am compiling a new list but to start things off I'll take £1100 for the engine:
Proven* 408BHP XU10J4RS complete engine with Wossner Pistons, PEC H section rods, cam timing adjusted. Estimated sub 1000 race miles only, no smoke or problems known.
*Track N Road Rolling Road Printout available.
I also have an EW10 complete engine with Wossner Pistons, PEC H section rods capable of making the same power or more £1200.
Posted 6th Aug 2015 at 11:22
Post #135
Anything Non supercharged & any nteresting bits would be good ?
New list will be great Ash !!!
Posted 6th Aug 2015 at 12:35
fatlapit
Post #136
Ash pics of the xu please
Posted 6th Aug 2015 at 12:54
ash
Six Addict
Post #137
I can take pics of the XU but theres really nothing to see, its just looks like a std used engine outside, I never painted it or anything but it was meticulously built by me from a road engine I used to use; it didn't even need a hone or anything. There's no leaks anywhere.
Posted 6th Aug 2015 at 13:07
ash
Six Addict
Post #138
List for starters; photos will follow, prices are collected, can post small items at cost.
*306*
Welded up Inlet for sump mounted charger £50
Excellent Rear beam from race car £50
Good Rear beam spare £25
Alloy seat side mounts £40
Momo suede steering wheel £70
Quick release steering wheel mount £40
Plumbed in Fire Extinguisher kit, not in date but always passes scrutineering £50
8x Team Dynamics 17"x8" silver Pro Race 1.2 Alloys with correct centre bore and correct offset (lowest possible) straight but various minor scratching £110 each with or without slick or wet currently fitted.
Siemens 650cc injectors 4x perfect for 300-500bhp minimal use +- 1000 miles £125
Nearly new large Laminova oil/water cooler/heat exchanger suitable for 300-500bhp like new with fabricated alloy tube and silicone joiners only £150
4x JIC fittings, braided oil hose and engine take-off fitting £100
Swirl Pot £50
Emerald ECU, loom and installed map for high boost Supercharged GTI6 £550
Solid engine, gearbox and tie bar mounts, bespoke in alloy, 4x complete fitted to rear engine mount and tie bar £125
Leda adjustable front coil overs (drop link tabs removed) and Bridgecraft adjustable top mounts £600 may split
Bilstein Rear Shocks Tarmac Rally PeugeotSport B46-2313 unused £225
Longacre very wide roll cage mounted rear view mirror £40
3.1 turn PAS rack and ram £50
3.6 turn non PAS rack £25
New plated C38 bracket £90
Used mat black C38 bracket £50
Aux Belt Auto Adjuster by Lynx with 8 rib pulley by Lynx £90
Alternator with 8 Rib pulley by Lynx £80
PAS Pump, relocating bracket and bolts and 8 rib pulley by Lynx £110
Air Scoop by Lynx £10
Inlet Air Restrictor/Diffuser by Lynx unused £120
Rotrex C38/81 Supercharger, reservior, filter £850
Wheel studs 8 PeugeotSport 65mm useable length and 8x other brand 80mm useable length wheel studs and 16x tapered nuts £40
Seward Race Parts Brake/Clutch/Accelerator Alloy Pedal Box extremely light 1180 grams! £300
Genuine Peugeot Cat in good order £80
Decat (without mounting flange) £30
Good Valeo Starter Motor £30
PowerVamp small race battery and mounting cage £70
more 306 parts will be added here...
Posted 19th Oct 2015 at 22:21
RallyeP6
Post #139
Hi Ash, what a long list!. I thought that was the 206 that you were building to race, what happened.
Will be interested in 4 of your 17" wheels please.
Posted 6th Aug 2015 at 14:50
ash
Six Addict
Post #140
As you can see, I've got a lot money tied up in the small possibility of going back racing is the problem; and then I need to find the money to actually go racing. Believe me it's been a hard decision!
Posted 6th Aug 2015 at 15:08
RallyeP6
Post #141
What ET are the wheels?, and i won't need the track slicks or wets, would it be cheaper?.
Posted 6th Aug 2015 at 15:44
ash
Six Addict
Post #142
They are ET16 or 20 max. no sorry same price as I also need space so giving the tyres away!
Posted 6th Aug 2015 at 15:49
veka_gti-6
Post #143
Hi Ash Stearing wheel boss will fit to my PH3? Thanks
Posted 7th Aug 2015 at 09:53
ash
Six Addict
Post #144
As far as I know they are all the same Veka.
Posted 7th Aug 2015 at 09:59
veka_gti-6
Post #145
They are for airbag and non airbag cars and momo has boss to year 1998 so might be some differences. From which phase you removed this boss? Has this boss turn indicator cancel? Could you take a few pics? Thanks
Posted 7th Aug 2015 at 10:30
silky
Post #146
Possibly interest in parts from the 205 RG if you break Ash.
To fit my 205 XS
I sold the GTI6 shortly after getting the window from you so I could buy the XS
Posted 7th Aug 2015 at 10:45
ash
Six Addict
Post #147
Most prices reduced.
Posted 20th Aug 2015 at 17:28
Chr1sch
Post #148
you have pm
Posted 20th Aug 2015 at 17:38
Chr1sch
Post #149
Sorry misread the post above see pm - is the cage above for a 205?
Posted 20th Aug 2015 at 18:00
ash
Six Addict
Post #150
Steering boss appears to have 40 splines and indicator cancel probably from P2.
Roll Cage is for 205
Posted 20th Aug 2015 at 19:53
