displaying posts 51 to 75 of 113
Pages (5): first .. 2 [3] 4 .. last
Author Subject: Engine hard to start and stalls
Cjwatson27
Post #51
Once it's fixed i promise not to break it again, Could this be a fuel issue due to all the flooding round hear I've heard a couple having issues recently ?
Posted 27th Feb 2014 at 20:52
bas_306gti
Post #52
The only useful thing about resetting the ECU is that the stepper goes to the slightly open position, from where the engine can be started. It does nothing more.
Posted 27th Feb 2014 at 20:59
Cjwatson27
Post #53
I have had a doggy sensor somewhere so wondered if the reset would clear the faulty data up the ecu has been receiving , or are they not that sophisticated ?
Posted 27th Feb 2014 at 21:01
Post #54
shh don't give the forum ecu reset secrets away LOL
Posted 27th Feb 2014 at 22:18
woody.
Post #55
Yeh I'm pretty sure a reset will clear the codes, but if there's still a dodgy sensor on there it'll pick it up as soon as the sensor plays up.
Posted 28th Feb 2014 at 00:17
Post #56
Exactly this. Yes
Posted 28th Feb 2014 at 07:06
Cjwatson27
Post #57
I suspect ive got the sensor issue now has it starts better I'll try the reset tonight
Posted 28th Feb 2014 at 07:16
daver6
Post #58
ICV
Wishbone Polybushes available
Posted 28th Feb 2014 at 17:40
Cjwatson27
Post #59
Yeah I've cleaned it im going to test it tommorow using the diagram retro pug posted
Posted 28th Feb 2014 at 18:24
Cjwatson27
Post #60
Right i replaced the lambda did a ecu reset on it, no difference so i changed the ecu over and it seems to be behaving a lot better which makes me think that possibly the ecu that was supplied with the cams possibly has been remapped , unfortunately whilst poking about the starting issue started creeping back i wondering if this is a problem with the loom has its seen better days. Is it possible to replace the loom with the engine still fitted in the car ?
Posted 1st Mar 2014 at 22:29
jeffers Forum Admin
Post #61
Sounds like a dodgy loom, I reckon it can be done in situ... Just be patient as I reckon you'll end up with grazed knuckles lol!
Team Running Engine again!
Team Negative Camber!
Posted 2nd Mar 2014 at 00:55
Cjwatson27
Post #62
Since replacing the lambda sensor and doing the ecu reset the cars worst than ever it now holding back loads plus judders loads on deceleration and started misfiring like it was hitting the rev limiter at 5k when I tried to put my foot down . I'm so tempted to set fire to this car Angry
Posted 4th Mar 2014 at 19:06
woody.
Post #63
Just to recap, what sensors have you changed/checked?
Posted 4th Mar 2014 at 19:15
Cjwatson27
Post #64
Map sensor lambda sensor , tps sensor , CTS sensor , 4 known working coil packs , new iridium spark plugs , checked th earth . I'm wondering wether to try another map ?
Posted 4th Mar 2014 at 19:18
Cjwatson27
Post #65
And a different icv and clean i think this is why it's idling better once started
Posted 4th Mar 2014 at 19:19
Cjwatson27
Post #66
Wheres the throttle position sensor ?
Posted 4th Mar 2014 at 21:33
Post #67
Underneath the throttle
Posted 4th Mar 2014 at 21:49
Cjwatson27
Post #68
Posted 4th Mar 2014 at 21:51
RetroPug
Post #69
Are you sure this isn't literally just because the aftermarket cams are in it and it's not timed up properly?
Posted 4th Mar 2014 at 22:12
Cjwatson27
Post #70
It's got worst for about 10 miles the other day it drove spot on , now however it makes you sea sick driving it . Its must of forgot what happened to my white xsi when it kept playing me up even that or it has a death wish
Posted 4th Mar 2014 at 22:16
RetroPug
Post #71
I've got a spare MAP sensor I keep in the driver's door you could try.
In fact, you could try various sensors as long as they go back on my car at the end. Could have a listen to exhaust as well.
Posted 4th Mar 2014 at 22:48
woody.
Post #72
Have you unplugged the power steering sensor? Down between the rad and inlet mani
Posted 4th Mar 2014 at 23:36
Cjwatson27
Post #73
Cheers No I'm going to try that tonight along with the tps, is it just a case of unplugging it and running it to see if its better ?
Hmm I might try your spare map sensor retro i don't think we should tempt fate by taking parts of yours and trying them on mine , put thanks for the offer, I'm about Saturday if you want to pop down to hear the exhaust unless i fix this tonight . Thumbs up
Posted 5th Mar 2014 at 06:33
RetroPug
Post #74
Might take you up on that!
Will PM you nearer the time.
Oh, and could an air leak somewhere be causing this?
You could test for one by removing the air feed tube/pipe for the ICV and blocking the inlet of the ICV with your thumb. If there are no air leaks anywhere around the manifold/TB it will stall, if it doesn't stall, air is getting in somewhere else.
I'm not sure this would be the cause of all your problems but maybe worth a go.
Posted 5th Mar 2014 at 09:55
woody.
Post #75
I know unplugging the power steering sensor is fine, I ran it for months like that just had to rev a bit more when parking etc no biggie.
Not sure about unplugging the TPS though but worth a try while you're there, whether it'll run at all without it plugged in, someone else will have to verify.
Posted 5th Mar 2014 at 10:29
