displaying posts 1 to 25 of 113
Pages (5): [1] 2 3 .. last
Author Subject: Engine hard to start and stalls
Cjwatson27
Hi another problem with my 306 Thumbs down , I have to start if with throttle now and increase the revs just to stop it from stalling then it idles ok ish once its warm its ok , I've researched this abit but can't find a definite answer , any help narrowing this down has it would be one less problem for a very poorly gti6 CrazySad
Cheers Chris
Posted 6th Feb 2014 at 17:40
Try an ICV clean, after this I would change the CTS. Yes
Posted 6th Feb 2014 at 23:49
Cjwatson27
Cheers Stan is the cts the green one ? My plugs broken if i take it off the fans come on but it doesn't clip on probably ill try and grab a plug from the other loom and crimp it on
Posted 7th Feb 2014 at 08:08
Yes, the CTS is the green one. My feeling is that it isn't sending the signal to the ECU that the engine is cold and therefore to add more fuel during a cold start up, hence the reason you need to use throttle to do it.
Once warm, the issue goes away. This is telling me the CTS is stuck on telling the ECU that the engine is up to temperature all the time.
Posted 7th Feb 2014 at 14:28
Cjwatson27
Right swap the CTS for the one on the xsi cleaned the ICV swapped the map sensor for a spare i had even swapped the black box thingy with the yellow plug on the throttle body because the clip had broken , i then found the lamba sensor connection was broken ive got it to clip together better . After all this it seems to start better not perfect like 4 or 5 turns but it does drive a lot better, would it be a idea to change the coil packs has i have no cover and the owner before me never had one you can tell by the amount of crap there was in there before i cleaned it out .
Posted 7th Feb 2014 at 17:13
Cjwatson27
Ok it now will start its a little reluctant try's firing on 2 to 3 cylinders before starting , could this be coil packs ? It has sat around unused for abit, it does now idle tho once it's started , there's a black plug not doing nothing near the throttle body is this unused or should it go somewhere
Once again thanks for any help . Chris
Posted 7th Feb 2014 at 19:39
Cjwatson27
Any ideas it's still a b**ch to start its better just not good , ive got a new green sensor on order and some replacement coil packs even tho the garage say they tested them and there fine , whats the symptoms for the lamba sensor playing up ?
Posted 10th Feb 2014 at 21:05
The black plug near the throttle body is a spare - don't worry about that.
Starting on 2 or 3 cylinders could point to a few symptoms:
-Coil packs intermittently faulty (rare as they usually fail when hot and in the upper rev limit)
-Spark plugs damp/fouled causing poor starting
-Head gasket issues causing damp to flood cylinders on starting. Is there any pressure in the radiator if you undo the cap once the car has been switched off over four hours?
Signs of lambda problems are: poor idling/stalling/poor acceleration/jerkiness in low revs/poor fuel consumption.
Posted 10th Feb 2014 at 23:12
Cjwatson27
I might replace the lamba sensor has im a little disappointed in my gti6 there's not a lot of difference in power wise between it and my xsi so something's wrong somewhere Dunno
Posted 11th Feb 2014 at 22:33
pete-gti
I would say so, xsi 130 bhp?
Posted 11th Feb 2014 at 22:51
Cjwatson27
Yeah I think I have a very poorly 6 that might need putting out of it misery Sad
Posted 11th Feb 2014 at 23:01
pete-gti
Get it pluged in :-)
Posted 11th Feb 2014 at 23:09
Cjwatson27
The garage has tried with 2 different dianostic machines both show no faults he says its too old to read just getting get up of trying with it . Still we all have these days / weeks / months lol
Posted 11th Feb 2014 at 23:14
pete-gti
To old?, I no it might cost bit but perhaps get dealer plug it in?, or find a garage that's got the right software
Posted 11th Feb 2014 at 23:27
robthe6
where in oxford are you. iv got a few sensors on hand I can come try with you.
1997 ph1 bianca GTI6 - The looker
1996 ph1 Sigma GTI6 - Dead Sad
1999 Red Rallye - The Daily
2005 Nissan Navara D40 - Family car
1968 Mustang Coupe - The dirty little secret
Put ya foot down, put ya foot down we'll loose em easy!
Posted 11th Feb 2014 at 23:50
Cjwatson27
Cheers guys ive got a new lamba turning up today and hopefully another CTS if this dont sort it I'll give you a shout robthe6 Thumbs up
Posted 12th Feb 2014 at 07:21
RetroPug
What are the plugs like?
Have you got a multimeter to test the ICV with?
If so, then:
Although you said it was idling okay now though.
Have you cleaned up the earths? Might make it start a bit better along with new CTS.
Is this the engine with lairy cams that may or may not be timed up right?
Posted 15th Feb 2014 at 18:16
Cjwatson27
Yeah that's the engine I've got a new cts now, I'll try the earth's later once I've got the bonnet open Thumbs down can you time cams on a rolling road?
Posted 16th Feb 2014 at 13:22
RetroPug
Starting any better with a new CTS?
Is your battery likely to be weak or not have much charge left? You mentioned that it had been sitting... a battery on its way out can cause problems.
Posted 16th Feb 2014 at 13:27
Cjwatson27
Yeah its a brand new battery, it drives abit better buts not starting any better, ill check the earth and test the icv against those values and see what happens
Posted 16th Feb 2014 at 13:32
Cjwatson27
And it does decelerate abit lumpy
Posted 16th Feb 2014 at 13:33
Cjwatson27
Right p**sed about with it all day , I think the head gasket may have gone after it's been switched off it hisses from the rad cap and it's lost a lot of water. What do you guys think ?
Posted 16th Feb 2014 at 16:36
RetroPug
Potentially, HG on the way out can make it difficult to start as well, that's what happened to mine.
The coolant seeps into the cylinders and when you try to start it from cold you're trying to start with a damp cylinder(s).
If this is the case, if you leave the rad cap off and run it up to temperature it will bubble up very violently when the thermostat opens.
Posted 16th Feb 2014 at 16:45
Cjwatson27
Right I'll try that , who did your HG were they local ? I'm a bit reluctant to take it back to the garage who did the engine swap even tho he's a mate i don't think he's to familiar with old pugs
Posted 16th Feb 2014 at 17:08
RetroPug
Nobody, the car was previously written off so decided it wasn't worth the expense. Still a bit gutted.
Quotes are all huge as it is a fair amount of labour time.
It is possible to do your own but it involves a fair outlay in parts as well.
Posted 16th Feb 2014 at 17:13
