displaying posts 1 to 25 of 43
Author Subject: price dropped Cams, ECU & timing belt kit SOLD
rich6
SOLD
Set of non standard cams.
Base dia is approx 37.75mm
Base + lift is 48.85mm
Lift: 11.1 mm not sure of the make, a couple of symbols on them but not a manufacturers mark.
but they dont seem to be standard which have 10mm lift if im correct.
I had them in my 6 when I got it. It made good power through the rev range that didnt drop off in the higher revs.
Ecu is from a phase 1 gti6 and rev limit has been upped to approx 8k.
Timing belt kit is a gates kit with pulleys.
Looking for £350 for complete set. - price dropped to £200
Can arrange shipping at cost within the uk.
Thanks
rich6 has attached the following image:
Posted 4th Jan 2014 at 15:40
rich6
open to offers.
Posted 19th Dec 2013 at 11:14
Put some pics of all the markings etc up mate I wouldn't wanna put cams of un known lairyness in an engine unless I had pocketed pistons. Maybe someone will recognise the marks?
Posted 19th Dec 2013 at 13:35
rich6
I will get some pics of the markings up tonight.
Note: the engine from which they orginated did not have pocketed pistons.
Posted 19th Dec 2013 at 19:56
7057sam
So can on completely standard engine? where they fitted to the engine before you had it?
Also take it the ecu is unlucked?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 19th Dec 2013 at 15:25
rich6
They came from what was otherwise a standard engine. Pistons were not pocketed, and injectors were standard etc.
They were fitted to my engine before I bought the car. And I used it on a few track days, it seemed to keep going where my friends rallye ran out of puff.
ECU is unlocked as i didnt have to use the key pad for the car.
Would be happy to verify this by testing it on your vehicle if you were interested.
Posted 19th Dec 2013 at 19:53
rich6
cams
Posted 19th Dec 2013 at 19:52
rich6
cams
rich6
cams
Posted 19th Dec 2013 at 19:54
rich6
cams
rich6
cams
Posted 19th Dec 2013 at 19:55
rich6
cams
rich6
price drop to £250 for cams ecu and belt kit.
Posted 19th Dec 2013 at 23:39
jeffers Forum Admin
Rich, could you post a picture of the drive end of the cams with the pulleys removed? IIRC there will be numbers stamped in the end which will more than likely give an indication of the make and model number! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 20th Dec 2013 at 08:19
jeffers Forum Admin
*EDIT* thinking about it, it may be the non drive end.... either way on one end of each cam there will be a series of letters and numbers which should give an idea!
Posted 20th Dec 2013 at 08:26
rich6
Ive checked and cant see any numbers stamped on the ends, will double check.
Posted 20th Dec 2013 at 08:47
rich6
Does anyone recognise them. Is it possible they are reground?
Posted 20th Dec 2013 at 17:21
PeterT ones?
  • Posted 20th Dec 2013 at 19:13
    rich6
    could well be...
    The other thing is the car was apparently known on the forum before I bought it. P506 NFL..... ring any bells? white phase 1 gti6
    Posted 20th Dec 2013 at 19:41
    rich6
    any interest in these?
    Posted 23rd Dec 2013 at 12:12
    Roon
    I am but only if the cams could be confirmed as to what they are. I'm seeing miles on the 27th I'll ask him to have a look and see if he knows what they are.
    Posted 23rd Dec 2013 at 18:13
    rich6
    dropped to £200
    included is wiring loom, ecu, cams and gates belt kit.
    Posted 3rd Jan 2014 at 09:07
    rich6 wrote:
    could well be...
    I remember this car, very quick as far as I recall and it definitely had updated cams in it. Yes
    Unfortunately, I can't remember which ones they were. Doh
    Posted 3rd Jan 2014 at 09:57
    rich6
    Cheers Stan, it did go pretty well.
    Its good that someone remembers it!
    Posted 3rd Jan 2014 at 10:22
    Cjwatson27
    Will the phase 1 ecu fit into a phase 2 car do you know ?
    And did the engine they came from have standard pistons ,
    Posted 3rd Jan 2014 at 10:37
