displaying posts 26 to 43 of 43
Pages (2): 1 [2]
Author Subject: price dropped Cams, ECU & timing belt kit SOLD
rich6
As far as I know the ecu will work fine in a phase 2 car
And the engine they were fitted to had standard pistons.
Posted 3rd Jan 2014 at 10:41
Cjwatson27
Ok is it unlocked , so it would just be a case of unplugging one then plugging the other in , my cars in the middle of a engine swap so I'm interested in these not just asking random questions
rich6
Ecu is unlocked, in my understanding. The key pad was no longer required to start the car.
Posted 3rd Jan 2014 at 10:44
Cjwatson27
Can anyone confirm will the ecu work ok in a phase 2 car i presume it should be ok cause the immobilisers the keypad and not a chip in the key ?
Posted 3rd Jan 2014 at 13:07
Yes, it will work fine. Yes
Posted 3rd Jan 2014 at 14:17
Cjwatson27
So just a straight swap then ? Thanks for the help Stan
Posted 3rd Jan 2014 at 14:29
Mably
Hi, have you sold them yet?
Technician at Rock Marine Services Cornwall
Gti6 Phase 2 Black Hillclimb/sprint car
Race it, Break it, Mend it, Repeat...
Posted 4th Jan 2014 at 15:31
rich6
Hi they went yesterday,
Sold to Cjwatson27
Posted 4th Jan 2014 at 15:42
Cjwatson27
Received today can't wait till next week to get these fitted . Cheers
Posted 8th Jan 2014 at 18:23
Cjwatson27
Post #35
On the off chance do any of these markings or figures shed any light on to what these are. I fitted them to a engine which afterwards started tapping badly. Not sure if it was down to the cams or a issue with the way they were timed
Posted 3rd Aug 2016 at 23:06
Post #36
what markings?
with 11.1mm of lift they're beyond the 10.9 that the standard springs go coil bound at from memory...
Posted 3rd Aug 2016 at 23:32
Post #37
so yeah, youll likely have at the least 8 bent valves by now.
Posted 3rd Aug 2016 at 23:33
Cjwatson27
Post #38
Cheers did see you quote that 10.9. In another thread. So do I need longer valves and piston cut out for these ? Or they not worth the hassle
Posted 3rd Aug 2016 at 23:37
Cjwatson27
Post #39
Mei the cast markings near the lopes
Posted 3rd Aug 2016 at 23:41
Post #40
those are just casting marks, if there are any specific marks they will be on the end under the pulleys.
if there are none then you need to measure the cam, a dial gauge and a degree wheel and a set of vee blocks or a bare head is needed.
if you go beyond the 10.9 you need different springs, not valves.
most likely they will have much more lift at tdc than a modified standard piston will take, given most mild cams are under 2mm lift and 10.8 peak, so you'll need aftermarket pistons too.
Posted 3rd Aug 2016 at 23:52
Cjwatson27
Post #41
Cheers sounds like I might need a engine builder. I'll pull them
Out and looks for any marks see if we can find out what they are
Thanks again for the help
Posted 3rd Aug 2016 at 23:56
pete_rallye
Post #42
I have cams with markings under the pulleys, another set with the markings on the other end, and a set with the markings etched onto the flat on the non drive end, so look carefully!
You could send them to Newman cams or similar, they can stick them through a simulation and advise on the best timing for them etc and give you specific detail of the duration etc.
Lap of the 'ring
Posted 4th Aug 2016 at 01:31
Cjwatson27
Post #43
Cool, would that give me a better idea on what I need to get them to work ?
Posted 4th Aug 2016 at 07:18
Pages (2): 1 [2]
