displaying posts 76 to 100 of 110
Pages (5): first .. 3 [4] 5
Author Subject: How do they get 280bhp out gti6 engine?
jeffers Forum Admin
Post #76
It'd be nice to see it out again Pete! Yes
Team Running Engine again!
Team Negative Camber!
Posted 29th Aug 2013 at 21:26
pete_rallye
Post #77
You're not wrong!
Lap of the 'ring
Posted 29th Aug 2013 at 21:32
jeffers Forum Admin
Post #78
pete_rallye wrote:
You're not wrong!
Put me down for a few passenger laps if you make it! Thumbs up
Posted 29th Aug 2013 at 21:37
blandy
Post #79
What are the standard pistons and rods rated 2 bhp/rpm wise I.e having machined pocketed pistons what would be the perspective limit
Posted 29th Aug 2013 at 22:15
pete_rallye
Post #80
No one knows is the honest answer. People will speculate all they like but I don't know anyone whos actually worked it out. I would imagine there is a formula for the rods involving tensile strength, piston speed, distance etc that would give you a good idea but not sure about pistons.
As Allen has said, there are numerous examples in the rallying world of mi16's and s16's been revved to 9krpm on standard bottom ends. I know of one that was fine for years revving it knackers off. Guess it depends how much you want to risk.
Lap of the 'ring
Posted 29th Aug 2013 at 22:20
Post #81
200 ish.
whether the rods will be good for further its difficult to say due to the fact they are a shrink fit without a bush, therefore wont accept an aftermarket piston without some machine work to install a suitable bush.
not unheard of at all, but most choose to get cheap Chinese rods instead, whether that's a good idea I'm not sure of, however I do know that if you keep the revs reasonably close to standard limits then many std pug rods will be fine, I know Sandy has just used EW7 rods in a TU5 build that's around the 200 mark going to just over 8k (due to geometry of the engine, piston speed is actually no higher than the original EW engine)
Posted 29th Aug 2013 at 22:21
miles
Post #82
From seeing the amount of bend rods I have, To have them fail is going some, It's more likely the big end bolts will go first if std. Mines on a std crank to 8500 rpm and is fine, But it's all been balanced but over the winter a steel crank is coming, get some weight off and another trip to my balancers.
But figures are just that, I could say mine was 300bhp and no one would know any better
www.pugracing.com
Posted 29th Aug 2013 at 23:46
Post #83
200 ish.
Many people (including myself) have run 260bhp on standard rods without issue when low boost. Yes
Admittedly, the rev limit was only increased to 7450rpm mind. Wink
Posted 30th Aug 2013 at 08:09
allanallen
Post #84
stan_306gti6 wrote:
200 ish.
Stan, back on topic........ LOL
Facebook
Posted 30th Aug 2013 at 08:18
pete_rallye
Post #85
Its Stan who turns everything into an NA vs boost debate! I reckon he should be banned from talking about boost for a month.
Lap of the 'ring
Posted 30th Aug 2013 at 08:24
allanallen
Post #86
A month! One step at a time, perhaps a day to start off with Razz maybe he could use his admin powers to start a new 'super dooper moonstone hi boost' sub forum where he could voice his opinion to people that were actualy interested?? LOL
Facebook
Posted 30th Aug 2013 at 08:31
clen666
Post #87
Miles, how much do you pay for balancing?
Team 'unintentional rat look'
Posted 30th Aug 2013 at 09:08
Post #88
stan_306gti6 wrote:
200 ish.
My ecu has the words 7800 limit written on it so I doubt very much i'll be using that for when i go boost.
Posted 30th Aug 2013 at 09:09
Post #89
LOL @ you lot!
I was merely stating a fact. Someone asked what you could reliably take the standard rods to. Welshpug guessed around 200bhp safely, I merely stated a lot of people have managed 260bhp reliably, so perhaps 200 was a little under the mark.
Nothing to do with boost or not, simply what power (however made) the rods could cope with...Smile
Posted 30th Aug 2013 at 09:16
miles
Post #90
I use http://vibrationfree.co.uk/, give them a call for pricing
www.pugracing.com
Posted 30th Aug 2013 at 10:02
Post #91
I mention 200 as that's the most you'll get with the standard piston modified for cams, to go any further you need longer duration which means opening the valves sooner and faster.
and the fact that you're under 11-1 compression which isn't ideal when you start increasing the duration.
Posted 30th Aug 2013 at 10:10
jammapic
Post #92
FYI, I am running a totally stock bottom end, albeit with ARP rod bolts. When my house move is completed I will be getting the pistons pocketed and intend to push stock rods and pistons to failure.
I would like to think 200hp is a little on the low side welshpug! as I'm roundabout there anyway. But, lets see.... There's no point us speculating!
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 30th Aug 2013 at 10:11
Post #93
I reserve judgement on yours till it sees a known pair of rollers, or an engine dyno Razz
or you strip the "standard" cams out for longer duration items...
Posted 30th Aug 2013 at 10:57
allanallen
Post #94
JP
How and why are you going to push them to failure?
Facebook
Posted 30th Aug 2013 at 11:09
rallyeash
Post #95
Building an engine to fail will cost more than building it once with decent pistons and rods in the first place.
What a stupid thing to want to do or say!
309 3dr K20 Type R
Posted 30th Aug 2013 at 11:15
gilesy
Post #96
Well he is stupid, so what do you expect
Posted 30th Aug 2013 at 16:56
pebbles167
Post #97
I think he meant he's going to push them to their absolute limit, not build the engine with the intention of it actually failing... Surely.
No one with a full grasp of their sanity would want to do that.
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 30th Aug 2013 at 17:47
rallyeash
Post #98
But you'll only no the limit when they fail so it's basically still building an engine with the wrong mindset!
309 3dr K20 Type R
Posted 30th Aug 2013 at 20:31
Post #99
When they fail you're well past the limit, because there's fatigue to account for, without accurate fatigue cycling and checks the very best you could say is 'they're good for about half of what I blew them up at'
Even then, it's not absolute, because more power at lower revs can be less stressful and vice versa, depending on setup.
Even worse, the main problem with rods these days is not strength, it's stiffness, so you may be nowhere near the limit a just happen to spend most of your time near one of the natural frequencies of the rod combination, in which case it fails through that rather than power/rpms.
I think the most anyone can say is they're good for 170+bhp for a damned long time (Not heard of many stock rod failures...).
Which means they are probably capable of 340+bhp for a very short time.
And anything else is a mix of the two.
Posted 30th Aug 2013 at 20:39
Post #100
There was a bloke in brazil with 450hp on standard internals
With ethanol and lots of boost.
What was his name again? had a zx dakar...
Posted 31st Aug 2013 at 00:11
