displaying posts 1 to 25 of 37
| Author | Subject: Welding experts advice needed |
pugjim
Seasoned Pro Location: Sheffield Registered: 11 Mar 2007 Posts: 1,380 Status: Offline |
Got a car with a hairline crack about 1cm long in the sump. Question is could it be welded with the sump in situ? |
rikky
probably not very well as you'd want it all cleaned up properly first, including the inside at a guess________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
would never try and do it in situ, is it alloy or steel?the oil will act as a massive heatsink making a bas**rd to weld if its alloy, not so much for steel but it will contaminate the weld. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugjim
problem is its on a lease car what is going back in about 6 months so the person who is leasing it doesnt want to spend loads fixing it. Was just wondering if there was a quick fix/bodge that would last 6 months |
dcc
Senior User Location: Wales Registered: 24 Feb 2009 Posts: 502 Status: Offline |
Dont see any reason why not! clean up the surface your welding, its only a sump so as long as you weld it well on the clean side I think it will be fine. I certainly wouldnt have any issue with welding something that way.________________________________________ 205 GTIXsara HDI |
and therein lies the problem ![]() trying to get oil out of a crack in a container that is full of oil ![]() is it p**sing out? what is the sump made from? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugjim
its just weeping out, very slightly, its an alloy sump. The company who are leasing the car have tig welding equipment. |
ben306
Seasoned Pro Location: North West Registered: 17 Jan 2006 Posts: 2,954 Status: Offline |
Chemical metal putty worked on my old company car for 9 months before I left the company. (I'd been playing real life Colin McCrea Rally so couldn't send it in to be fixed)________________________________________ My 306 Rallye Project ThreadFew recent Youtube track videos, more on my channel Pair of Rallye's doing a few laps of Anglesey Lap of Anglesey Coastal 3 sisters circuit Few laps at Blyton |
dcc wrote: Dont see any reason why not! clean up the surface your welding, its only a sump so as long as you weld it well on the clean side I think it will be fine. I certainly wouldnt have any issue with welding something that way. your a pikey |
pugjim wrote: problem is its on a lease car what is going back in about 6 months so the person who is leasing it doesnt want to spend loads fixing it. Was just wondering if there was a quick fix/bodge that would last 6 months A big Disney plaster should sort it out |
rikky
i'd personally just zip tie a huge sponge to the bottom to soak the oil up with a plastic tray underneath and just leave it till the day you give it back, that's not an MOT fail either cos we've done it before^ not a lie ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
its not going to cost them out but a tube of goop if they have tig equipment, and given they have tig equipment, surely they'd have someone who knows how to weld and the pitfalls of welding up something full of oil? ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Taking a sump off isn't a big job on most cars.Otherwise drop the oil and weld it in situ. Pretty sure with a crack in alloy you should drill a hole at both ends of the crack? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
It'd need to be clean to tig, never going to happen with it on the car, you could try chemical metal and a patch but that's not exactly discrete ![]() ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
coskev wrote: Pretty sure with a crack in alloy you should drill a hole at both ends of the crack? any crack really, its the same reasoning behind stitch welding when "seam welding" a shell for race or rally cars, weld and inch leave and inch and so on, as a crank in a continuous weld will just follow the weld, a rack in a weld an inch long will only be an inch long. shouldnt need to on a sump though, its not usually a stressed member so just vee-ing the crack out and filling it back up with weld would be sufficient. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,294 Status: Offline |
if you burn through with it in situ you could have a lovely fire on your hands.________________________________________ the world is changed by people in sheds |
Clean it up and sikafkex a square ally plate over the crack, if you do a neat job it won't look too obvious. If you want a reliable weld repair, it will need to come off, be degreased and then welded. You will not get a result trying to weld it in position, the oil in the crack will ruin the weld and cause you even more problems.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
all the suggestions and nobody's mentioned draining the oil first, get it hot first then leave it to drain for a day or 2.________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
buzzbrightyear wrote: all the suggestions and nobody's mentioned draining the oil first, get it hot first then leave it to drain for a day or 2. guess you didn't read any of mine or Davey's posts then ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
buzzbrightyear wrote: all the suggestions and nobody's mentioned draining the oil first, get it hot first then leave it to drain for a day or 2. That won't work, buy a tig off me and try it for yourself to find out why ![]() ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
When the bendy busses first came to our neck of the woods they smashed two £1,500 sumps a week for 2 months on the speed bumps around Millbrook. When they found out how much replacements were I got a few to repair. So I have a little experience in this area, vee-out the crack, get the casting vapour blasted, if you can find the ends of the cracks drill them out or run a tee weld across each end to try and stop them spreading further, I often heat the casting to 300 degrees for a few hours to get the oil impregnated in the ally to vapourise, and then crack on with the welding. 100% success with this method, people ask "can't you just put a blob of weld on it?" the answer is always no.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
stan_306gti6
daveyboy wrote: When the bendy busses first came to our neck of the woods they smashed two £1,500 sumps a week for 2 months on the speed bumps around Millbrook. When they found out how much replacements were I got a few to repair. So I have a little experience in this area, vee-out the crack, get the casting vapour blasted, if you can find the ends of the cracks drill them out or run a tee weld across each end to try and stop them spreading further, I often heat the casting to 300 degrees for a few hours to get the oil impregnated in the ally to vapourise, and then crack on with the welding. 100% success with this method, people ask "can't you just put a blob of weld on it?" the answer is always no. This is the best advice. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
How much is weeping?Tesco value oil added when required FTW. ________________________________________ ![]() |
clen666
daveyboy wrote: buzzbrightyear wrote: all the suggestions and nobody's mentioned draining the oil first, get it hot first then leave it to drain for a day or 2. That won't work, buy a tig off me and try it for yourself to find out why ![]() Jim, have you seen my post in the welders thread? Don't want to take this thread off topic too much, but I was asking about those r-tech welders ________________________________________ Team 'unintentional rat look' |
pugjim
