The majority of members on here make more mess than that when they speak.
displaying posts 26 to 37 of 37
Pages (2): 1 [2]
| Author | Subject: Welding experts advice needed |
You taking the p**s? ![]() The majority of members on here make more mess than that when they speak. ________________________________________ ![]() |
t3ora
Regular Location: England Registered: 22 Dec 2009 Posts: 317 Status: Offline |
Chemical metal ftw________________________________________ Road/track car coming together slowly |
atomtigwelder
Newbie Location: staffordshire Registered: 16 Apr 2013 Posts: 9 Status: Offline |
Silicone it?????? lol cheap and easy________________________________________ Totally nuts about anything petrol consuming |
clen666 wrote: daveyboy wrote: buzzbrightyear wrote: all the suggestions and nobody's mentioned draining the oil first, get it hot first then leave it to drain for a day or 2. That won't work, buy a tig off me and try it for yourself to find out why ![]() Jim, have you seen my post in the welders thread? Don't want to take this thread off topic too much, but I was asking about those r-tech welders I'll take a look, not had much interest off the forum so I stopped looking for a bit. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
yeah, where's the leak?! ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
a new/2nd hand sump might be cheaper+easier to aquire and fit.then again......looking at the size of it you could probs get away with drilling it out then tapping it and fitting a bolt. ________________________________________ the world is changed by people in sheds |
pugjim
Seasoned Pro Location: Sheffield Registered: 11 Mar 2007 Posts: 1,380 Status: Offline |
The people who do the servicing on it wanted £500 to fit a new sump. |
oldbrownshoe
Seasoned Pro Location: Holon Israel Registered: 08 Aug 2008 Posts: 1,795 Status: Offline |
you candismantle the sump, clean it thoroughly, weld the crack and/or weld a patch covering the crack. use Loctite 518 or Martson MD 4000.574 for seal in the mating surfaces. ________________________________________ French military victories?Did you mean French military defeats? |
ian7675
Techno Viking Location: Gloucestershire Registered: 12 Oct 2007 Posts: 6,068 Status: Offline |
oldbrownshoe wrote: you can dismantle the sump, clean it thoroughly, weld the crack and/or weld a patch covering the crack. use Loctite 518 or Martson MD 4000.574 for seal in the mating surfaces. OBS posts in General section shocker ![]() ________________________________________ Less than 24 hours to go! |
oldbrownshoe
Post #35
i wrote a lot of posts of technical issues in the past,but the deletion policy of old posts is not doing good for balancing my image. ________________________________________ French military victories?Did you mean French military defeats? |
monty-69
Senior User Location: Colne Registered: 02 Jul 2006 Posts: 792 Status: Offline |
Post #36
Sikaflex is your friend |
oldbrownshoe
Post #37
monty-69 wrote: Sikaflex is your friend No, the FC11 Service Temperature range is : -40°C to +80°C, too low for sump temperature. with friends like this i prefer enemies. the MD Surface Sealant 4000.574 Temperature resistance is up to 150°C. ________________________________________ French military victories?Did you mean French military defeats? |
Pages (2): 1 [2]
