Car looks great
'98 Nile Blue 306 GTi 6
| Author | Subject: jord294s resto project |
Lecktorious
aka G. Location: Edinburgh Registered: 08 Jan 2009 Posts: 920 Status: Offline |
Post #126
I'm sure you'll be fine mate.Car looks great ________________________________________ '98 Nile Blue 306 GTi 6 |
jord294
Post #127
sadly the 405 failed it's test ![]() excessive pedal travel when braking. i must still have air in system, as car actually passed on the brake test. not a biggie. i've tidied my garage and now the 405 is out of the cold, and in there for the winter. meanwhile, my new project will keep me occupied ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
mcvite
Regular Location: basingstoke Registered: 23 May 2012 Posts: 303 Status: Offline |
Post #128
Excellent work you have carried out there,well done ________________________________________ http://s1160.photobucket.com/albums/q486/mcvite/ |
jord294
Post #129
just a little update.after some research, i found that when i turn on the ignition, the abs pump should be heard working for a couple of seconds. the pump on my car made no sound at all ![]() as i had a spare unit, i decided to swap it over. so now i have a working pump ![]() just need to rebleed the system now ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
Post #130
Any luck now? This looks spectacular. Fair play.________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
jord294
Post #131
have by the book bled the rear calipers again. or should i say primed ![]() i can understand now how air was still trapped in them. just need to rebleed the front. far too windy to do them today though ![]() ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
tvrfan007
Post #132
With abs and a dry system, I always found it helpful to cycle the abs on grass or gravel then bleed one last time. always found a little bubble somewhere! ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
jord294
Post #133
PESKY M/C !!! must of been internally leakinggenuine new m/c now fitted, and brakes bled (even ran car in gear on axle stands and dabbed brakes, just to make sure there wasn't a spongy pedal) turns out, i had bled brake system properly initially, but dodgy m/c gave the feeling there was still air in system. in for m.o.t this week, and am confident it will pass ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
jord294
Post #134
happy days ![]() ![]() ![]() now to write the 'for sale' ad ![]() ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Post #135
I was just down the road from there a few weeks ago.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
