Author Subject: Breaking 406 v6 coupe
mole man
Don't no if any parts intrest people but brembos have gone along with front seats everything else is left
Posted 3rd May 2013 at 22:18
dendle89
Whats the rear bottom engine mount like ?
Team 6 Cylinders
Posted 4th May 2013 at 06:58
Do yourself a favour snd write a decent ad for a start Wink
Posted 4th May 2013 at 07:51
mole man
Ok sorry,
Engine is sold, it's a turquoise green with lots of laquer peel but all panels are straight and just need a respray, brembos have been sold but still got the rear brakes and front discs available, lights dash parts still all good and in working order, it's the d8 model and on a 97 plate, wheels are good condition with really desent tread on,
So if any parts interest anyone let me no cheers
Posted 4th May 2013 at 11:47
mole man
I'm not sure about the bottom mount mate ill have to have a look and let u no cheers
jord294
how many ports does the master cylinder have please?
what condition are the discs in?
Posted 9th May 2013 at 11:52
calibra306
How much for fuel hoses posted (fuel rail S shape section only under hood)
V6 Power!
Faster I can go the better!
Posted 9th May 2013 at 12:55
Think they are the same as a gti6. No bigger anyway.
Posted 9th May 2013 at 13:22
calibra306
The hoses pug used keep leaking.
The unions are jubilee clipped on but with the heat the hose goes soft which is double layered and then it leaks.
Happened to both ends at the fuel rail now!
I figured id get the V6 hose as the unions are solid in the pipes and then couple up.
I needed some spare unions anyway but ive noticed the hose is more pipe so stiffer.
I might just buy some competition hose (braided) hopefully help stop the hoses going soft and leaking?
V6 Power!
Posted 9th May 2013 at 13:40
jord294
m/c is 23.8mm, but different part number to 306. am after 406 specific m/c and 305mm discs
Posted 9th May 2013 at 13:52
mole man
All fuel hoses have gone buddy I'm afraid sorry, discs are a bit rusty but look to be in good condition will hopefully whip them off at the weekend so you can see pictures
Posted 9th May 2013 at 14:05
jord294
What about the master cylinder mate?
Posted 9th May 2013 at 14:07
mole man
I'll have to have a look tonight for you buddy and let you no
Posted 9th May 2013 at 14:08
it'll be 2 port.
Posted 9th May 2013 at 15:54
jord294
You sure mei?
I was led to believe early models had 4 port m/c
Posted 9th May 2013 at 15:57
yes, being V6 it'll be high spec therefore having ABS and 2 port.
Posted 9th May 2013 at 19:14
mole man
Yes can confirm what welshpug has just said just checked
Posted 9th May 2013 at 19:16
jeffers Forum Admin
Can I suggest you look at some of the other for sale Ads and list the parts with prices in accordance with the forum for sale rules, you may then get a better response out of potential customers to! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 9th May 2013 at 19:19
jord294
so i don't necessarily need the m/c off the coupe. i'm after a 4 port for an abs car
this should be ok to use for the brembos as it is 23.8mm
Posted 9th May 2013 at 19:31
abs cars did not use 4 port.
ALL 406's are 23.8mm.
many aftermarket replacements will be 4 port and come with 2 planking plugs.
Posted 9th May 2013 at 19:44
jord294
Just testing you mei Wink
How much for the m/c posted please mole man?
Posted 9th May 2013 at 20:04
