displaying posts 1 to 25 of 44
Author Subject: vht wrinkle/crinkle paint
martinh
Has anyone used the above in an aerosol can?
The engine is out of the rallye and before the new one goes in I was thinking of doing the cam covers maybe inlet etc to tidy it all up a bit.
Any pics of results?!
Posted 13th Apr 2013 at 21:06
beez_neez_gt
I have had mine done with 2k epoxy primer then 2k red coat, it will outlast the engine LOL
With the above paints plus some high build 2k primer it can get rid of the cast surface look of the cam covers too.
VHT is ok to use but can be scratched easily and tbh doesn't do well with hot chemicals ie oil on it.
If you get inlet powder coated make sure the inside is super clean as the sandblasting dust can damage the engine.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 13th Apr 2013 at 22:24
matt evans
I used the VHT red wrinkle paint on my cam covers and they are as tough as old boots, withstood brake cleaner, steam cleaner and all sorts of stuff on it.
It's really hard wearing mate.
honestly3k wrote:
owain wrote:
Posted 14th Apr 2013 at 08:33
daver6
I'm actually doing my cam covers next week with the black VHT wrinkle. Just heat the job up before you spray
Wishbone Polybushes available
Posted 14th Apr 2013 at 08:49
beez_neez_gt
It doesnt matter what they do its still 1k paint, for longivity all 1k paints are s**t.
I was talking about standard vht paint, not used this crinkle stuff. However even 2k paint can get slightly affected by brake cleaber so i dont believe its good for that especially being 1k paint, as i have had a slight reaction using it.When my hot antifreeze went on standard 1k vht paint it stripped it off.
The only downside to 2k paint is you have to use an air fed mask and air compressor and gun or pay someone to do it for you, at least then once you have spent time refitting them with a small amount of sealant you can forget about them. Same goes with powder coating, it isnt the best but better than any 1k paints, its an epoxy type substance anyways, just one layer though unless you also get primer powder coating too.
Pug fee`ver,
Posted 14th Apr 2013 at 09:07
matt evans
That's really helpful bearing in mind the thread title don't you think?
Posted 14th Apr 2013 at 09:33
daver6
LOL
Posted 14th Apr 2013 at 09:35
beez_neez_gt
It makes no diference, its still 1k paint, just another name to make people buy more and who would want a crinkle finish if that is what it gives that is. I would use this type on stuff again but not on much. Iv used plenty of these so called 1k chemical 'risistant' paints and all so far didnt do what it says on the tin. I use to believe in all the hype of these types of paints, even one that says very durable which chipped quite easily yet the 2k stuff is very durable and tough.
If you want something that will last and look great for ages go for 2k, im not sure this paint will last long on aluminium either and using etch first wont work as etch doesnt like too much heat.
Pug fee`ver,
Posted 14th Apr 2013 at 10:09
jamiek_uk2000
Are you sure you don't work for a company selling 2k paints? It's all you seem to talk about LOL
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 14th Apr 2013 at 10:11
matt evans
Again - Let folks answer who have ACTUALLY used the stuff the OP was asking about FFS.
To the OP, ignore Mr "2-pack" above and use the crinkle paint. Prepped properly its tremendously hard wearing.
This is how the rear cam cover of mine looked when it had been done..
Thumbs up
Posted 14th Apr 2013 at 11:09
He's just very opinionated and never wrongThumbs up
And I don't think he preps surfaces correctly judging by all the trouble he has with any other paints bar 2kRoll eyes
Posted 14th Apr 2013 at 11:15
beez_neez_gt
beez_neez_gt wrote:
It makes no difference, its still 1k paint, just another name to make people buy more and who would want a crinkle finish if that is what it gives that is. I would use this type on stuff again but not on much. Iv used plenty of these so called 1k chemical 'resistant' paints and all so far didnt do what it says on the tin. I use to believe in all the hype of these types of paints, even one that says very durable which chipped quite easily yet the 2k stuff is very durable and tough.
If you want something that will last and look great for ages go for 2k, im not sure this paint will last long on aluminium either and using etch first wont work as etch doesn't like too much heat.
No i dont.
There is a good reason for that, its because iv been there, done, tried them all and found that the 2k stuff is the best type you can get for most things, 2k epoxy primer is the very best of all, epoxy 2k primer is good for aluminium blocks and parts too without the need for etch of which is useless with regards to a lot of heat. If i did sell it there would be no point as most cant spray or cant afford the air fed mask tools to use this type of paint, these costs add up but for me well worth it so you paint it once and once only and lasts. This crinkle stuff would be good enough for those that dont want to fork out for all that stuff or get them pro painted etc.
If something is worth spending a lot of time with prepping etc then you might as well use a paint that will last a very long time. I use brake cleaner to clean the oil etc on cam covers etc, that is all you need to make sure its spotless, i cleaned mine up a few times as the oil dirt etc really gets into the pours etc.
As for the finish its not for me, at least you wont be able to see if it starts to go bad as it looks like it is already LOL
I bet its hard to clean up with all them dimples in the finish.
fook off coskev he never asked you and i am trying to help others not being opinionated s**t you tripe about. You are incorrect i am wrong at times and iv addmitted that but you never have. I know how to prep and fooking paint you plep, 1k is s**t ask any pro painter that same question, only good if the cars colour only comes in 1k then use 2k clear coat. When things are done correctly and it still goes bad its the paint not me, this is my experience of it.
Pug fee`ver,
Posted 14th Apr 2013 at 11:29
Thumbs up
DAT ENGINE
Hnnnghh
Posted 14th Apr 2013 at 11:45
daver6
No i dont.
The OP isn't a pro painter and wants to use aerosol, so I'm guessing he doesn't want to pay s**t loads just to have some wrinkled cam covers.
f**k 2k paint, f**k masks and compressors. Clean them, heat them, spray them.
If after your nightly engine cleaning sessions with gallons of brake spray, you find the finish lifting, then you know you should have paid to have it done.. or set up your own paint shop
Posted 14th Apr 2013 at 12:20
beez_neez_gt
Only usually use bake cleaner on bare steel where oil has been mostly, other stuff i use panel wipe a few times over. Brake cleaner flashes off very quickly anyway so no it wont be the cause, cause its only down to it being 1k pile of s**t stuff, iv sprayed a lot of stuff in my time and know what im doing. When i did floor pan i completely cleaned it using bake cleaner and its perfectly fine as other parts iv done. Oh and when i used panel wipe on an area that was covered in oil i did get a primer reaction, i used brake cleaner after sorting it out and all is fine.
There will always be something missed granted, but as any pro painter will say, 2k is the superior paint to use, any and i mean any 1k is s**t because its only 1k, as said iv tried them all just about and just because its a new paint saying its this that and the other means nothing, experience tells me its s**t. Iv used manifold paint, done the prep properly as usual and after a few drives all this paint has peeled off. Manifold was sandblasted to bare metal, i did everything right yet its substandard stuff, bigged up by the commercial manufacturers. I always follow the paints instructions as well in case they have a certain time between coats etc.
Try scrapping 2k with a screwdriver and do the same with 1k and you will see the difference, both will eventually come off but the 2k will take far more effort in my experience.
I guess it all depends on how long you want it too look good and costs etc, as said if anyone wants to use it due to these reasons its fine, im just saying there is better stuff to use and looks much better imo too.
Pug fee`ver,
Posted 14th Apr 2013 at 13:45
Brake cleaner usually flashes off too fast to take the oils and dirt off the panels with it, it just leaves it behind, hence panel wipe....
Posted 14th Apr 2013 at 13:46
beez_neez_gt
Not if applied on the cloth then wipe off with a clean dry one it dont, depends on which type you use too. Proper greased oiled up parts need brake cleaner as panel wipe in my experience did a s**t job. Dependant on job i do use panel wipe afterwards too, it can never be too clean.
Pug fee`ver,
Posted 14th Apr 2013 at 13:57
No i dont.
LOL bellendThumbs up
I would spend abit more time forming your brake pipes and wiring to match your super dooper 2k paint if I was youThumbs up
Posted 14th Apr 2013 at 14:43
Takedown
VHT BLACK
Posted 14th Apr 2013 at 14:47
That looks epic too^
And the fuel rail!
Posted 14th Apr 2013 at 18:40
matt evans
Listen, the Painting expert knows best. I've just been in the garage to attack a spare pair of cam covers I painted up in VHT wrinkle red and guess what?
He was unimpressed.....
Posted 14th Apr 2013 at 19:11
clen666
LOL
Team 'unintentional rat look'
Posted 14th Apr 2013 at 19:33
Takedown
Bulls**t,
i did it for the first time, sprayed a lot on it it you compare it to normal painting, turned out not that good... added A LOT MORE PAINT, let it dry overnight and it was perfect!
I really needs A LOT OF PAINT to cure to a very nice small grainy surface, when you spray not enough it wont look good.
Guess the paintexpert needs to learn how to paint wrinkle LMAO
Posted 14th Apr 2013 at 19:35
Takedown
And beezneez, thats bulls**t, its hard as nails... and wont be affected by gasoline, brakecleaner,oil or whatever!
get your facts right
Posted 14th Apr 2013 at 19:36
jord294
not emigrating now martin??
Posted 14th Apr 2013 at 19:37
