displaying posts 76 to 100 of 183
Pages (8): first .. 3 [4] 5 .. last
Author Subject: My Xsara VTS project
demondriverdan
Post #76
You may have said but what cams are you running?
Rallye Race Car
Posted 13th Nov 2014 at 21:03
IvayloPavlov
Post #77
IvayloPavlov wrote:
Posted 14th Nov 2014 at 19:17
burnout21
Post #78
Is that exhaust a modified 306 one?
Posted 14th Nov 2014 at 20:02
Post #79
nope, the hangers are different and the bends are different under the tank.
Posted 14th Nov 2014 at 20:05
IvayloPavlov
Post #80
De-cat & Remus is modified GTI6,but the middle part is made to order.
https://www.youtube.com/watch?v=0eN8l3jRoe4
Posted 14th Nov 2014 at 20:19
IvayloPavlov
Post #81
Posted 28th Nov 2014 at 21:21
p-silva21
Post #82
Standard manifold again? or are you using it until you have it properly mapped?
Posted 28th Nov 2014 at 22:24
IvayloPavlov
Post #83
I will use for first 1 000 km with standard ECU.After that back to ITBs and Megasquirt2.
Posted 29th Nov 2014 at 21:49
IvayloPavlov
Post #84
Again on ITBs
I've made vacuum plenum for ICV and MAP sensor.Unfortunately the car is rich on idle and lean on full throttle.
So I made Megasqurt loom.
Posted 6th Feb 2015 at 19:09
IvayloPavlov
Posted 6th Feb 2015 at 19:10
IvayloPavlov
Post #86
Oil pressure is important.
Posted 14th Feb 2015 at 20:58
IvayloPavlov
Post #87
Some basic settings,
tests,
http://www.youtube.com/watch?v=YlxQ-JQhU_w
and wiring.
Posted 30th Mar 2015 at 21:02
IvayloPavlov
Post #88
buzzbrightyear wrote:
What brand of clutch have you fitted?
OEM clutch is down after 10 drag starts at full throttle. Any suggestion is welcome.I expect close to 200 hp at the flywheel (pessimistic). Big grin
Posted 15th Apr 2015 at 11:22
Post #89
stop doing stupid drag racing Razz
o.e.m clutch here at 200 bhp.
Posted 15th Apr 2015 at 14:03
IvayloPavlov
Post #90
Posted 19th Apr 2015 at 20:26
IvayloPavlov
Post #91
How to instal after market oil pressure sender? You need to move OE switch behind the starter.
Posted 21st Apr 2015 at 20:03
IvayloPavlov
Post #92
In order to keep Max Duty Cycle at 80% OEM injectors is going to be replaced with the EV6 generation 317cc @3 bars Audi TT injectors.
Posted 28th Apr 2015 at 21:53
IvayloPavlov
Post #93
And Oil Cooler
[url=http://postimage.org/image/5sp02rg03/full/][/url
Posted 29th Apr 2015 at 19:15
6waysforward
Post #94
Snap Smile
**edit** Balls, can't add the pic of my clutch on the iPad. See my project thread page 3 Thumbs up
Posted 29th Apr 2015 at 20:29
IvayloPavlov
Post #95
Absolutely the same clutch.LOL Mine have the same reference printed on it.Shock
Posted 29th Apr 2015 at 23:47
burnout21
Post #96
Thought you was or had removed the A/C?
I'm looking at removing mine.
Also, what flow rate was the original Vts Injectors?
Look different to the Gti-6 ones,
Posted 1st May 2015 at 07:29
IvayloPavlov
Post #97
No, I am not.This will be my street fun toy.
VTS use the same injectors as GTI6.Pics above shows my new upgrade.
Here it is my new clutch.
Posted 1st May 2015 at 17:24
rallyeash
Post #98
What bodies are they?
309 3dr K20 Type R
Posted 1st May 2015 at 19:49
IvayloPavlov
Post #99
I don't understand the question. Are you asking about the injectors or ...?
I have mounted the oil cooler today.
Posted 1st May 2015 at 21:08
p-silva21
Post #100
I think he`s talking about the ITB´s... if so, he said in the first page they are CBR 1000 RR bodies Smile
Posted 1st May 2015 at 21:27
