displaying posts 51 to 75 of 183
Pages (8): first .. 2 [3] 4 .. last
Author Subject: My Xsara VTS project
IvayloPavlov
Post #51
Head is down,pistons are outLOL
Posted 8th Jul 2014 at 23:13
IvayloPavlov
Post #52
Block looks not good but other one from XU10J2TE is perfect.Engine is out and full rebuild is in action.
[url=http://postimg.org/image/xbe5i09jh/full/]
How to make deeper pockets with your old block and damaged head.
Posted 30th Aug 2014 at 20:04
IvayloPavlov
Post #53
Here it is new block and pistons.New rings & bearings.
Posted 25th Feb 2016 at 21:18
IvayloPavlov
Post #54
Posted 25th Feb 2016 at 21:25
pebbles167
Post #55
Good to see this coming along Yes
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 4th Sep 2014 at 00:28
demondriverdan
Post #56
I've heard good things about the K6 but people have said it can be slow to map. I think the key with an ECU is to get one that your mapper knows as ultimately, we're not the ones that are actually going to be doing the mapping!
Rallye Race Car
Posted 4th Sep 2014 at 07:11
IvayloPavlov
Post #57
Unfortunately in my country mappers are knowing only Megasquirt or their own brand. I can't find guy who knows Emerald, so I will look for Vems or Megasquirt2.I have very good offer for homemade MS in original case and plug.
Posted 4th Sep 2014 at 21:41
IvayloPavlov
Post #58
Bottom work finished.
Some works to flowers.
And after very good job on the head ...
I found issue with 7 of 8 lobes.
But we have decision.Big grin
Posted 26th Sep 2014 at 22:06
Post #59
NOM NOM NOM sayd the die grinder Big grin
have you checked the spray bars as well?
Posted 27th Sep 2014 at 11:33
IvayloPavlov
Post #60
Under the pistons or above the cams?
Posted 27th Sep 2014 at 19:35
p-silva21
Post #61
I think he meant above the cams as you may have some clearance issues with cams with a big lift. Probably you´ll need to modify the oil spray bars too
Posted 28th Sep 2014 at 13:02
Post #62
Yes the ones above the cams, I havent got that much peak lift on a ph2 cam but they are very close to the spray bars, and clear the head fine.
whats the peak lift you have? As the std valves dont have that much more space either
Posted 28th Sep 2014 at 13:35
IvayloPavlov
Post #63
Yes. I found this problem but I don't know how to fix them.Any suggestion is good received.Wink
Max lift 10.95 mm for both.
Posted 30th Sep 2014 at 21:18
IvayloPavlov
Post #64
Only plastic end is an issue.
Posted 2nd Oct 2014 at 19:51
IvayloPavlov
Post #65
Some works with the clocks ...Wink
Posted 10th Oct 2014 at 21:57
Post #66
What brand of clutch have you fitted?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 10th Oct 2014 at 22:08
IvayloPavlov
Post #67
OEM.
Posted 11th Oct 2014 at 23:30
IvayloPavlov
Post #68
What do you thing about this?
Posted 15th Oct 2014 at 21:03
Post #69
great if you know electronics and are willing to learn mapping.
Posted 15th Oct 2014 at 21:10
IvayloPavlov
Post #70
Ready to go!
Posted 21st Oct 2014 at 20:51
RetroPug
Post #71
Looking good!!!
Posted 22nd Oct 2014 at 18:53
IvayloPavlov
Post #72
And the engine started a few minute ago.Big grin
Posted 22nd Oct 2014 at 21:08
IvayloPavlov
Posted 24th Oct 2014 at 21:06
IvayloPavlov
Post #74
Relay board & some additional ignition drivers arrived Big grin
Posted 12th Nov 2014 at 19:32
IvayloPavlov
Post #75
Posted 13th Nov 2014 at 20:50
