displaying posts 101 to 125 of 183
Pages (8): first .. 4 [5] 6 .. last
Author Subject: My Xsara VTS project
IvayloPavlov
Post #101
Correct, 44mm CBR 1000 RR bodies.
Posted 2nd May 2015 at 08:56
IvayloPavlov
Post #102
Standard OEM dampers were replaced by pugheaven's gas one.
Posted 3rd May 2015 at 15:22
IvayloPavlov
Post #103
The car is waiting her new water cooler.I already have ordered Dturbo phase 2 radiator and diffuser, he is 5.5 cm bigger than the GTI6 one.
Posted 7th May 2015 at 19:59
IvayloPavlov
Post #104
Here is the difference between both
Posted 8th May 2015 at 19:44
IvayloPavlov
Post #105
Posted 9th May 2015 at 21:22
IvayloPavlov
Post #106
Posted 10th May 2015 at 20:10
IvayloPavlov
Post #107
Smile
Posted 11th May 2015 at 19:12
IvayloPavlov
Post #108
Power steering pump died yday,so I decide to go FWD w/o power steering.
Posted 24th May 2015 at 13:05
Post #109
why go slow steering?
Posted 24th May 2015 at 13:13
IvayloPavlov
Post #110
Because of 106/Saxo pump is not enough strong and Air Con. It is impossible to have not electric pump.
Posted 24th May 2015 at 14:12
IvayloPavlov
Post #111
Some pics of today
Posted 24th May 2015 at 14:17
IvayloPavlov
Post #112
Posted 7th Jun 2015 at 20:23
IvayloPavlov
Post #113
Some paint job.
Posted 9th Sep 2015 at 22:24
MisterGTR
Post #114
Just seen this thread for the first time. Brilliant work. Very inspiring.
Can't wait to see it running in anger!
Posted 9th Sep 2015 at 23:23
IvayloPavlov
Post #115
I have litle problem with the middle range.The car won't start under 4 000 RPM but after that is burning his tyres. I bought R888 and C5 wheels but didn't fit with my 15 mm spacers because of Brembos. I have to order 25 mm spacers.
For the moment the car is mapped by me and make stable midle 15th with a lot of burnout.
* left is mine Roll eyes
Posted 13th Sep 2015 at 20:44
IvayloPavlov
Post #116
Posted 4th Nov 2015 at 21:00
Post #117
you made less than stock power?!
Posted 4th Nov 2015 at 21:08
IvayloPavlov
Post #118
It is on the whell. Stock was 136 first page post #8.
Posted 4th Nov 2015 at 22:33
IvayloPavlov
Post #119
I am going to replace my FD 19x77 (4.06) with the shortest possible for 6 speed BE gearbox 19 x 79 (4.15). I am wonder if will be better to replace curent first gear 2.92 with 3.45?
Posted 16th Nov 2015 at 20:33
Post #120
you really dont want a 1st shorter than 2.92, its not a diesel van!
where did you find the 4.15 for the 6 speed? std is 3.95 or 4.06.
Posted 16th Nov 2015 at 21:06
IvayloPavlov
Post #121
Citroen Xantia or Peugeot 406 XU5 1.6 88 HPBig grin
Posted 16th Nov 2015 at 21:15
Post #122
they are not 6 speed ?!
Posted 16th Nov 2015 at 21:22
IvayloPavlov
Post #123
They are not,but 79 tooth wheel will fit 6speed gearbox.Both GTI6 77 tooth and XU5 79 tooth wheel work with the same second line 19 tooth wheel.
Posted 16th Nov 2015 at 23:04
Post #124
no they dont!!!
it doesn't work like that.
Posted 16th Nov 2015 at 23:33
IvayloPavlov
Post #125
Yes,you are correct. The bottmo of the GTI6 pinion is stamp 19x77, so I've changed the bearings only.
Posted 16th Dec 2015 at 23:13
