displaying posts 1 to 25 of 49
Author Subject: Black rallye refurb......
Wallopadonkey
Welcome to my project thread
Had this for a few months now
and it had developed a few little problems
Gearchange was not nice and quite hard going into second almost like it only goes in 2 mm and can pop out if not held in place (was fine at first but lent it to a friend and it came back like that)
Then this happened...
Woo woo
Radiator
I bought an oe timing belt kit, water pump, and head gasket with bolts just in case
However after talking to a few members it would seem it will more than likely warped the head so...... No point messing about then.....
lol first attempt 4 hours or so with a few interesting discoveries on the way!!
Posted 13th Feb 2013 at 14:05
jord294
look forward to see how you progress dave Thumbs up
Posted 13th Feb 2013 at 14:24
step1: make car higher off the ground
Posted 13th Feb 2013 at 14:28
banksey
Still love the look of these. Smile
Posted 13th Feb 2013 at 14:29
Wallopadonkey
Cheers Andy
I am going to have a little time to sort the bushes and stuff out pics to follow!
I'll get you to have a look at my beam for me if that's ok I'll chuck it in car and fetch it over unless you are down this way.
I have secured yippeekayay's low mileage engine and box
so have plenty of time to get other bits sorted
Posted 13th Feb 2013 at 14:35
Wallopadonkey
@rikky yeah I will be raising the suspension a bit I have heard bilstein dampers with suitable springs are the way forward.
@banksey they are beautiful nice hips and curves too lol one of my favourite car shapes
I am going to put the rebuilt engine into a 205 rallye they just don't have enough ummmmf about them fancy a yellow one next
Posted 13th Feb 2013 at 14:44
Wallopadonkey
I'll be stripping the car just a bit to improve the handling and power to weight ratio and I have some special seats for it in mind custom made for the rallye
Will want a solid bottom pully, lightened flywheel my ecu was supposed to have a superchip but I will have to open it to see if it does
Oh and it should have a ported throttle body but I guess again we will see!!
Posted 13th Feb 2013 at 14:58
Wallopadonkey
Rightio then I had quite a good sniff about whilst lying underneath the car and I might need a few bushes and arms lol it was never the best handling but it was better than most I have driven lol
Also I am sure this is on its last legs! Pass side balljoint
And think this needs replacing too
I take It the cracks are not decoration lol
Oh yeah and this as well
Lol I will need to sort out replacements soon
Posted 13th Feb 2013 at 15:39
Wallopadonkey
Just noticed I'll be needing some braided hoses too lol
Posted 13th Feb 2013 at 16:14
scotzman
Don't fancy trying to get those old ones off either
Posted 13th Feb 2013 at 16:16
russbez
its all fixable mate, why we do it i do wonder
good progress Smile
My Rallye project thread
Posted 13th Feb 2013 at 16:21
Another black rallye being saved:-) keep the good work up
Posted 13th Feb 2013 at 18:25
Wallopadonkey
I am right that the bottom engine stay is knackered yeah
So is there another option to grp n mounts worth getting ? Not bothered about harsh as long as supple
I will be going solid rear mounts too in time
Also which bushes for bottom arms don't want roller bearings really but would like this to be a nice firm ride judging by the state of everything else I will change them while I am down there would I be better going down the new standard route
Would that be ok with solid rear or just replace rears with new I dunno what ya think
Posted 13th Feb 2013 at 19:39
Wallopadonkey
Ok
Gear change been a bit ropey i take this is the quick shift part
Does it look right ?
Posted 13th Feb 2013 at 19:49
jord294
pugheaven has a decent pair of upgraded wishbones Yes
imho, i'd fit new standard engine mounts, but maybe fit a more solid bottom engine mount. chassis ok where you took top mount from?
Posted 13th Feb 2013 at 20:01
mike rallye
Great work , your doing there. Always do love a black rallye
Posted 13th Feb 2013 at 20:06
Wallopadonkey
Top mount was clean
But rubber thing didn't look great....
This end was loads shorter than other
And in car
Top if picture looks like it has worn away!!!
Posted 13th Feb 2013 at 21:05
Wallopadonkey
@ jord294 andy is it better to replace bottom arms than rebush those ones ?
Posted 13th Feb 2013 at 21:07
silky
Is just alot easier to swap arms over if you have a spare set all ready to go on
Posted 13th Feb 2013 at 21:19
Wallopadonkey
Aye just messaged him now
If I get them why are the equivalent rear bushes group n ? Or solid?
Posted 13th Feb 2013 at 21:30
Wallopadonkey
Is there someone selling braided brake hose sets still?
Posted 13th Feb 2013 at 21:31
rich306
Glad to see another Black Rallye being worked on.
I found some heavy rust on the underside of the car buddy so be warned and check your chassis rails for rust under the rubber coating.
Especially if the rust is quite bad everywhere else lol :p
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 13th Feb 2013 at 21:38
Wallopadonkey
Arms are sold I'll have to think again !!
Posted 13th Feb 2013 at 21:39
jord294
The top mount buffer sort of looks like that.
The best thing to do is fit some type of shim before refitting buffer
Who is this Ian you keep mentioning?
I've been told vibratechnics do half decent p bushes. I have new front wishbone bushes in stock
Posted 13th Feb 2013 at 21:51
Wallopadonkey
Got you in my phone as Ian ????!
Lol
Just looked at profile and it's Andy lol sorry mate
Must of heard wrong on the phone pmsl
Posted 13th Feb 2013 at 22:05
